Old May 13th, 2008, 11:49 PM
Wait, so do you guys lock the converter through shifts?
I was talking to bison and I guess i should go re read what he was telling me, very knowledgeable person.
Anyways, it sounds like some of you guys lock the converter, and keep it locked through shifting?? I always thought you get into third, then you would lock the converter? Do you lock it up right after the launch or what?
Old May 14th, 2008, 04:38 AM
Trader Rating: (8)
Normally half way through second.
MODS: Some stuff
Old May 14th, 2008, 05:43 AM
TurboDave's Avatar
Cell Phone Doc
I wait for a second or two into 3rd. There prooved to be way too much bog at the 2-3 shift to lock in anytime in second. For avoiding the pitfalls of the huge 2-3 rpm drop bogging things down, you'd need to be making a lot more HP than I was and spinning something close to 6000rpm at the shift point.
I was only running mid 11's so it severely hurt my times and mph locking before the 2-3 shift. Maybe if the TCC clutch isn't 100% efficient it would slip enough to allow this. Unfortunately I'm running a 7 disc. It is very unforgiving at a 100% efficiencey when locked.
TurboDave EWCS(SW) USN (Ret.)
My Photo Gallery
Email Us
Sevierville, TN
TranslatorPro MAFless fuel, spark and boost management
86 GN(TranslatorPro/ExtenderPro on speed density w/boost & fuel pump control,PLX-WB) (original owner)
87 GN (second owner)
84 L69 Z28 (original owner)
01 Excursion LTD 7.3L PSD(Power Stroke Diesel), Turbo, 4X2
08 Honda Accord EX-L, 270HP 3.5V6, AT
Old May 14th, 2008, 07:20 AM
BEATAV8's Avatar
The Engine Whisperer
I only lock it in 3rd. Trans guy says locked shifts are a good way to break hard parts.
Steve
formerly known as MJRWOOD
87T
Old July 15th, 2008, 08:36 PM
Are all billet parts necessary for WOT L/U in 3rd. What about through shifts?
Thanks
Old July 16th, 2008, 12:08 PM
Thanks
Minimum I would use a billet forward drum.
1987 GN, 1986 T, 1984 Hurst Oldsmobile with 1987 GN drivetrain
Old July 16th, 2008, 12:23 PM
Buick "RICER"
Trader Rating: (14)
Thanks
depends on the power of the car .. mid 11 car we locked it at the line for YEARS .. now its making a little more power high 9s/ low 10s and we just lock it up once we are in 3rd oh ya.. we do have all the good parts in there now
Dan
Old July 16th, 2008, 11:44 PM
GNVYUS 1's Avatar
A.K.A. DR.BOOSTER
I literally got my car back from Jimmy's Trans and the guy in front of me snapped the input while locking in 3rd and it was a low 11 car.
So I got one and recommend it if you plan on locking it on 11's and lower.
Hey Dave do you have a before and after time slip from your track lockings?
I personally think the Precisions lock ups are a tad loose and the end of 2nd gear locking would help by 1mph over just third. I might try it if no time slip shows up about this theory and plan on shifting around 5600-5800.
Mike
87GN T-Top down 423lbs.
Rebuild #2, BLK/BL Paint w/Custom Metal Flares, VPE Stg 3 Heads, 210/215 Roller Cam, TA49, V2 w/Blitz Blow Off, Billet Drum/Input, PI 3400 5disc, T Brake, Inland 3.5" DS, KB Plenum/70mm TB, Razor's Post Turbo Alky Kit, Devils Preturbo Alky Kit, TT Chip, 60lb Inj, Denso 280 Pump,-8/-6 SS Fuel Lines, MBC, Pwr Plt, PTE Oil Relocator, Preluber, Z06 Maf, Translator, Volt Master, Poston Headers, THSS 3.5" DP/Test Pipe, ATR SS 2.5" Y Pipe w/No Muffs, PST 2" Drop, Poly Bushings, Boxed Upper/Lower Arms, QA1 Shocks, Vacuum Converted, Aerospace 11" Brakes w/SS lines, Alum Drums, Polished Autodrags 15x8/15x10, 275/60 Nitto 555Rs
Old July 17th, 2008, 03:12 PM
BEATAV8's Avatar
That was my Buddy Dave's car. DOH!
That thing locks up tight when it locks. Pulls it down hard!
I like my PTC non-lock though. Loose as a goose at the line but then it couples hard when you move. My 2-3 shift MPH went from 55mph with the Precision to +70mph with the PTC. And only 7.5% slip through the traps.
Steve
87T
any guys with art carr 9" non-lock up no-nos Transmission Talk 8 July 3rd, 2006 09:01 AM
Lock up converter??? TurboGN871 General Turbo Buick Tech 1 April 30th, 2006 10:29 PM
From lock-up to Non lock-up converter mytquick87 Transmission Talk 1 April 5th, 2005 07:21 PM
B&M lock-up converter TurboT231 Transmission Talk 0 November 3rd, 2003 08:51 PM
lock-up converter in non-lock tranny? 67turboCamaro Transmission Talk 2 September 17th, 2001 11:27 AM
