Old April 23rd, 2006, 07:07 PM
kshef's Avatar
275 radial or 235 DR..which tire hooks better?
trying to decide which tire to run in TFS
275 regular radial
or
235 drag radial?
thanks
'87 GN stock turbo/intercooler 12.2@108
'99 Park Ave. Ultra, 13.8 @ 99.2, 4060 lbs.
Old April 23rd, 2006, 07:10 PM
255 MT drag radials? But to answer your question i would think the BFG 235s would outperform a normal 275 radial by a pretty decent margin.
11.255 at 121.5 (best mph:124.1)
87 GN, PT61, mototron 60#s .030 over, TRW pistons, ported and polished iron heads, with Manley 1.77, 1.50 valves, ported intake, 204/214, ATR headers, 2.5" exhaust, 3" ATR DP ,ebay fmic, moser axles, LT1 MAF, fuel mods, home built billet tranny and a 3400 CK 10.5. air bags and umi lowers CAs ATR rear sway bar, PAC alky kit, 1LE 36mm front sway bar, QA1 economy coil overs, Howe longer ball joints,bilsteins, Richmond 3.23s, eaton posi, ls1 brakes.
Dads 86 GN-ported heads, 204/214, ATR headers/exhaust, PT61, 60s, alky, 3400 9/11, ebay front mount (supporting mods...) 11.42 at 124.13mph 24 psi.
modded 85 GN and now a new 87 T.
Old April 24th, 2006, 09:50 AM
Black Car's Avatar
Why not 275x60 or 275x50 size in DR?
Gary
Old April 24th, 2006, 03:09 PM
I was here first
Gary
Max size DR allowed is 235.
Use the MT radial
Mike
www.fullthrottlespeed.com
Tech:www.fullthrottletech.com
Home of the FASTEST hydraulic roller cams for Turbo Buicks
___________________________________________
Disclaimer:
The poster does not take any responsibility for any bad feelings or sense of exclusion that the reader of this post may have-whether real or imagined. Reading threads poses inherent risks. The poster of this thread would like to also remind readers to make sure they have a functional sense of humor and a brain before they visit any discussion board
Old April 24th, 2006, 11:32 PM
ttypenssrider's Avatar
If Both Are 60 Series Tires Then 275 "should" Be Better Because Of A Wider Contact To The Ground Then The 235, But The 275 Are Taller And May Hurt Top End,it All Depends On Your Combo.
I Personally Will Be Getting The 235/60/15 M/t Dr's, Its Better Suited For My Combo And Stock Wheels.
Old April 24th, 2006, 11:35 PM
GEEZ I JUST NOTICED ITS RADIAL VS DRAG RADIAL,SO I WOULD THINK THE DR'S WOULD STILL HOOK MORE.
Old April 25th, 2006, 06:51 AM
Buick "RICER"
Trader Rating: (14)
Drag Radial hands down
Dan
Old April 25th, 2006, 07:51 PM
I run the M/T DR 235 and they hook great. Regular radials have no chance in this comparison.
86 G.N. 56k miles
50# injectors, te44 turbo, Alkycontrol.
3" mease dp.w/3 in. S.S. singleshot,rjc plate,
11.88@ 112. mph.60" 1.62
235 Mickey D.R.'s
Old April 26th, 2006, 08:46 PM
Dr's. The new MT hook great.
Jason
Old April 28th, 2006, 09:03 AM
A "taller" tire should improve top end, if by "taller" you mean physically taller, as in a larger diameter.
Old April 28th, 2006, 09:08 AM
Ive got BFG 235's drag radials and they work good for me on street and strip. I personally dont like taller tires. Also check out the Nitto 255 Drag radial is also nice. Regular radials dont cut it if you want traction on the street and like to play.
Old April 28th, 2006, 09:18 AM
WakkoSS's Avatar
I love the 275/60 Nittos on my car. I did have to roll the lips but the highway gearing is a tad better and they grip like crazy. The 275/50 also looks pretty badass though...but will probably also require a lip roll.
Ian -
989ci
