yea, had them work on my car a few years ago. a bit pricey, and there crooks. there are better people out there. do a search on these guys.
87 turbo t, new engine 40 over,delphi 50s,jim testa chip, ta 60 ,esp front mount, dynotech trans, protorque 10 inch converter, terry houston down pipe, 2 and a half hooker exhaust, ported plenum,power plate , ,champion ported irons and ported intake, razors progressive alky, best et{11.688 at 117 0n pump gas } |
I don't know much about them. But lets put it this way. When I got my TTA I didn't know a whole lot yet but I knew the car was acting not as it should. For one, boost would NOT go above 16lbs. After I went through it, doing nothing but replacing vacuum line connections and the plenum gasket and a couple other loose ends. After that I instantly without touching a thing saw 20lbs.
Come to find out after taking apart a bunch of things down to the plenum that there was alot of crap work done. I went through all of the things I got when I bought the car and had some Stage 1 receipts. The work they performed on the car indicates they as well would have had to take apart, down to the plenum on the car. And all of the screw ups that happened would have happened while reassembling. I discovered many vacuum line connectors that were way too big to fit over the metal lines securely, causing them to come right off under boost. Also when I took apart the plenum someone had NOT scraped all of the old gasket off, looked like they just pulled off the old one and left what was left, and then just slapped a new one over it. Creating one hell of a bad seal i'm sure. Also one of the screws was not tight when I went to remove it. Great. Also some other screw ups I can't quite remember right now but after just fixing these screw ups the car was running beautiful. I'm not saying I know for certain they did the work. So this post is not to say, stay away they do crap work! Because I don't know for certain. But those are the facts I know. You can form your own opinion. I've got mine. ![]()
www.cardomain.com/id/njws6 1989 TTA - 19K Miles - PT61, Mototron 60's, Hot wired Walbro 340 in tank fuel pump, 160 Thermo, ATR Downpipe, ATR Cat-Back (No cat), Scanmaster, Turbotweak chip, RJC Power Plate, Turbonetics Wastegate, LS1 MAF conversion, Translator Plus 1986 Buick Regal T Type WH1 - 60's, PT52, RJC Plate, ATR DP, Turbonetics gate, Walbro 340 Hotwired, TurboTweak Chip. 1987 Buick Grand National - T tops. Stock. Needs resto. 1997 Buick Regal GS - Supercharged 1990 Trans Am GTA - 305 5 speed. 2002 Trans Am WS6 A4 -Heads/Cam/Nitrous 2002 Convertible Collectors Edition - Stock 1994 Formula - Mostly stock 1993 Trans Am - LS1 + Precision 101 Turbo |
>>>> Cottons Performance. Aggawam Mass. |
I know there's a few shops in within an hour of the NJ/PA border on the PA side, but I don't know any of them by name. Two that come to mind in central NJ that deal with TRs are Ron's Custom Auto inn Kennelworth, and Dynotech in Manville. I have delt with both shops and have no complaints about either one.
Big Dreams, No Cash, but a whole lot of Creativity mixed with a little bit of Stupidity! 87 Grand National - TE-61,Big Mouth Cold Air, LS-1 MAF, RJC Power Plate, 72lb Inj,Ported Irons, Comp 212 Roller, ATR Double Pumper, Big neck IC, Progressive Alky, Mease 3" Downpipe, Test pipe w/dump, ATR 3" Crossflow exhaust, Trans+ and Extender Extreme, Pro-torque 3200 converter, Nitto DRs On the injured list .....Be back in the spring with a new 109 stroker. 06 TrailBlazer SS - Stock.....................For now. So far she's gone 12.56 at 110.3 mph @17psi in Street Trim, 2.04 60 Ft. |
now, dynotech i would bring my car to. there good guys down there.
I've dealt with Dynotech ever since I bought my GN new, and have nothing but good words for them!... Got good advice and service from Fred Vetter back when he founded Dynotech, and now Eric Shertz has helped me a lot and I'm very happy with his work, and would recommend him to my friends GN owners anytime!! He also runs Hi-Pro transmissions and builds the most bullet-proof transmissions on the east coast for sure!!
Claude ![]()
1987 Buick Grand National 10.51 e.t. @ 129.53 mph 2002 Ford Thunderbird 2008 Ford F-350 "King Ranch" Crew Cab Dually Pickup 2006 Ford Five Hundred SEL 2001 Saturn SL2 |
dont know, i took 287 and it was about 10 minutes off of there. go to there website and you can get directions. easy to find
