personal best ET
hey guys went to the track tonight and run my car and got a personal best
![]() 1.64 60ft 7.66 ET 89.5 MPH @19 psi i wanted to turn up the boost but something was preventing it from going up i put 5 turns in the wastegate rod and nothing still the same lol ![]()
http://www.turbomalibu.com/1SloGN.htm best time slip 1.55 60ft 7.20 / 95 mph @ 22 psi |
Good run on the low boost there man, a little more boost and timing and mid 11s will be cake
11.255 at 121.5 (best mph:124.1) 87 GN, PT61, mototron 60#s .030 over, TRW pistons, ported and polished iron heads, with Manley 1.77, 1.50 valves, ported intake, 204/214, ATR headers, 2.5" exhaust, 3" ATR DP ,ebay fmic, moser axles, LT1 MAF, fuel mods, home built billet tranny and a 3400 CK 10.5. air bags and umi lowers CAs ATR rear sway bar, PAC alky kit, 1LE 36mm front sway bar, QA1 economy coil overs, Howe longer ball joints,bilsteins, Richmond 3.23s, eaton posi, ls1 brakes. Dads 86 GN-ported heads, 204/214, ATR headers/exhaust, PT61, 60s, alky, 3400 9/11, ebay front mount (supporting mods...) 11.42 at 124.13mph 24 psi. modded 85 GN and now a new 87 T. |
thanks
also on that run i had timing set @ 21/21 leaving with 8 psi @the line
