Old August 25th, 2008, 08:05 PM
555 Boost Valve
Can these valves be purchased from transmission part stores.? or are they custom made by one of our vendors?
Old August 25th, 2008, 08:09 PM
bison's Avatar
Long Duc Dong
Trader Rating: (23)
Custom made
Blue GN: Old combo 559whp/706wtq. New buildup to come with race ported GN 1 heads and intake .
Black GN:Stock 147k shortblock except cam ,KB 70 mm TB and plenum, ported irons 1.77in 1.5ex, RJC head gaskets, ported stock intake, 212-212 comp roller, 1.65 T&D's, RJC powerplate, 1" plenum spacer, 83 lb/hr injectors, double pumper, FAST XFI, G-Body FMIC, welded ported stock manifolds, 3.5 dp, CPT 66BB GTQ, PAC dual nozzle alky injection, Dusty PTC 9.5", 200 4-R by me with billet shafted forward drum, billet input, billet ring gear and planet. 8.5 rear with Auburn, 28 spline Moser axles, and LPW girdle. 10.29@133.46mph .Time with old combo (stock ecm, p-trim turbo, and loose converter) 10.88@126mph. Stage II coming soon .
Old August 25th, 2008, 08:24 PM
is the 570 recommended or will I have problems due to thin wall
Old August 25th, 2008, 09:22 PM
bison's Avatar
Long Duc Dong
Trader Rating: (23)
.555 is fine. PTS doesnt even sell the .570 anymore to my knowledge
Old August 26th, 2008, 07:02 AM
turbo nasty's Avatar
BOOST SUX MY WALLET
Yeah I just purchased the Psi reg system from PTS and mic'd the boost valve and its 555. Tho I found that the trans is on the verge of starting off in second with his entire setup so I put the stock rev boost in with his kit and all is well. Really firms up the 2-3
USAF POWER PRO
Bang Bang Buick
05' Harleys
Wide Glide- Glacier White Pearl w/ EFI, Stage 1 & SE Pro Pipe, Chrome thunderstar wheels. FOR SALE
Duece- Sunglo and Chopper Blue w/ EFI, Stage 1 & SE Double Barrel too much to list both bikes still have warranty till 2010.FOR SALE
Old August 26th, 2008, 05:02 PM
Hmm,
Interesting...
I posted on here a couple or three years ago about issues I had with the .570 boost valve having poor machining and too thin.
I guess maybe there were more issues with them than some would like to admit.
I haven't had issue with using the standard cheap .500 boost valves other than they need to be smoothed a little sometimes to be sure they work good hot.
www.jakesperformance.com
Old August 28th, 2008, 09:24 PM
chris718's Avatar
Supporting Vendor
We are making the .555 valves and they are produced on a screw machine which is the only choice for efficiently manufacturing small parts.Ihad a few hair pullers with the .571 valve assemblies cars showed up with at the shop.Jake,the diode is junk,FB is installing them in 350 .Not with good results from what it I have heard,the races are annealed ,turned re heat treated and ground.
www.ckperformance.com
Old August 28th, 2008, 11:11 PM
Good to see you around Chris.
I was wondering how tough the diode was because they are the preferred deal in the AOD world. I did that AOD awhile back and it's in the car and running now behind the 347. Works great!
I put the diode drum in it, I was just curious, with the ratcheting action, you would think it would see greater wear.
I'll post a new post up here for all builders input about the pans.
Jake
Old August 31st, 2008, 09:54 AM
chris718's Avatar
Supporting Vendor
towing without the driveshaft removed and the wheels on the ground will kill the diode in 10 miles in most cases.we use a super sprag from an e40d at that location.
TV boost valve 1985BuickGN Transmission Talk 3 August 27th, 2007 05:00 PM
TV boost valve "More Boost" Transmission Talk 11 February 13th, 2007 07:35 PM
RJC boost valve. Bobs rare 6 General Turbo Buick Tech 1 December 26th, 2004 09:18 PM
.400 1-2 boost valve where does it go TurboTA3.8 Transmission Talk 5 August 25th, 2004 10:43 AM
? on TV boost valve JDSfastGN Transmission Talk 6 November 25th, 2003 01:11 AM
