10.4 @130 on pump, no alchy
I was shooting for 10's....could not believe what it did.
Drove the car to the track on my 275/60/15 M/T DR's then busted off some 11's. The car was running fine, so I turned it up a little Best 60' was a 1.59 on the DR's launching at about 8 psi or so. I learned that these tires need a big burnout to hook....at least for my car.My only disclaimer is that the car had 1/8th tank of C16 left in it. Added 10 gallons of Marathon 93 No alchy.Best part was it was driven home, no broken parts ![]() Witnessed by the Lonnie Diers and Steve Hughes.
Kevin Bolger ![]() '87 Turbo T 9.83 @ 138.56 11/3/07 Engine, V1 intercooler and transmission by Extreme Automatics http://extremeautomatics.com/ Also thanks to Kip at Excessive Acceleration #4 in TSM points series for 2007 Last edited by KevinB : November 17th, 2007 at 05:19 PM. |
I thought you had meth, then i actually read it
Damn good pass! I assume it has aluminum heads and 20° of timing or so? BW
BRYAN Eric Marshalls Turbo Tweak Chips Timeslips for white car TA61/009 Inj Under hood shot of white limited ![]() ![]() Proud TTA owner |
Thanks guys!
It has GN1's. I ran it at around 19 psi creeping to 20 and 21 degrees of timing with an a/f around 11.4.
Kevin Bolger ![]() '87 Turbo T 9.83 @ 138.56 11/3/07 Engine, V1 intercooler and transmission by Extreme Automatics http://extremeautomatics.com/ Also thanks to Kip at Excessive Acceleration #4 in TSM points series for 2007 |
What was the 8th mile time and speed?
what does your combo consist of?
86 T-Type 7.2@96.5 1.7 60' 170k Bone stock longblock except for valve springs. 91 octane gasoline and single nozzle methanol.
It's interesting to watch peoples faces as your driving out of the track to go home
Dan don't run your mouth if you cant run your car 86/87 GN and 89 TTA .. tons of parts !! Time to get out! Stuff has to go !!! Otherwise I am cutting it up and throwing it away email ttastage2@yahoo.com
The whole timeslip looks like this:
r/t -.002 60' 1.594 330 4.408 1/8th 6.719 mph 106.09 1000 8.720 1/4 10.425 mph 131.84 <---that's only 8 mph less than my normal c16 tune Here's my list of parts. http://www.turbobuick.com/forums/tim...ombo-database/ The cam is different now though, still a hydro roller. Quote:
Congrats! I'll never achieve those times. However, your headline is a little misleading since you using 3-4 gallons of 118 octane mix with pump gas. Probably had octane average near 100 or better.
Technically, we can pump 100 unleaded locally, is this considered pump gas? In my mind pump gas is a cheesy lousey turdfilled 91 octane in California. ![]() |
Even if it was 100 octane, 10.4 on drag radials on a conservative tune is very quick! BW
I'm thinking of doing the e85 thing. I have a buddy here with a very fast turbo 'Stang that has been running e85 with very good results all year. I've been picking his brain about a setup for my car. I think this is the future ![]()
Yeah, i understand the e85, as long as you can throw enough fuel at it and if its cheaper in the long run over running pump gas.
Hypothetical situation~ High z60's as the main injectors and use 2 large injectors under high pressure to make up for the extra needed fueling that run constant like a throttle body injection on a older GM..... That or inject propane as the constant and use e85 with larger injectors. All just to keep the stock ECM till high z 120s are avail. Who wants to be the guinea pig? BW
I have Accel Gen7, I am thinking of doing 160's or bigger for injectors (I have 96's now.) I need to replace my -8 feed with a -10 and probably run 2 Aeromotive 1000 pumps (Thats overkill, but safe.) Also may replace the stock tank with a big fuel cell.
