Old May 4th, 2005, 08:34 PM
My cars suck
How to pull a TR engine in new GMHigh tech...
Is it just me or did they not make mention of actually removing the bolts HOLDING THE ENGINE IN THE CAR!! And did anyone have to remove their fan to pull theirs, cuz I didn't. And where they put their chain is going to tear up the valve covers pretty good. Rookies.....
2002 Z28
757 rwhp on pump gas
Detuned to 730 rwhp for safety. Or something.
1997 Viper GTS. Its stock.
Old May 4th, 2005, 09:04 PM
Tom Tom Turbo's Avatar
Turbo Goes Woo Woo
Rookies....well then I will call ya up when we pull mine and get some tips from a pro Sam! I'm not gonna be able to make Parkland on Saturday, it is my sister's b-day, so we have crap to do. Good luck!
86 WH1 T Type: fresh short block, ARP studs and hardware, ported big valve o-ringed heads, ported manifold and headers, 206 billet roller cam, T&D 1.55 rockers, SpeedPro roller lifters, 3" THDP, 3" ATR single shot, PT54 turbo, big neck stretch stock location liquid intercooler, 50# MSD injectors, SMC progressive alky, 3200 Precision billet converter, Jimmy's Level 2 trans, Moser 31 splines, Auburn Pro diff, Moser girdle, full UMI suspension, 17" SLP ZR1 wheels, Weld Draglites on ET Drags......the list goes on!
2002 Z28: Sebring Silver, Hooker LT's, ORY, Corsa Sport exhaust, Strano springs, swaybars, Panhard rod, LCA's and 35th anniversary SS wheels
a few more toys......you'll see them someday!
Old May 5th, 2005, 12:31 PM
NCTURBOS's Avatar
All Appears OEM!!
Re: How to pull a TR engine in new GMHigh tech...
I haven't seen the article, and I don't tear up anything where I put the chains. But... there must be a better way to attach the chain from what I'm doing to make it easier.
Any photos of the easiest way to do it? I thought I saw a photo of a plate bolted to the top of the intake where the plenum would be?? That seems like it would be hard on those threads in the aluminum though!?
K.
NCTURBOS
If You See One of These...
Turbocharged Drivability & Performance!!
In-House Cylinder Head Porting & Computerized Flow-Bench Testing!!
'87 Turbo-T
Sage Green "1 RARE T"
'00 H-D Heritage Softail
S&S 106cui., etc.
'02 2500 24v CTD
Patriot Pearl Blue, 2wd, A/T, QC, BHAF, MIA silencer ring, J-Hook, 5" MBRP, DSS, MITUSA, Smarty, Redline box...
**FOR SALE!!**
Old May 5th, 2005, 10:17 PM
DCVING 6's Avatar
Re: Re: How to pull a TR engine in new GMHigh tech...
K.
According to the article, they attached the chain to the drivers side rear stud for the exhaust manifold.
Glen
1986 GN- Garage Art.
Old May 5th, 2005, 11:46 PM
re-evaluating's Avatar
Can't even re-member
Thumbs up Much better way
Here is the best way I have found to pull the motor. I have been doing this way for over 10 years and no scratching anything. We sell the straps at HR too..
Dave England
Gold 87 T TSM 9 second stock block madness
2004 TSM Points Series Champion
Brought to you by HRpartsNstuff,
TA Performance Racing Engines,
Hartline Performance
Old May 6th, 2005, 08:42 AM
NCTURBOS's Avatar
All Appears OEM!!
It looks like the strap loops under the intake, correct??
K.
NCTURBOS
'87 Turbo-T
S&S 106cui., etc.
'02 2500 24v CTD
**FOR SALE!!**
Old May 6th, 2005, 10:31 AM
Thumbs up yes under the intake
Yes it goes under the intake inside the fuel rails has good balance as you can see. I take it out with everything intact including the fuel lines turbo everything.. Much easier to do all the assembly on the engine stand..
Dave England
Old May 6th, 2005, 11:23 AM
My cars suck
Tom, if I can find time I can help pull your engine. Its pretty easy.
I like the strap too, but never seem to have it when I need it. I use chains and never hurt anything, but I use common sense and place them where they don't rub. Usually in the front/back of the head or intake bolts, depending on the level of completion of the motor.
Also they should make mention that every engine picker I've ever seen doesn't have enough throw to pick the engine straight up. My custom one does, but I've used others and while they do work, you gotta be careful when it snaps loose of the mounts and goes forward.
2002 Z28
Old May 6th, 2005, 01:09 PM
You're right about the average cherry picker not being able to reach...at least from the front...that's why I did my last few pulls from the side....works great...
Scott
87 GN - Street/Show Car (orig owner - 41K miles)
87 T - Street/Race Car(10.46 - 131.68 MPH) - TSM setup
Old May 6th, 2005, 01:42 PM
My cars suck
Yeah, I tried that but I would have to pull the wheel off, and my one jack was being used to hold the tranny up. The great thing about yanking these motors is they are very light, so they are easy to manhandle, and theres so much room in front its not going to hit anything.
2002 Z28
Old May 7th, 2005, 07:07 AM
TurboIndian's Avatar
worlds quickest 6cyl bird
K.
there are SEVERAL companys out there that make a plate that bolts to the aluminum intake, I mean for big blocks. I see what you are saying, but this practice is done all the time. but for another note I'm going to my local sling manufacturer on monday & having one like Daves made up! that's slick!
get your kicks with a little V6
67 Pontiac Firebird stage II power
99 Corvette coupe 6 speed
03 VW GTI VR6 6 speed
99 Western Star Detroit powered
06 GMC D'Max Allison 4x4 dually
