Need help diagnosing trans problem 200-4r
I had my trans rebuilt a few years ago and it has worked great since then. But all of a sudden it shifts early and soft compared to before. I checked the fluid and TV cable and they both are ok. The trans seems to be fine otherwise,no noise,goes through all the gears(but earlier than b4),no flaring etc. It just won't shift hard like it was,before it chirped the tires very hard now it will not. It is going through the gears really quick compared to before when it would build some rpm before the shift. Now it feels like a stock trans. I'm hoping it's a stuck valve inside or the servo is stuck but not sure where to start.Please give me your experienced expert suggestions on what to do,I'm not driving anymore until I get this sorted out.TIA
Another thing I should mention. Before this problem started when in WOT in either 2nd or 3rd gear (not near shift points but in the middle of the gear) it seemed to disengage or slip for just a split second as if it was going into nuetral for a half second. It would quickly re-engage and break the tires loose and continue accelerating.
Dropped the pan last night,fluid looks ok but not optimal as it needed a change anyhow. There was a little black gunk on the magnet but otherwise the pan was very clean. Drove it again before this and it is definitly shifting earlier and softer than it always has. I'm trying to find a transmission gauge to find out what the pressures are,I will post the results when I get them. I am also considering just bringing the car to the shop that did the tranny in the first place. I'm not mad it lasted longer than I had expected anyways if it turns out to need a rebuild. This was a modified 4BQ trans with 2800 restalled D5 from my old 84 T. I have no idea what they did inside but it has held up to some abuse.My car seemed to hit a limit of around 112-115 in the quarter,maybe this tranny and convertor was holding me back some?
Sounds like it took a beating.
How many miles?
USAF POWER PRO Bang Bang Buick 87GN- GT3255E, Turbosaver, Razors PAC Alky, ESP FMIC, 3" THDP, TA Headers, 3"ATR Crossflow, TT chip, 38's, Pats 3k stall, QA1 r's front, UMI rear Ups(adj) & Lows, HR Bar. 03' G35 Coupe 5At, Blk on Blk, Leather, 18's, Prem pkg, Bose, JDM clears....wifes car 05' Harleys Wide Glide- Glacier White Pearl w/ EFI, Stage 1 & SE Pro Pipe, Chrome thunderstar wheels. FOR SALE Duece- Sunglo and Chopper Blue w/ EFI, Stage 1 & SE Double Barrel too much to list both bikes still have warranty till 2010.FOR SALE |
Only about 16k.any suggestions on what to check while the pan is off?
What level did you have the fluid in the pan when driving it? Middle part of the back and forth bends on the dipstick? Cavatation can cause flare or bad slide shift on the 2-3 from low fluid level
If they go back through it make sure at the minimum you have a bigger boost valve in the psi reg set up no smaller than .500.
Get the psi's and post em up first Then id take it back to em and see what they say, that mileage is to low IMO.
Based on the description you are giving it sounfds like the inner tv valve is sticking.Give me a ring and Iwill tell you how to try to free it up if that is the issue.631 218 1989
CRISTOFOROS KOKKONIS GM AUTOMATIC TRANSMISSION SPECIALIST www.ckperformance.com STREET,STRIP AND DRAG RACE TRANSMISSIONS,CONVERTERS,DRUMS ,SHAFTS ETC. |
| Turbolink diagnosing a problem | PaulRV6 | Scan Tool Tech | 0 | June 9th, 2007 07:19 PM |
| Need help diagnosing this problem | 86SS86LS | General Turbo Buick Tech | 4 | May 21st, 2007 04:36 PM |
| Help diagnosing brake problem? | FlaBoy | General Turbo Buick Tech | 1 | April 5th, 2007 10:20 PM |
| need help diagnosing trans problem | ez at nova | Transmission Talk | 11 | September 9th, 2002 06:09 PM |
| Diagnosing problem | Mr. T-Type | General Turbo Buick Tech | 6 | September 8th, 2002 11:38 PM |
