Old August 26th, 2008, 05:23 PM
trans fluid
What kind should I put in a newly rebuilt 2004r and how many quarts do I need including the torque converter?
Old August 26th, 2008, 06:38 PM
kenny's Avatar
No turbo, no care.
Dexron III, like 6 quarts. Fill it a quart over full.
85 El Camino, LC2 swap in progress
87 Turbo-T, organ donor
87 Turbo-T 440rwhp, 491ft-lbs (sold)
87 Turbo-T 324rwhp, 393ft-lbs (stolen)
Old August 26th, 2008, 08:37 PM
jpratt's Avatar
Ask the builder. I like Type F
Best run 11.621 at 121MPH
86 T Top GN, TA49, 60's, Champion ported iron heads, Champion ported stock intake, Vigilante 3200 5 disc "O" pump lock up converter. Brian Hofer trans. T&D roller rocker and Comp roller cam
Alky Control.
http://community.webshots.com/user/jpratt725
http://www.fquick.com/8uwav6
Old August 26th, 2008, 09:07 PM
TT/Ameasap's Avatar
Trader Rating: (8)
I like type f also. It does stink tho!
Old August 26th, 2008, 09:22 PM
Rodney87GN's Avatar
MONEY PIT
If it's a newly built (dry) trans you'll need around 10-11 quarts. I use Dex III, it's what my trans builder recommends.
87 GN - Head gasket: 1----->Me: 0
7.30 @ 94 mph, 1.67 60'
http://www.cardomain.com/ride/2686667
Old August 27th, 2008, 12:18 AM
Boost231's Avatar
What's An Intercooler
Trader Rating: (13)
DEC 3 like everyone said. make sure you fill the converter before installing it on the trans. as far as how much oil. depends on the pan you are running.
Just Another Slow HotAir
www.arizonagn.com
www.gbodyparts.com
www.rjcracing.com
Old August 27th, 2008, 01:30 AM
spidereyes's Avatar
I prefer type F and use it in all my cars with an auto trans. Dont belive the horror stories that it will hurt or ruin the trans, the only thing it will do is make the trans shift crisper or harder (depending on how you look at it) because of different friction modifiers in it.
Old August 27th, 2008, 09:22 AM
trans fluid
Thanks guys for the info
Old August 27th, 2008, 09:25 AM
trans fluid
thanks a lot guys for the info, anyone using any synthetic like royal purple?
Old August 27th, 2008, 08:34 PM
JoaTMoN
Trans Fluids
The Purple is pricey. Some are using Tractor hydraulic fluid with good results. Here's an old post with some Info.
Mobile 424 tractor fluid
Old August 28th, 2008, 07:16 AM
turbo nasty's Avatar
BOOST SUX MY WALLET
Just run plain ole dex.
USAF POWER PRO
Bang Bang Buick
05' Harleys
Wide Glide- Glacier White Pearl w/ EFI, Stage 1 & SE Pro Pipe, Chrome thunderstar wheels. FOR SALE
Duece- Sunglo and Chopper Blue w/ EFI, Stage 1 & SE Double Barrel too much to list both bikes still have warranty till 2010.FOR SALE
Old August 28th, 2008, 08:55 AM
i need to try that in my old trucks
Old August 28th, 2008, 09:33 AM
I use Lucas Semi Syn. in my race car. I use to fill my converter before installing until my tranny guy who builds a ton of tranny's for race cars said don't worry about it. It will fill up as soon as you start the car. Just put a little around the seal surface. He and another guy who builds PG for racers both say you won't do any damage to anything if you don't fill it.
I just had my old converter cut open after 10 years and they said it was still in great shape.
Old August 28th, 2008, 09:38 AM
jpratt's Avatar
That is great to know. But for peace of mind, I will continue to fill it up.
Alky Control.
Old August 28th, 2008, 09:48 AM
If I didn't get my tranny work and parts done for free I would probably still be filling the converter up as well.
Old August 28th, 2008, 05:18 PM
The converer is usually assembled with some small amount of assembly lube on the parts. They wil also fill up in seconds IF there is enough in the pan to fll them.
It doesn't need to be "filled" on install, but adding a half qt is good insurance, so they at least have some lube besides whatever they may have on assembly.
www.jakesperformance.com
What trans fluid to use and why ronbuick Transmission Talk 6 April 8th, 2007 03:41 AM
Trans fluid jpratt Transmission Talk 1 January 7th, 2005 04:58 PM
How much trans fluid? V6POWER Transmission Talk 2 April 29th, 2004 04:52 PM
Trans fluid capacities??? Dry trans buickrob Transmission Talk 1 July 5th, 2003 03:16 PM
Leaking trans fluid thanks to a stripped trans pan bolt d0n_3d General Turbo Buick Tech 6 January 4th, 2003 02:25 PM
