Old September 6th, 2008, 05:13 PM
Not as cool as LeeTompson
Is there a difference in the cases of a 2004r lock up and nonlock up?
Hey, My trans case is srored from the band piston failure. I need a new case. Is there a difference in the case from lock up and non lock up? Are they both still called 2004r. Thanks, Steve
Old September 6th, 2008, 05:20 PM
chris718's Avatar
Supporting Vendor
All 2004r transmissions were lock up from the factory and even when they are converted to non lock up the case is not modified.You arent talking about a 200 3 speed are you?If so there is a lock up and non lock up unit.The non lockers had a vent on the extension housing area.
www.ckperformance.com
Old September 6th, 2008, 05:30 PM
Some one today said they had a bop 2004r but then said it was a three speed. So I was not sure if I should buy it .
Old September 6th, 2008, 05:52 PM
chris718's Avatar
Supporting Vendor
There is a bop only 2004r case and a chevy bop comdo case.Either way if your engine is bop itll fit.
Old September 7th, 2008, 02:06 AM
Thanks chris. Do you know what the difference is in a brf case. If my internals are from a non brf can they be used in a brf???
Old September 9th, 2008, 09:47 PM
87Regal3.8SFI's Avatar
V6 on steroids
Hhhmm thought all 200-4R's were Chevy/Buick/Olds/Pontiac? No? What about the BRF 200-4R trannies our TR's came with? Do they have a Chevy bolt pattern also?
Old September 10th, 2008, 12:12 AM
JoaTMoN
BOP/Buick/Olds/Pontiac Housing & Unibell/Chevy/BOP Housing>
Old September 10th, 2008, 06:17 AM
V6 on steroids
So the unibell housing has the notch at the top of it?
Old September 10th, 2008, 07:28 AM
JoaTMoN
Pic on left is BOP housing/case with 6 mounting holes & 2 dowel holes.
Pic on right is Unibell BOP & Chevy housing/case with 10 mounting bolt holes & 2 dowel holes.
Old September 10th, 2008, 04:51 PM
V6 on steroids
Thanks. Were there any cars besides a Monte/Malibu/Elky that came with the multi bell 200-4R?
Old September 11th, 2008, 07:12 AM
JoaTMoN
Most all 2004R's I've seen have the Uni-Bell case. Some early 80's had BOP only. Saw a Pic a while back of an early 80's Chevy only case but can't find it now.
Old September 14th, 2008, 06:37 PM
V6 on steroids
Ok, just wondering if my BRF tranny has it or not....haven't checked, just figured they were all unibell up until now.
WTB: Non lock valve for 2004R 87LtdT Parts wanted 1 March 17th, 2008 07:33 PM
Difference in 2004R years? GNBeswick Transmission Talk 5 March 11th, 2007 08:07 PM
2 lock up street/strip 2004R`s (1 BRF & 1 CZ) brian Parts for sale 10 June 11th, 2006 08:40 PM
Lock-Up/NonLock-up Questions.... camino70 Transmission Talk 2 October 5th, 2004 09:44 PM
2004R weird sounds and won't lock up wanarace Transmission Talk 2 September 8th, 2004 11:53 AM
