Transbrake??
Since I cant seem to get my vacume brakes to hold on the line I am thinking of installing a T brake and want to know whats involved? I was thinking of the stageright type that Brian sells. Anyone have any input? The trans was built by Vince Janis and has about 500 miles on it with all the billet parts and a PTS D5 so Im sure its tough enough. Just wondered how hard it was to install one? Ive installed a shift kit before but thats it on a trans. Done a few engine rebuilds but a little nervuos about transmissions. Thanks for any input. Also I bought a crappy shifter cable from Autozone that wont let me shift into low so where can I get the right trans cable? Thanks again. Marty
1986 BUICK GRAND NATIONAL PTE 44 HOUSTON DP PTE EXHAUST HOUSING HD WASTEGATE ACTUATOR 009s TURBOTWEAK ALKY CHIP RAZORS ALCOHOL KIT WALBRO 340 PUMP HOTWIRED SCANMASTER HOOKER EXHAUST PTE FRONT MOUNT PTS EQUIPT JANIS TRANSMISSION LS1 TRANSLATOR 2800 PTS CONVERTOR |
Marty,
I sent you a pm. I have a couple new GM shifter cables as well. The new ones are slightly longer than the originals. Install of the brake is the same as a shift kit. If you did that, you are good. Thanks, Brian
87 Turbo T, Silver with maroon interior, and 35K miles. PTE 61-52E, CAS V-4, 42lb inj, 65mm t-b and HEMCO upper, TINMAN cold air kit. Powered by ALKY control. 11.77 @ 114, 23 psi 87 Turbo T, Blue on blue, ex DEA car, no options, all old school parts. Trans by me, 3400 stall O pump Art Carr N/L conv, Champion ported heads and intake, stock cam and bottom end w/ 117K, ESP front mount, TE-63, 55 inj, Hemco,3.42 gears with a locker, 10.84 @ 125 @25 psi 1.65 60ft on M/T drag radials Need a Hi Perf trans? Email me... hipsibri@cs.com |
Get it. You'll love it. Your car isn't complete without it. After you have it you'll wonder why you ever waited.
1986 Ttype .030 over TRW, stock crank and rods, RJC Girdle,oil pan,and power plate,Kenne-Bell ram air, 70mm throttle body and upper plenum, intercooler, ported irons, ss headers,and ss exhaust, TE 67, T.H. 3" ss downpipe, 60 lbs injectors, ME-R, Precision 5 disk 3200, Alky control, 210/215 roller with beehives, 1.6 rockers, rollerized billet parts from PTS, Stage Right brake, Dick Miller rear suspension, 26x11.5x15 ET Street bias ply tires. Best time 10.88 @128 On the street using a G Tech Pro Meter. |
The hardest part is taking off and installing the pan. That is how easy it is! Hope you have upgraded the axles! A brake is hard on factory axles. Some people use factory axles and a brake but having better axles will give you a little piece of mind! Are you running S10 wheel cyclinders and longer shes? That helps also. I run a brake bypass that is controled by a switch in the console. When activated, the fluid bypasses the proportionate valve the when turned off I have normal rear brakes. Twice the holding power on the rear brakes.
MODS: Some stuff |
I still have the stock axles and driveshaft but better parts throughout the drive line. U joints and Eaton posi and such. After the t brake install I found a vacume leak I thought I had fixed and can hold 10 psi easy on the vacume brakes. Go figure.... I had to get the brake from the guy that built the trans in case I ran into trouble. Paid alot more for it but oh well again. The bibbest pain on the install is all the fluid that runs out after you pull any bolt. Man I hate tranny fluid.
I still have the stock axles and driveshaft but better parts throughout the drive line. U joints and Eaton posi and such. After the t brake install I found a vacume leak I thought I had fixed and can hold 10 psi easy on the vacume brakes. Go figure.... I had to get the brake from the guy that built the trans in case I ran into trouble. Paid alot more for it but oh well again. The biggest pain on the install is all the fluid that runs out after you pull any bolt. Man I hate tranny fluid.
| transbrake | turbo grey | Parts wanted | 1 | May 3rd, 2005 05:03 PM |
| Transbrake | aquickv6 | Transmission Talk | 36 | February 18th, 2005 10:16 PM |
| need help with transbrake | Otto J | Transmission Talk | 5 | June 10th, 2004 11:23 PM |
| Transbrake | Big_D | Transmission Talk | 1 | May 12th, 2004 08:50 AM |
| Transbrake ? | V6RACER | Transmission Talk | 1 | October 18th, 2001 08:51 AM |
