Old May 9th, 2008, 10:09 AM
BEATAV8's Avatar
The Engine Whisperer
1000+ RPM drop with PTC N/L on 10sec street car
I just love it when something works exactly the way you want it to.
Thanks Dusty
Shifted the 2-3 manually at 5950. Pulled down to 4900.
Spools up just fine on a stall test too. This converter does everything right.
(PS.. thanks to Bison too for recommending it)
Dog Slow Steve
The artist formerly known as MJRWOOD
87T
oh yeah.. the wife has one too. but hers is fast!
Old May 9th, 2008, 11:17 AM
Trader Rating: (10)
Cool. Looking forward to seeing the ET and MPH improvement over the Vig.
Are you going to BG? Or any local tracks anytime soon?
87 GN T63E, PTE FM, MSD 50's, Atr DP w/ext gate, ATR 2 1/2 duals, 5 disc Vigilante Jimmys trans HR sway bar 11.09@124.01 1.64 60' on Alkycontrol and 275/50/15 MT DRs TT chip
TTA#259 GT3255e, 50lb inj, RJC boost controller, THDP,MT DRs. 11.60@117.4. 1.61 60' Alky control TT chip. Jimmy's trans. 3200 Vigilante 5 disc LU
Old May 9th, 2008, 12:20 PM
TurboBob's Avatar
Mad Scientist
unhook the wastegate rod and do a stall test. Post the PL screen.....
The idea is to get a good idea of the zero psi stall. The tires must not turn or the test is not accurate.
Bob
Bob Bailey
86 GN 80K miles
Stock Engine, mildly ported heads, "Baby Roller" cam
PT6776RHP and PTE stock location intercooler
Translator Pro, PowerLogger, Scanmaster
Extender Pro chip, 60 lb injectors
BrianH Transmission and PTC Converter
Razor Alky
-------------------- yep, its pretty fast.....
Old May 9th, 2008, 02:35 PM
Suffers form priapism.
Trader Rating: (18)
Bob
The great thing about these converters is you can have both. Loose down low and tight up top.Very hard to achieve on a small cube turbocharged engine. Some great tech here with these and they are very affordable.
Blue GN: Old combo 559whp/706wtq. New buildup to come with race ported GN 1 heads and intake .
Black GN:Stock 134k shortblock except cam ,KB 70 mm TB and plenum, ported irons 1.77in 1.5ex, RJC head gaskets, ported stock intake, 212-212 comp roller, 1.65 T&D's, RJC powerplate, 1" plenum spacer, 50 lb injectors, double pumper, stock MAFS -1 screen, Turbo Tweak chip, DIY alky from 1998, G-Body FMIC, welded ported stock manifolds, 3.5 dp, T72BB P-trim, AC 9.5" 2800 stall, 200 4-R by me with billet shafted forward drum, 8.5 rear with Auburn and 28 spline Moser axles. 10.88@126mph. Stage II coming in the spring .
Old May 9th, 2008, 02:36 PM
Trader Rating: (18)
Thanks Dusty
These things just plain work.
Old May 9th, 2008, 02:40 PM
NCTURBOS's Avatar
NC Performance!!
I have (2) of these converters in cars here recently. One of them is in Atlanta at the "Pinks" event right now. I'm patiently waiting for a progress call... The 9/11 lock-up that came out just wasn't cutting it @ speeds over 123+mph.
K.
NC PERFORMANCE
If You See One of These...
Turbocharged Drivability & Performance!!
In-House Cylinder Head Porting & Computerized Flow-Bench Testing!!
'87 Turbo T
"1 RARE T"
'00 H-D Heritage Softail
Killer Klown Performance!!
'02 2500 24v CTD
Patriot Pearl Blue, 2wd, A/T, QC, BHAF, MIA silencer ring, J-Hook, 5" MBRP, DSS, MITUSA, Smarty, Redline box...
**FOR SALE!!**
Old May 9th, 2008, 03:48 PM
BEATAV8's Avatar
Bob
Here 'tis. 3190RPM. The SMC started to spray a little bit near the end and loaded it up just a little bit, but it was already flatline before that.
Dog Slow Steve
87T
Old May 9th, 2008, 03:50 PM
BEATAV8's Avatar
Is this quick enough spoolup for ya? click to watch movie.
Dog Slow Steve
87T
Old May 9th, 2008, 03:55 PM
BEATAV8's Avatar
I'll be at BG but just spectating and hanging out with you and Dave. My rear suspension is shot and I still have stock axles back there, so I have some work to do before she's ready. I'll be picking up a complete HR package from Paul Ferry at BG, and the axles / driveshaft are on the way too, so there is light at the end of the tunnel!
Dog Slow Steve
87T
Old May 9th, 2008, 04:09 PM
Trader Rating: (10)
I forgot. Dave said you were going to upgrade your axles and rear suspension.
The video looked good.
Old May 9th, 2008, 04:12 PM
TurboBob's Avatar
Mad Scientist
I was just wanting some fairly controlled tests to compare to my PTC 10"
Thanks guys.
(steve, email me that file, or post it)
I will try to do some of the same testing on mine.
Bob
Bob Bailey
86 GN 80K miles
Razor Alky
Old May 9th, 2008, 06:02 PM
Trader Rating: (18)
That graph doesnt lie. Looks like your going to have a real animal when you get your suspension issues worked out. Looks like your a little fat down low too. If you pull some fuel out it should help even more.
Old May 9th, 2008, 06:40 PM
BEATAV8's Avatar
Thanks
I try to run 11.0-11.3 AFR on the track. She pigged out on the stall test because the SMC started to spray (it's set to come on at 0psi when I'm running around on the street). The last pass was 10.70 @ 126 blowing through the Precision, and only 17 degrees timing. I can't wait to see what happens with the converter / suspension improvements and some more power.
I learned alot about torque converters from reading your posts! thanks again Bison
Dog Slow Steve
87T
Old May 9th, 2008, 06:48 PM
What turbo are you using? Exhuast Housing? ETC....
Matt Miller
Old May 9th, 2008, 07:34 PM
BEATAV8's Avatar
PT6776RH, P-trim with .63 housing.
109 block +.030, stock crank + rods, diamond pistons
Ported iron heads
210/210 comp roller
T/A headers
supporting bolt-ons
Dog Slow Steve
87T
Old May 9th, 2008, 07:46 PM
87NAT's Avatar
Addicted to Boost
I am not brave enough to footbrake my car to that boost level in my driveway...I would need some serious house work to repair the hole I put in the back of the garage.
I guess its time to put some brakes on my ole bucket.
Whats the advertised stall again? Was it a 2800 or 3200?
87GN GT6776bb, 206/206 roller, 60# inj, PTE Stock Loc. IC, PTC 10" 2800 Conv, Turbotweak, 93 octane & Alkycontrol
No track times with new converter/engine combo...yet.
Old May 9th, 2008, 08:11 PM
BEATAV8's Avatar
He he... the thought of driving through the house did occur to me. But I knew the brakes were in top form - I had to use them quite a bit this morning after jumping on it to get the 1st power logger file!
It's a 27-17. (that's the P/N referring to the number of blades on the goodies inside)
Dusty would have to tell you what it might stall at on your combo.
Dog Slow Steve
87T
Old May 9th, 2008, 08:12 PM
TurboBob's Avatar
Mad Scientist
Ported iron heads
210/210 comp roller
T/A headers
supporting bolt-ons
sounds like what I want to build,
caps or girdle?
I took a look at your file, it looks like 2900 at 0 - 1 psi. Sounds like it spools well....
Bob Bailey
86 GN 80K miles
Razor Alky
