Old July 1st, 2006, 07:15 PM
GDNF2ET's Avatar
Dash vent help needed
Until I can sort out why the air blows out the defrost and floor, but NOT the front dash vents, what position do the 2 flaps have to be in to blow out the front vents ? I'm not interested in the vacuum solution at this time....
Tracy... 83 Monte/GN pwrd ....87 T, all stock....93 Talon, AWD, AT
Old July 1st, 2006, 07:49 PM
Not what you asked for, but -
the default position when the vac. isn't working properly is to blow the air out of the defraust vents.
The floor vent flapper originally had some foam stuff on it that made it seal. I gave up on mine and covered it with duct tape.
Sorry I'm not more helpful.
Good luck.
Old July 2nd, 2006, 11:57 AM
Cool
check the vacumn hose behind the coil pac.had the same problem.
gray 87 t with t tops k@n hooker exhaust walbo 340 pump ta49 turbo 60#motrons smc pac alcy trans plus70 mm tb delta gate downpipe all new body bushings springs shocks hr bar tt chip
all work performed by
FREDS TURBO PERFORMANCE
229-794-2337
FRED TOOK MY STOCK CAR AND MADE IT A STREET
CAR TO BE PROUD OF.THANKS FRED AND KAY
Old July 2nd, 2006, 07:52 PM
darkred87T's Avatar
Also, the vacuum diaghram for the vent doors is under the dash on the drivers side mounted on the heater box. You can check there to see if you have vacume to that point. Vacuum is how it operates, unless a door is stuck?
1987 Regal T. Dark Red Metallic w/ Burgundy
GT3255, #60's, LS1 MAF, Translator +, CAI, Walbro 340 hot wired, Ramchargers dual fans, 3" THDP, 2 1/2" Hooker cat. back, CAS V4, PAC, RJC power plate and boost controller. 12.0@112
Old July 3rd, 2006, 01:03 PM
GDNF2ET's Avatar
I popped out the 2 center vents and put a stick inside to prop the door open..I found a handful of cracked hoses under the hood ...Its been in the upper 90s the last couple days..I will do it right real soon..
