LinkBack (11) | Thread Tools | Display Modes |
Congrats to the winner...
Now someone please lock/unsticky/delete this thread before somebody who cannot read asks to be put in for it 2 months later!!! ![]()
87 GN - Head gasket: 1----->Me: 0 7.30 @ 94 mph, 1.67 60' http://www.cardomain.com/ride/2686667 |
Oh damn I really need this! Killer give away.
www.cardomain.com/id/njws6 1989 TTA - 19K Miles - PT61, Mototron 60's, Hot wired Walbro 340 in tank fuel pump, 160 Thermo, ATR Downpipe, ATR Cat-Back (No cat), Scanmaster, Turbotweak chip, RJC Power Plate, Turbonetics Wastegate, LS1 MAF conversion, Translator Plus 1986 Buick Regal T Type WH1 - 60's, PT52, RJC Plate, ATR DP, Turbonetics gate, Walbro 340 Hotwired, TurboTweak Chip. 1987 Buick Grand National - T tops. Stock. Needs resto. 1997 Buick Regal GS - Supercharged 1990 Trans Am GTA - 305 5 speed. 2002 Trans Am WS6 A4 -Heads/Cam/Nitrous 2002 Convertible Collectors Edition - Stock 1994 Formula - Mostly stock 1993 Trans Am - LS1 + Precision 101 Turbo |
1987 TURBO T Orig owner might sell 2006 IBM GTO 1 of 115 made
Shipping out today. Your Radiator top plate will follow in about 2 weeks.
Giveaway
Count me in!
87 GN, Kenne-Bell SS dual 2.5" exhaust, THDP w/dump, race Hemco with 62MM TB, AFPR, MaxEffort 8 position chip, ATR ram air kit, stock turbo, injectors & IC. 87 GN SS 2.5" exhaust, THDP, PP, vacuum brakes and ATR chip. Soon to be daily driver. Still sitting in the closet: Knock Detector Alarm, new Autometer Boost and Fuel Pressure Gauge and MSD ignition, TE-44, CAS V4, Razor's PAC Alky Kit, Tom Grant rear LC arm, HRPartsN stuff rear sway bar kit, Walbro 340 and hot wire kit, Hemco 70MM TB, Poly motor mounts, C-Clip eliminator w/ axles and lifetime car cover from Car Motorsports. The Way to salvation: Romans 10:9 - 13 |
my birthdays in May....would make a great BDAY gift
Owner of Royal-T [1987 Turbo T Limited] destined to run in the low 11's [in street trim] and be featured in a national publication •BEST so far 12.1x @ 112.9X• BEST MPH 114 ALL on 18" Toyo street tires - ZERO boost launch and full tank of PUMP gas - stock "109" block, stock heads, and lots of good stuff ALL MIXED WITH A LIL' ALKY
You guys do know that May of 07 was last month right?
1987 Buick GN - Lots of stuff, 11.51 @ 117 MPH 1.76 60' on Nittos! No cage so no 10 second timeslip... for now. 2001 Pontiac Grand Prix GTP Special Edition - It has a pulley and a lot of KR which is not my fault! 14.66 @ 98 MPH with a crap 60' <~~ WebmasterWant your transmission built right? Call the master BGN Registry #BGN00858C |
Apparently alot of people around here are on the slow side!!
'87 Turbo T with T Tops, new engine brought to life 11/14/05!! 212 roller, ported cast iron heads,TE61 turbo, Duttweiler necked IC, Hi-Z injectors, Commander chip, TH 3" DP, Hooker dump tube back exhaust, Precision Industries converter , trans and transbrake by Performance Transmission Las Vegas, (Thanks Len !) Best times as of 5/19/06: ET of 11.72, MPH of 118.55 ! now for some traction devices!!!!
Jim Seaton 83 T type (white) CarbedHotAir Slug ET 14.3 @ 94mph with only 14 psi boost and 2.0 60' 86 T-type mostly stock.."The White moon roof GN", TT chip,KB adj fpr, fullthrottle pump&hotwire, 50lbers, Razor alky.. 1980 C3 Vette...sucker for projects Comp Cams will not get a Dime of my money Customer Service, Principles and Integrity mean a lot to Me..Why isn't B4Black MOD anymore???? Removed link due to someone having nothing better to do, but complain to someone else instead of manning up to me. |
