Old April 24th, 2003, 08:12 PM
S10xGN's Avatar
Finally Roadworthy!
Swapping Governors...
Hi All,
I've got a gov from an '85 MCSS (CQ tag), if I stick it in my 87 BRF tranny, will it raise the shift points? I'm looking for 5700 plus or minus a hundred and don't really want to modify (read: destroy) my stock BRF gov.
TIA!
* Russ Selkirk; Port Neches, TX -> GN powered S-10 <- 12.17 @ 115.6 on pump gas!
* * * * * * * * * * * * * Click HERE to check out my thermal-printed stickers page! * * * * * * * * * * * * *
* GN powered '96 S-10 fleetside * +.030 TRW's * steel caps * ARP studs * Comp billet 215°/210° roller * full-port iron heads
* JetHotted "Hayden" ported headers * 50# MSD's * "TurboTweak" chip * PTE 52 turbo * "Jay Jackson" 62mm throttle body
* CAS front-mount IC * "TurboMike" ported elbow: 3" downpipe: 3" DynoMax Raceflow * Walbro 340 * Vigilante 3400 converter
* B&M megastick * Ford 8.8" 3.73 trac-lok * Hoosier QT's * CalTrac bars * Razor ALKY * BsTC controller w/dual solenoids
* and a whole lot of custom-made pieces!
Old April 24th, 2003, 11:16 PM
chris718's Avatar
Supporting Vendor
listen up this governor will produce the same wot upshifts as the brf. if you dont want to risk hurting the governor drill a .055 hole thru the governor housing to slightly raise wot upshift points .drill righr thru into the area where the governor fits in out thru the other side.www.ckperformance.com
Old May 7th, 2003, 08:44 PM
S10xGN's Avatar
Finally Roadworthy!
Chris, sorry about the delay, I've been out of town. Are you saying to drill a "through hole" across the aluminum housing the gov installs into?
Old May 7th, 2003, 11:08 PM
chris718's Avatar
Supporting Vendor
yes.
