Old June 3rd, 2003, 03:01 AM
Signal 1 J-12
Torque spec?
What is the torque spec for the valve body on the 200?
TIA
Joe Reif Jr. Paola, Kansas
2008 Can-Am Renegade 800 CVT beast
2007 Harley Davidson Road King FLHPI SE 103"
2005 Chevy Silverado 3500...Bombed Oil Burner
1987 Turbo-T...light blue exterior/dark blue interior 84k miles
Chip programming by: Eric Marshall @ www.turbotweak.com
Meth injection by: www.alkycontrol.com
My email:pdq6cyl@midwest-connections.com
Old June 3rd, 2003, 10:25 AM
WE4's Avatar
WE4 WE4 is offline
TBcom Adm/Prayers NYFD
We use..
120 inch pounds......and this is critical...
WE4
Bruce
"WE4"
Bruce
***Now with Brand New East Coast facility in Burlington, North Carolina***
***And still on West Coast in Wilton, Ca.***
"The 1 and only Original Performance Transmissions"
Northern California Turbo Buicks
Really Just a Turbo Buick Boy at Heart
#12 Ryan Newman Alltel Dodge Fan
Turbobuick.com admin
Old June 3rd, 2003, 08:27 PM
HOTTOGO's Avatar
Never Enough!!!
Re: We use..
WE4
Bruce
and you should see the fancy (expensive) torque wrench he uses too. You would see just how critical it is!
Mark
97 Eagle Talon Turbo TSi AWD
pic's of my '86 Monte SS
'86 Monte SS 355ci. modified ZZ4 375HP @ 5250rpm & 420 ft. lbs. torque @ 3600rpm, Hypertech Chip, Flowtech Ceramic Coated Stainless headers, crossover pipe, 2 1/2" FlowMasters, "Strengthened" CZF 2004r, 4.10 gears, Auburn posi, Energy Suspension upper/lower control arms and trans mount, Brute Force u-joints. 13.44, in street trim.
'89 IROCZ Camaro 5.7 TPI, 700r4 w/mods, Hypertech Chip, Crane ignition system, Cold air induction, air foil, Headman headers, 3" Random Technology high flow cat, Sonic Turbo muff w/2 1/2" tailpipes. 14.39, 1/4 mile.
Old June 3rd, 2003, 08:58 PM
chris718's Avatar
Supporting Vendor
120c inch lbs is correct .also after torquing bolts in sequence from the center out it is also good practice to loosen them and retorque a second time after 20 minutes.youll be surprised how much more the bolts crank up .also we test all our transmissions in a car before we ship and we remove the pan and retorque the bolts while hot before pulling trans down to ship.once again youd be surprised .it is also good practice to do this when servicinfg fluid and filter.
www.ckperformance.com
Old June 3rd, 2003, 10:21 PM
Signal 1 J-12
What symptoms might be indicitive of those bolts being too tight or loose? Is that valve body gasket re-usable??
Signal 1 J-12
BTW, what does that torque spec convert to in foot pounds?
Old June 4th, 2003, 09:51 AM
Where's your sign?
Since there are 12 in. per foot; 120 in-lbs = 10 ft-lbs.
But that is too low on any ft-lb torque wrench I've ever seen to be considered accurate or reliable. Beg, borrow, or buy a torque wrench with no more than 300 in-lbs to do this correcly.
If time is not an issue try eBay. I've seen several brand name TWs go very cheap--not Snap-On, though.
Old June 5th, 2003, 08:26 PM
HOTTOGO's Avatar
Never Enough!!!
The bolts being too tight can cause valves to stick causing several problems and too lose leaks and thus the same problems. It's rare that the gaskets don't stick and tear, but even if the don't I wouldn't re-use them, too risky for the price and trouble.
Mark
