Well, I tried re-adjusting the tv cable and now it dies when I shift into reverse!
1987 Regal T Stock turbo @ 22lbs, 55#'ers, adjustible FP regulator, Razor's Alky, TT chip, RJC Power Plate, RJC boost controller, cold air kit, ported stock elbow, 2.5 DP, hot wired Walbro 340 fuel pump, DirectScan, restalled D5, UMI rear suspension, and 275/60 BFG DRs. 1968 Pontiac Lemans |
I'm sorry for not being clear. Yes, the engine stalls out. Please tell me more about possible solutions if it's the TCC. Thanks for the reply. I do appreciate any help.
Could be a bad TCC solenoid, or brake light switch. Brake switch unlocks TCC when depressed. Do a search for Torque Convertor Solenoid ot TCC on here and see what comes up. There are easy ways too check it. Maybe unplug the plug on left side of trans or brake switch and see if it stalls.
I disconnected the plug, but it still stalls out on shifting into any gear. Now that I think about it, the converter never locked up with the previous tranny. I never do any highway driving, so it was low on my "to do" list. Will the converter lock up in first? I didn't think it was possible until 2nd.
Only in 2nd or higher. The hydraulic circuit in the trans is designed so there is no oil going to the lockup circuit in 1st gear so a stuck solenoid cannot lock the converter in 1st.
1987 GN, 2-1984 Hurst Oldsmobiles - one with 1987 GN drivetrain, the other soon to be. |
if you install a lock up converter on a trans with a non lock up valve in the pump itll stall like that .there is no oil to hold the clutch off.
CRISTOFOROS KOKKONIS GM AUTOMATIC TRANSMISSION SPECIALIST www.ckperformance.com STREET,STRIP AND DRAG RACE TRANSMISSIONS,CONVERTERS,DRUMS ,SHAFTS ETC. |
Ahhhh.... Thanks Chris. That's it. That never crossed my mind but I'm pretty sure that's it. Now what?!?!
pull out the trans and change converter
That's what I was afraid of. I was hoping I could put a paper clip and some gum somewhere to fix it.
I'm not looking forward to pulling the tranny again. Do you have a converter that you'd recommend for my setup? Thanks again for all the help to all.
This one would be real nice for your combo. Art Carr 3200 non locker F/S
**87 Buick GN** 109 block steel crank/mains Ported Irons roller cam/rockers Ported intake/acufab plenum PT front mount 70GTQBB 83lb injectors Razor alky Maf T Pro Fuel, spark and boost management LC-1 Wideband Tracking |
I Have A Few Art Carrs Like That As Well As Some 12 Inch Non Lockers.ill Give You A Ring Today.
| Rearend looks shifted ??? | PCP_58 | Brakes, Suspensions, Tires & Wheels | 8 | November 14th, 2007 02:25 PM |
| need orange govenor drive gear for tranny | turbo john FL | Parts wanted | 2 | September 25th, 2006 08:06 PM |
| John Ritter dies at aGE 54 and Johnny Cash dies at age 71 | 6pack | Turbo Lounge | 6 | September 13th, 2003 01:00 AM |
| Installed '85 GN tranny to replace my crappy station wagon tranny | Jeff | Transmission Talk | 2 | July 24th, 2002 08:34 AM |
| Problem: car dies when put in drive, Solution: new coil pack & module | Berman | General Turbo Buick Tech | 8 | June 14th, 2002 08:00 AM |
