Old August 21st, 2008, 06:11 PM
S10xGN's Avatar
Finally Roadworthy!
Lokar TV cable on a Holley....
Hi All,
I'm building another swap, a carb'ed LS-1 with a 200R4 in a '72 Maverick. I'm mocking up the TV cable (Lokar) using the Holley TV cable actuator bracket (20-95?) on a #0-82751 750DP and the Lokar mount bracket. I'm seeing 1.00" of "pull" at the tranny end while sweeping through the entire throttle range, is that enough?
* Russ Selkirk; Port Neches, TX -> GN powered S-10 <- 12.17 @ 115.6 on pump gas!
* * * * * * * * * * * * * Click HERE to check out my thermal-printed stickers page! * * * * * * * * * * * * *
* GN powered '96 S-10 fleetside * +.030 TRW's * steel caps * ARP studs * Comp billet 215°/210° roller * full-port iron heads
* JetHotted "Hayden" ported headers * 50# MSD's * "TurboTweak" chip * PTE 52 turbo * "Jay Jackson" 62mm throttle body
* CAS front-mount IC * "TurboMike" ported elbow: 3" downpipe: 3" DynoMax Raceflow * Walbro 340 * Vigilante 3400 converter
* B&M megastick * Ford 8.8" 3.73 trac-lok * Hoosier QT's * CalTrac bars * Razor ALKY * BsTC controller w/dual solenoids
* and a whole lot of custom-made pieces!
Old August 23rd, 2008, 02:16 PM
S10xGN's Avatar
Finally Roadworthy!
Not even in Chris's Book?
Should I be concerned? Is there even a "dimension" for this ? ? ? I'm unable to find anything other than diagrams for the carb end. Nothing on "length of cable pull" at the TV valve...
I'd be appreciative if someone could mark and measure their cable pull on a typical GN throttle body setup!
Old August 28th, 2008, 09:25 AM
S10xGN's Avatar
Finally Roadworthy!
Nevermind, I'll figure it out when the time comes (along with 1,000 other things). I'm getting too old to try and remember all this stuff anyways...
Old August 28th, 2008, 09:31 AM
Too many words! Haven't read it yet, but your answer may be here:
CptTransmission.com Performance Transmission, Racing Shifters and Torque Converters
Old August 28th, 2008, 03:31 PM
1 7/16
Jim
77Monte 385 SBC 200-4r
Old August 28th, 2008, 05:32 PM
Art carr said it should be exactly 1 1/4 of throw.No more and no less.Here is a link to his website explaning it.CptTransmission.com Performance Transmission, Racing Shifters and Torque Converters
86 t type,6157 turbo,msd 50s,hotwired 340,3" dp ported elbow,comp 260 cam,rjc power plate,smc alky,speed pro forged pistons .30 over,mild homeported heads,pypes exhaust with testpipe,f body rad with ramchargers fan,3200 9.5 stall.Best 7.59 At 89 mph in the 1/8 on bfg drag radials.
Old August 28th, 2008, 10:04 PM
JoaTMoN
Do you have the Cable geometry corrector for the Holley?
Old August 30th, 2008, 10:44 AM
BTO TV made EZ kit
Len Barron
67 Camaro SS-350 Convert.
406SBC/200-4r/12Bolt 3.73 Truetrac
Len's 67 Camaro PT Garage
Old August 30th, 2008, 11:36 AM
Originally Posted by LCAC_Man View Post
BTO TV made EZ kit
Thats what I use on my GSX.
Doug Gorton
70 GSX
87 GN
73 Ski Nautique
Old September 3rd, 2008, 02:30 PM
S10xGN's Avatar
Finally Roadworthy!
That's the bracket I have. Since I only have 1.0" of actual cable travel, I will use the pressure setting method when the time comes.
Thanks for the replies,
4160 Holley help? jcawley3 South Eastern Area 2 April 27th, 2008 07:23 AM
TH400 Lokar trans dipstick SIXBANGR Transmission Talk 0 November 21st, 2007 08:47 PM
Holley TPS...USE IT camaro75racer Hot Air (non-intercooled) Tech 0 July 7th, 2006 04:13 PM
FS: New Hurst Quarter Stick, Lokar Dipstick/Kickdown Kit TurboTA3.8 Parts for sale 8 February 4th, 2005 03:48 PM
holley tps sensor 85 ttypewh1 Hot Air (non-intercooled) Tech 1 July 26th, 2004 02:01 PM
