| Turbo Lounge Place for off topic relaxed discussions * No political or religious threads * |
LinkBack (7) | Thread Tools | Display Modes |
Odell crash video
Well as unfortunate as it is, I just so happened to be pointing my video camera right at his car when he had his wreck. This is my first Youtube video so it may not be 100%, but it will get the point across that he is a very lucky man. God was with him today.
You took a hard lick man, and let me tell you I felt sick as I was recording it, but I knew I had just got the whole thing on tape and figured I would try my best to get good footage. Take the rest of the week off, and get better. Your turbo buick brother, Jerry Berger Jr.
1984 Grand National Stock block, 208 / 208 cam. Champion ported irons. Stock 86/7 intake with modified plenum. 50lb MSD injectors fed by a Walbro 340 pump - hotwired. SMC round bottle alcohol kit. 2.5" Kenne Bell headers, crossover, and uppipe. 3" stainless Mease downpipe with a dump pipe. TA-49 turbo reclocked and running into a Spearco intercooler that is mounted in the 86-87 location. 86-87 radiator, electric fan, oil cooler. 86-87 ECM /w TT chip. Red stripe torque conv. (2800), HR Poly motor mount. PST poly body and suspension bushings. Homemade cold air kit. The car was completely totaled in '01 and the car has been rebuilt. If you want to see what my cars paint job looks like, check out my webshots album linked at the bottom of my sig. My car pics page Last edited by Waco84GN; May 15th, 2009 at 11:46 PM. |
| Sponsored Links |
God, thanks for letting us keep OC for a little while longer.
That video made me sick to my stomach...
John Wilde "She peels out, she is a sweetie." David Spade on his GN Car was stolen 3-12-10 Car was recovered 3-17-10 http://www.turbobuick.com/forums/tur...ml#post2446605 |
Man o man........thankfully he is OK.
Rich from Rich's Auto in New Jersey Home of the Jack Home of the 9 second street cars 9.02@153.60, 1.33 60' in Newman "SLVRSTG" thru the Exhaust JCC Racing Team President Proud Driver of a a FaRTIE LaHaie tuned automobile Buick Performance Group Member # 1071 Former G-S-C-A # 3372 Been banned from the G-S-C-A BB 4 times in my life.....now who else can say that!!! |
Wow that was a hard hit into the wall and real lucky to walk away from that.
I hope they gave him something at the hospital after being looked at for the after effect pains that he is sure to have tomorrow and probably a few days to come. Glad he is ok and hopefully going to take it easy a few days. John
86 T-Type, new engine/combo with 917 miles,tuning inprogress on 93 octane,dual nozzle alkycontrol not turned on,yet. An occasional driver GN1's,T&D 1.65 rockers,CompCams Roller,70mmtb/plenum,Little KB fmic,60lb.inj,NGK plugs,RJC power plate,MaftPro,Accel super coil,ATR sway bar,TH-400''Finally I won't be the worst president in history'' - Jimmy Carter "The economy is on life support," says Scott Bradley, 38, general manager of a carpet store in Columbia, Mo. Bradley says he voted for Obama in 2008 but he wouldn't again."Obama's policies are making the economy worse." Date Presidential Approval Index Strongly Approve Strongly Disapprove Total Approve Total Disapprove 9/02/2010 -13 29% 42% 47% 52% |
x2, You could see the emotion on Cal Hartline when something happens to a close friend. Cal lines him up in the burnout box and is the first to run to his aid. That's a true friend!!!
Mike Ricketts ![]() DLS built 4.1 StageII/ 76turbo/ 44mm Tial/ BG ported intake/ 1.75 T&D jessel style rockers/ FAST system/ TH400/ PTC converter (Thanks Dusty)/ TA heads/ 5" DP/ TA SS 4 bolt Headers/ Champion Racing/ RJC front mount/ 95lb/ Racetronix harnesses throughout the car etc... Cal Hartline tuned........ DLS ENGINE DEVELOPMENT 886 E 900N, Wheatfeild, IN, 46392 219-956-3653 HARTLINE PERFORMANCE 321-722-1563 My Track passes http://www.youtube.com/watch?v=mKEIyppgOr0 http://www.youtube.com/watch?v=6SqbYtfQn8c |
I think he just got out of the groove early, pushed to the right and then broke traction. Thank God hes ok.
87 GN 8.81@158 Getting there. |
Just wow man.
If you can't fix it with a hammer, you've got an electrical problem. Boardwalk Ferrari/Maserati www.boardwalkferrari.com |
Indeed you are correct my friend, but on the other hand that car needed to have that suspention dialed in, even on the the burnout you can see the car push to the left which tell me that the suspention is not correctly adjusted, pushing either left or right during a burnout tells you that 1-suspention needs adjustment or 2-your posi is going out because one tire is grabbing more than the other, plus getting out of the groove didnt help things at all and trying to correct to quick is what made the car hit the wall and flip, if he has the HR Sway Bar on that car, he needed more preload on the passanger right tire in order to prevent this from happening, a guy in area 2 yrs back had the same problem and after i went to his pit and made the proper adjustments to the bar the car went straight as an arrow.. Hope he is ok..
The several cars that went down the track prior had trouble as well keeping them straight. (this happened after a rain delay) I would have thought some of the slower cars would have made passes first to help put some rubber down. The track had to be cool after it was rained on for as long as it was. I know OC has to be sick looking at the car but the MAIN thing is, he's ok and still here to build again. We can replace cars but we can not replace friends and family. I was in total shock watching it unfold, glad your are ok OC and still with us to fight another fight.
Scott Lambert 87 GN 32k Original Owner GT6131e, Crane Billet Roller 212/210, 3" SS THDP, 9" Art Carr, 57lb inj, 22 Row Thunder Fab, Hooker Cat Back, Hot wired Fuel pump, Adj fuel reg, Bell Mouthed TB, Stock location K+N w/ Postons base lid, Scanmaster, Ported Big Valve Heads- All Studed 86 T-Type Now a Parts Car 87 Turbo T Astro-Roof Chrome Trim 87 Turbo T Solid Roof White w/ Blk Trim-Mama's New Toy 85 Limited Hard Top N/A V6 116K Very Rust Free - For Sale |
crash
Thanks to everone for the support, i got home around 1 pm today,
true im a little sore, but my bank accound did and will have more suffering, that is if i dont give up and part out the old car, hartline give me a lot of support plus tuning the fast and dialing in the ams 1000 controller, i told cal after the crash he did it , by adding more power of course he knowed i was kidding him thanks,oc,
oc , |
oc , |
Damn bro...at least youre okay. On a different note, this is why we keep it on the track. You never know what could go wrong.
84 TType 87GN motor swap Stock Turbo evil bay FMIC 200r4 shift kit K&N Filter TT Street 91 Powerlogger Translator/LT1 MAF 60lb inj DIY Alky Hotwired FP 2.5'' Single Shot Cutout No Cat MagnaFlow Muff Jounce Frame Braces and GP Brace 34mm F Body Sway Bar The ladies love my Power Bulge.
Glad to here you're OK Odell. That was a nasty wreck. I've seen some nasty dirt track ones about as bad and they didn't walk away. Jerry, next time post a little more so we can see the driver get out ok. That was my biggest concern.
Just a another twisted Moderator. Wanna know how well your President is doing. I GOT LAID OFF TODAY!!! 7/10/09 Working again now and lost $4160 a year. Thanks OBOMBOUT! My new project. http://www.turbobuick.com/forums/sho...ml#post2230675 See where it leads. ![]() How to build a B4Black turbo? Take a look. http://www.turbobuick.com/forums/bef...ted-equal.html |
Odell, I'm so glad you made it out ok. You've definitely always set the best example for us in the Buick community. I hope you get the (a) car together soon and get back out the the track without too much $ lost.
I still have one of those aluminum rods you gave me at the Nats in 2003 - a great keepsake. John Nguyen |
Wow, that looked very nasty!!! Glad to hear he made it out okay though as that is the most important part. Hate to see this happen to anyone, but especially somebody like Odell who is so well liked in this small community and has spent so much time, money, and effort into building his Turbo Buick.
87 Turbo-T, bolt-ons.... |
I am so glad you are alright Mr. Odel! I wanted to come speak to you but you had such a crowd and I figured you didn't feel to good...
I didn't see it but I heard it and I knew it was bad, too much noise I took one look at the car and turned around, brought back to many bad memories. I hope you get it back together! Hope you feel better too!
John 3:16 "For God so loved the world that he gave his one and only Son, that whoever believes in him shall not perish but have eternal life" 1987 GN 47K 1987 GN 26K 1987 T 18K A few more TR's! Isac Alky Controller! Best Alky/Boost Controller on the Market T6P.COM Big Wood Racing Where Fast is never Fast enough! BoostedWhips.com NCSHANE.COM |
Thanks grim, and all the buick people,
the car body would be very expensive to rebuilt only good part is the right front fender and grill, my son did a good job on the rollbars i was asked was the car NHRA legal, yes it is certified in march i have a nhra driving license also, at my age 69 in 20 days, do i really want to start over with a new chassic, my car had a lot of frame reinforcement that people never see, anyway i know where there is a nice roller with a rollcage that will certifie down to 8.50 , now i just have to buy it, looks like ill have to bale a lot of hay this year, thanks to all, oc,
oc , |
Odie main this is your OK, I was swick when I saw this not many nicer or better guys out ther IMO. If you need anything you got my number
Mike
Website & Online Ordering: www.fullthrottlespeed.com Tech Support:www.fullthrottletech.com Our Ebay Store: http://stores.ebay.com/Full-Throttle-Speed ___________________________________________ It is easy to spot the pioneers - They are the ones walking around with arrows in their back. |
I'm glad you have such a positive attitude about the situation. Good luck with what ever route you decide to take.
87 GN girdled,k1,GN1's,PT-67,TH 3"dp 60lb. inj.,Scorpion 1.55,215/220 roller,V-4 intercooler,9" 3200 Art Carr,ATR double pumper, TurboTweak Chip,Alky Control duel nozzle kit...more to come!! |
Man I'm so glad you were ok. It was right in front of me when it happened. My buddy and I heard a loud pop right before you lost it, and swore it was an axle that broke, but whatever caused it, I'm glad you're ok.
87' GN Ported Irons, 200/200 cam, TA60, 3"THDP, 009's, V4, Translator with LT1 Maf, TT chip, Alkycontrol, Pypes Exhaust, Power Logger |
Odel I saw the wreck first hand and I'm glad you made it ok. When I first saw it happen, it was like it was happening in slow motion to me. I've rolled a vehicle in a bad accident myself and know somewhat of what you went through there. I also finally stopped upside down like your car was. I had to crawl out the back window and was lucky I wasn't crushed since I didn't have any rollbar. After you get out of the car, you feel like you are in a dream and are trying to figure out if you are still really alive and all your limbs and such are still there. You are in total shock after it happens. I'm glad you had many supporting people around you. The car can be replaced! You cannot! Hang in there and things will surely get better. Take care my man.
![]() ![]() ![]() 87 GN - going back to stock for now...almost ready to hit the road again after 3 years! |
Odie - You are a trooper my friend. I'll pile my thanks to the Lord that you're OK. I hope to see you keep at it. Such a nice car and you're a really nice old boy. If you're thinking of a new car, I've got a pretty nice set of Geo doors to get you started - on the house !!
That car just makes really good reliable power, always a good performer, good mechanics make it look easy. Roger |
I'm sure everyone will appreciate 11 sec advice about an 8 sec car. Happy he's aight. Cal can be a part of my safety crew anytime!.
TOYOTA TRUCK - aka "yellow rice rocket" http://www.youtube.com/watch?v=eDr83V6_5js&feature=fvw http://www.youtube.com/watch?v=JkyywX7YqBM V8 with 88's Last edited by Chevota; May 17th, 2009 at 05:26 AM. |
Odell
Hey OC
Wife and I are glad you are ok! hrmmm to old to start over; what kind of talk is that? Sounds like you have already found one to get things on the go with. All the best on your decision. Later AJ
1987 Grand National Tell me and I will forget. Teach me and I may learn. Involve me and I shall understand. ___AJ___ |
Very good to hear that you made it out okay (would have been nice to see it on the video as well). It's easy to question your desire to continue after a crash, regardless of your age. Nice to hear you talking about that roller. Give yourself some time to recover.... you'll be back!
1987 Regal T Stock turbo @ 22lbs, 55#'ers, adjustible FP regulator, Razor's Alky, TT chip, RJC Power Plate, RJC boost controller, cold air kit, ported stock elbow, 2.5 DP, hot wired Walbro 340 fuel pump, DirectScan, restalled D5, UMI rear suspension, and 275/60 BFG DRs. 1968 Pontiac Lemans |
You forgot to leave out that sometimes $hit just happens, even with everything right........ How a 10.90 car reacts is very different than a 8.x TSO car. I can bet he isn't running a Posi . Glad you are OK OC, get that backup roller out and start swapping parts. Don't give up, it won't be the same without you there.....
5.31 @ 139.10 1/8th, 28x10.5 tire 3410# 8.19 @ 171.73 Garrett 47/88 turbo, no billet wheel Powered by DLS Engine Development 219-956-3653 Big Stuff 3 Twisted 6-PTC converters TA cylinder heads |
New TSM Combo, Built by Alexander Automotive Motor by Don Cruz Special Thanks to Hartline Performance Pine Tree Posse Member #0970/ DSR Member #021 ![]() |
LinkBacks (?)
LinkBack to this Thread: http://www.turbobuick.com/forums/turbo-lounge/285758-odell-crash-video.html
| Indiana Chapter Buick GSCA • View topic - Odell Cantrell's mishap | This thread | Refback | February 4th, 2010 07:55 AM | |
| Indiana Chapter Buick GSCA • View topic - Odell Cantrell's mishap | This thread | Refback | November 26th, 2009 10:51 AM | |
| Chicagoland Buick GSCA • View topic - Odell Cantrell's mishap | This thread | Refback | October 25th, 2009 10:06 PM | |
| Chicagoland Buick GSCA • View topic - Odell Cantrell's mishap | This thread | Refback | July 24th, 2009 04:58 PM | |
| Chicagoland Buick GSCA • View topic - Odell Cantrell's mishap | This thread | Refback | June 2nd, 2009 11:21 AM | |
| Indiana Chapter Buick GSCA • View topic - Odell Cantrell's mishap | This thread | Refback | May 18th, 2009 08:17 PM | |
| Chicagoland Buick GSCA • View topic - Odell Cantrell's mishap | This thread | Refback | May 18th, 2009 07:05 PM | |
