LinkBack (1) Thread Tools Display Modes
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old May 14th, 2008, 10:27 PM
80 Vette with a 4BQ
TCC Electrical Question 350C vs 200-r4
My car (1980 Chevy Corvette) currently has Th350c (lockup) tranny. Lockup is controlled by a manifold vacuum switch, that then is connected to tranny, to lockup tcc.
When I install my 200-r4 (4BQ), will I only need to connect my electrical connector that is currently plugged into 350C, to new 200-r4 connector, or is there any wiring tasks that need to be done, connector changes, etc to get lockup to work as it did with 350C????
Old May 15th, 2008, 12:14 AM
jmd jmd is offline
the 200-4R connector is
A [12v from brake switch to TCC solenoid]
B [ECM]
C [not used]
D [from ECM ground to TCC solenoid]
I know the 700 connector is the same as the 200-4R but I haven't looked at my TH350-C in a long long long time.
Matthew
86 SS L69 w/86 LB9 EFI & 95 T56 w/mech. clutch linkage conversion/push clutch
87 SS Saddle tan interior conversion, 700-R4 for now; soon to be 200-4R again
Old May 15th, 2008, 05:55 AM
80 Vette with a 4BQ
So who would be the person(s) to ask?
Since the 80 does not have ECM, I am still kind of at a loss here. I would think with as many conversions that have been done to 200-r4, that there had to be some from Th350c's and the lockup issues that come with that conversion (if any).
Just want to be prepared when I bolt up the 200-r4
Old May 15th, 2008, 06:56 AM
jmd jmd is offline
I just thought of something. 1983/1984 SS Monte Carlo accepts a direct swap of a 700-R4 or 200-4R. No changes needed for lockup.
If the 1980 TH350-C has the same connector, I'd say you're good to go. Your vac. switch wire probably goes to D.
Got a svc. manual for the '80 or have you dropped the pan?
Matthew
Old May 15th, 2008, 07:24 AM
80 Vette with a 4BQ
Here is illustration from shop manual ... doesn't show anywhere what wire does what ..... I will confirm the connector, but I am pretty sure they are same.
Old May 15th, 2008, 10:39 PM
jmd jmd is offline
Talking
I knew the ~'80 GM models had peculiar parts like Q-jets with TPS but no ECM and non-ECM switched TCC circuits in the early 200-4Rs. But that's pretty interesting in the TH350-C how they made the TCC work based on speed vaccuum and temp with no ECM. I'm laughing here.
The bottom line is that your TCC is going to work off of the same voltage. They used that gov. pressure switch to avoid low speed lockup drivability problems. That could be accomplished in other ways such as a VSS source & a switching setup of some sort. If you're deadset against an ECM at some point I'd consider adding the gov. pressure switch to the 200-4R but I'm not the guy to tell you whether the 200-4R has a tap into that circuit. The rest of the wiring will work fine; short of perhaps a physically different plug and that's easy enough.
You truly learn something new every day.
Matthew
Old May 15th, 2008, 10:46 PM
Senior member
That TH350C probably has a blue connector, the BQ should have a black connnector, and the 700 uses a white connector. The black connector has the same pin setup as an IAC socket. The 700 is different and the blue is totally different from those as well. The little "guides" inside where the pins are will show you the differences.
Eric Ruybalid
SR Performance
GN-"Conquering masses in wanton deception"
http://www.hotairbuick.com/registry.htm
Old May 16th, 2008, 01:38 AM
80 Vette with a 4BQ
Removing TH350C & THANKS TO ALL YOU GUYS!
I am taking out the Th350C, hopefully get it done today (Friday) and will post what connector is actually on there.
BowTieOverdrives, says that they have a "External Wiring Kit" that they will sell me for $95 that you can lockup the TCC automatically in 4th, and manually in any gear. But I would lose Cruise Control & I wonder if it is any different than getting the B&M 70244 speedo sensing switch that would lockup at a set MPH, maybe 40-45mph .....
Or, just keep existing setup (possibly need to change harness switch, but don't think so as a vette buddy of mine did the conversion of TH350C on his 81 and it plugged right in - but hasn't been tested yet), and if up shift points are too early or late downshifts, I can just drive in 3rd gear in town, and only use OD when on the road?
Some of you guys are truly amazing on this stuff though - and I wonder that I would have done if it wasn't for the internet and this Buick forum ....... TOO DAMN
Old May 16th, 2008, 02:58 AM
80 Vette with a 4BQ
Just thought of something ELSE
Since I have a 4BQ valve body and it IS different from non-GN valve bodies that I have seen so far, in that my vb has TWO pressure switches, is that for 4th gear lockup or something totally different??
Here is picture, if that helps any .....
http://i244.photobucket.com/albums/g...0/100_0931.jpg
BTW - don't laugh too much, that stuff really did work, before I started tinkering
Old May 16th, 2008, 08:57 PM
gsgns4me's Avatar
For what it's worth, here are the wiring configurations for all 1987 model 200-4R's. Most other years are similar.
Dwayne Martin
Shady Spring, WV
Here's a few pictures
Old May 17th, 2008, 12:10 AM
Senior member
If you want to save yourself the $95, do like I do when I build one for non computer use. I run a 1 amp fuse from Key On source at the fuse block to "A" pin on connector to the positive side of the solenoid. Run the negative side of the solenoid to the 4th pressure switch and it will lockup automatically in 4th. You can interupt the ground side and add your own switch to ground and make it lock up when you want. Solenoid receives 2nd gear oil and has the capability to lockup at that time. Never had any problems in the last 20 years building them like this and I just don't lockup the stock type converters at WOT with this set up.
Eric Ruybalid
SR Performance
Old May 17th, 2008, 07:29 AM
80 Vette with a 4BQ
You The Man!
Now that is what I am talking about - you guys are great!
I have the lower left vb, with the two pressure switches ..... and planning on using an ACC 2800-3200 Street Bandit TC.
So I guess I will remove the lone wire coming down from my vacuum switch to the Th350C now? I think it must have 12v switched, but could be wrong!
I will send you picture of what that looks like when I get back to the house (& my own PC)
Old May 17th, 2008, 08:53 AM
80 Vette with a 4BQ
Current 350C wiring
http://i244.photobucket.com/albums/g...TCC80vette.jpg
I have a single wire coming down to 350C (into a dual pronged plug that obviously has to be changed to the 200-r4 4prong plug) ....
Then there are two pressure switches in vb (3rd & 4th gear) on the TCC solenoid on the 200-r4!
The brake switch disengages tcc lockup now, so I am thinking that the wiring harness should be able to be used ...... am I thinking backwards somehow?
Old May 17th, 2008, 04:50 PM
JoaTMoN
Here's a cheap place to get the plugs>
200-4R Switches & solenoids: Bulkpart transmission parts
Old May 18th, 2008, 09:18 PM
I think, therefore I am??
Okay, just to clarify: I can use the latter of your ideas here to just make a simple toggle on/off lockup switch, correct? What color is the wire for "pin A" (to run a switched 12V source) and and the ground (to run a toggle switch to ground) and you are talking about the plug at the tranny, right?
Thanks! Jay
Jay Jackson
http://hometown.aol.com/ygettv8/1index.html
--'87 Buzda... TA61, PI 7 disc, EP Front mount, ought to run!
--'87 WE4 63K ... heads/intake, TA62, CAS V-4 IC, 50# inj., alky, 62/65mm TB, Translator+, Mease DP, PI 9.5" l/u, Jimmy's Trans., best: 11.65, 116.2 mph, and 1.642 60' Gone, but not forgotten: RIP Andy
--'86 gray T-Type 94K... "YGETV8",11.755@117.89 stock long block & on pump gas! SOLD 6/03
--'86 GN "Beater"... stock combo 12.6@111.97 SOLD 8/02
--'03 Cobra, 11.2@128- stock... yeah, right!
Old May 18th, 2008, 11:12 PM
JoaTMoN
TCC 4th Only Wiring
This may or may not help you with your question. Hope it helps.
4th Gear Lockup diagram
Old May 19th, 2008, 02:21 AM
JoaTMoN
Wiring Color
This site has a diagram with wiring color also. It's kind of hard to read though. Schroll down about 3/4 of the page it shows a TCI* kit wiring.
700R4 Info Page 1
LinkBacks (?)
LinkBack to this Thread: http://www.turbobuick.com/forums/transmission-talk/250820-tcc-electrical-question-350c-vs-200-r4.html
Posted By For Type Date
Soleniod current requirements - Chevelle Tech This thread Refback August 28th, 2008 02:02 PM
Electrical question 85RegalLimited General Turbo Buick Tech 6 June 10th, 2007 08:13 AM
Electrical Question Boost231 General Turbo Buick Tech 6 September 27th, 2006 10:26 PM
Electrical question soundguy General Turbo Buick Tech 2 January 18th, 2006 10:25 PM
th-350c shift question. Yedi Transmission Talk 8 August 31st, 2005 11:12 AM
TCC question on a THM-350C... Freddie's Buick Before Black (non-SFI) Tech 11 October 25th, 2002 06:18 AM
