Car painting Hep
Harbor Freight Tools - Quality Tools at the Lowest Prices
This summer I will be painting an old beater car pretty much for practice. It will be my first full car paint job. I am not expecting a great job heck I am not even expecting an ok job but I would likme some input as to which spray gun to get. I have seen them on harbor frieght from $15 to over $100. I would like to know how does these $15 guns stack up to the more expensive one? Can I get by with the cheaper one? What benefit will there from buying a better on other than its service life? Thanks for the help.
PT-67 (.63A/R, P-trim) 10" WestCoast converter 3800 rpm stall, CK Performance Transmission, Eastern FM, 3.5" Maf, Translator plus, 3" THDP, Hooker Cat back, 3" Flanged removable Cat, Mototron 60/65 lb/hr injectors, comp cam 206/206, Adj fuel reg, Extender Extreme chip, SMC Alky, Holley 255 LPH fuel pump hot wired, KN air filter, RJC power plate, Air bags, UMI Rear Lower control arms, Metco driveshaft loop, Eaton Posi, Poston's crossover pipe, Dual 11" Spal fans, Arizon GN Radiator, S-10 rear brake cylinders, Powerlogger and Scanmaster II |
My buddy bought an airgun from HF awhile back. HVLP (the purple handle one with white bottle). It was on sale for like 30-40 bucks (normally about $80?). JUNK. Do yourself a favor, if you're going to use the gun more than once, buy a good one. And after watching my friend struggle with that one, I'd recommend even if you're going to use it just ONE time (as he did), still don't buy it. It wouldn't hold the adjustment for more than 5 minutes at a time (= lots of wasted paint + time & aggravation). He said it wasn't even worth "practicing" with (it's hard to learn how to do or use something when the variables keep changing!). You have to be careful buying stuff from HF, some of it is real garbage. I've bought a few things from there, but mostly for "one-time use" projects.
Richard Clark's Open House Event Pics: http://buickturboregal.com/richardclarkevent.html My Wild Ride in Buick GNX #500! http://www.buickturboregal.com/buickgnx500.html http://www.crazy-car-videos.com/grandnational Videos of cool Grand Nationals! http://www.BuickTurboRegal.com information & photos of ALL the Turbo Regals! http://www.GNcollector.com - a Grand National Collectibles website! Collectibles BLOG: http://buick-grand-national.blogspot.com |
for my very first gun i got a grav feed hvlp sharpe sgf98 off of ebay years ago for about 200 bucks new. it still works great still too. you just have to clean them every time you are finished, and they will last. you can still find a decent gun for pretty cheap there too. stay away from those cheap guns, i bought one to spray an epoxy sealer once and it was garbage. the pattern was inconsistent, and the flow sucked. if you are painting the beater to practice, prep is the key, it will determine how your paint ends up. practice on a junk fender first, to learn how to adjust the pattern and flow. also, get a respirator with cartridges for paint, modern paints are way more toxic than the enamels of the old days. you can find a disposable one for like 20-25 bucks from 3m.
72 cutlass supreme(almost 455 powered) 71 chevelle (winter beater) 68 firebird with a RAIII 72 cutlass s 70 mustang 351w 71 camaro (totaled, looking for a new body) soon to be a TR in here.. |
The crappiest gun you should even consider for running the top coat through is the $99.00 Gravity Fed HVLP Sears gun.
Primer can be shot through a crappy gun though, hard to mess up primer. I still wouldn't recommend it, but I see you are on a budget and looking to learn (I guess.) Buy yourself 2 guns, the $50.00 one (Primer) and the $99-129.00 gun for your Paint.
Brent 1984 WH1, 87 drivetrain, 204/214 cam, AFR, Walbro 340, hotwire, 60# inj, Razor Alcohol Inj, RJC powerplate, stock turbo, gbodyparts stock location stretched I/C, 3" gbodyparts downpipe & test, 2.5" Hooker exhaust, TurboTweak alky 93 chip, Pats 2800 stall, (times and turbo pending) |
If it was me I'd invest the money and go with the two gun beginners set from Eastwood. I think they have a special on the $129 set for $99. If you are like me you'll want to do more projects after you get the hang of it. The HF guns are okay, they just wont last 5 years like the name brand stuff.
Eric Fisher OEM Parts Specialist at GBodyParts.com 252-332-8787 1997 SCCA Regional Champion. 1986 Grand National #38 ESP 86 Grand National 84 Riviera T-Type 82 Regal engineless |
| Painting my GN soon | Studmonkey | Turbo Lounge | 7 | March 3rd, 2007 10:04 AM |
| Painting | canadianregal | General Turbo Buick Tech | 5 | February 10th, 2006 06:19 PM |
| Painting over POR-15 | 84GNTTYPE | Show Car and Restoration/Body Repair | 2 | December 28th, 2003 11:50 PM |
| Painting a GN | TRBON8R | Turbo Lounge | 0 | April 11th, 2003 06:21 PM |
| Painting GN | V6POWER | Show Car and Restoration/Body Repair | 8 | January 13th, 2003 04:00 PM |
