60 Foot Times
About what 60' should the left front wheel come off the ground foot braking. It sure seems like I'm getting close.
Tommy Milner 87 GN Best to date 1/8th 7.46@92.25 1.63 60' PT-51, Stretch IC, THDP, 009's,3K LU converter, PP, air bag, DS,K&N, Hooker 2 1/2" cat. back, Walbro 307 hotwired and an old BG FPR |
I'm not sure either, i swear with a sway bar off and pulling only a 1.74 it felt awesome but i know it wasnt close
I think it all depends on the suspension setup. I've seen some cars pull 1.4s and not lift, yet I saw a 90/10 shocked malibu running a mid 12 lift the front left an inch.
11.255 at 121.5 (best mph:124.1) 87 GN, PT61, mototron 60#s .030 over, TRW pistons, ported and polished iron heads, with Manley 1.77, 1.50 valves, ported intake, 204/214, ATR headers, 2.5" exhaust, 3" ATR DP ,ebay fmic, moser axles, LT1 MAF, fuel mods, home built billet tranny and a 3400 CK 10.5. air bags and umi lowers CAs ATR rear sway bar, PAC alky kit, 1LE 36mm front sway bar, QA1 economy coil overs, Howe longer ball joints,bilsteins, Richmond 3.23s, eaton posi, ls1 brakes. Dads 86 GN-ported heads, 204/214, ATR headers/exhaust, PT61, 60s, alky, 3400 9/11, ebay front mount (supporting mods...) 11.42 at 124.13mph 24 psi. modded 85 GN and now a new 87 T. |
I had my rear sway bar out at one point and it would pull the left front wheel about 3-4" with 60ft's around 1.57-1.58.
It hasnt pulled the wheels scince but has gone a 1.47 60ft and is consistantly in the 1.47-1.49 range. HTH, Steve |
I've seen cars with 1.65's pull the left wheel an inch. Usually it was with the "shock" of the launch and it wasn't truly pulling and carrying the wheel.
UNGN My OOOOOLD Timeslips Page My OOOOOLD G-body Homepage 1986-87 Illustrated Parts Book Wil's Power Wheel Page |
Pulling "a" wheel is frame twist(not wanted).A real wheelstand is hanging the hoops on both sides.Besides who cares if you pull a wheel or both as long as you run the #s.Sure it looks cool,but you might not be going straight when a wheelstand comes down.True pro racers try NOT to pull the wheels,of course there are those that are known for their wheelies I.E. Jack Cotton.
BTW I know a guy who has an all stock motor with just injectors and a turbo that pulled the wheels up 6" launching at 25# and his 60' was in the 1.6s
TA perf. Motor built by ArizonaGN (Thanks Nick) PT76GTS,RJC intercooler,F.A.S.T XFI,Champion GN1 intake,83#,TA block and heads,224/224 solid roller,T&D 1.65 rockers,CP pistons,Total seal rings,ATR rods,Eagle crank,MSD billet dist.,7AL-2 ignition,PTC converter,TH400 w/T-Brake,ATR headers & exhaust |
without some very expensive mods to our cars (4 link, ladder bar, etc) it is difficult to keep the front wheels on the ground during hard launches.......not the best situation, but folks run some pretty salty 60' times with the wheels in the air
(like low 1.3's....)
Woody Basic TSM recipe 24 lbs boost |
