Old June 4th, 2008, 10:20 PM
Whats the risk of a hard parts breakage wreaking the converter
Title pretty much says it. If you break a input shaft, the OD carrier, or the OD ring gear, What the chances of wreaking the converter as well?
Old June 5th, 2008, 07:46 AM
turbo nasty's Avatar
BOOST SUX MY WALLET
Problem is the metal pieces that get in the conv. If its a l/U then the metal could get embedded in the lining and then as it wears release it into the fluid and block valves and passages.
Also the convertor has to be cut open to be cleaned out.
USAF POWER PRO
05' Harleys
Wide Glide- Glacier White Pearl w/ EFI, Stage 1 & SE Pro Pipe.
Duece- Sunglo and Chopper Blue w/ EFI, Stage 1 & SE Double Barrel.
Old June 5th, 2008, 10:48 AM
Always Look Forward
About the only hard part breakage scenario in a 200-4R that you might get away with would be when the intermediate shaft snaps with a clean, flat break. That's about it.
Donnie Wang
1984 BUICK Grand National with a baaad alcohol and nitrous chaser habit.
100% Methyl Alcohol Injected/Nitrous Oxide Assisted/Forced Inductions FI91X Turbocharged/TA blocked/M&A headed/DRW TH475 Transmission/Neal Chance Pro Mod Torque Converter/Moser 12 Bolt Rear Axle Housing
Warning: Do not try this at home without proper adult supervision.
Ultimate Stage I BUICK V6 v3.2
GN details
9.19@145 from a 224 CID
5.73@122.1 in the 1/8 mile. Latest best.
1.28 60 foot.
'Perseverence is the key to innovations endless possibilities and varieties locked within each of us.'
BRF Tranny with hard parts and Art Carr converter hwfstru Parts for sale 4 July 24th, 2007 08:33 PM
Turbo Thunder Parts Breakage geno Pacific Northwest Area 2 August 6th, 2004 12:36 PM
D4 converter??? Whats it from? T-Type Mike Transmission Talk 1 August 17th, 2003 07:55 PM
At the risk of seeming idiotic......... PrinzII General Turbo Buick Tech 3 August 29th, 2002 12:43 PM
Whats the best converter for a te44 Blkt6 General Turbo Buick Tech 10 July 2nd, 2002 05:11 AM
