Fastest 200 4R in the land?
Anybody know who's running the fastest on a 2004R???? I'll throw my Len Freeman built 200 in the ring, but surely there's faster guys out there...
Scott Atkinson / White 87T 109: Performance Transmissions LV; ALKYCONTROL.com; MAXEFFORT "R"; Full Throttle Speed |
what's Vince Janis' car running these days?
87T - stock block, TA-61, Precision FMIC, Comp 218/218, Janis transmission, 57# injectors, and lots of ghetto-rigging |
I believe Eric ran at least 9.50's, I ran 9.70's for a year with one of Erics plain Hi-pro trans....
I remember Greg Wood, I think I used to deal with him...... opps.... this is Jack Cotton, I was under Lorries name.... |
in 2003 i got 6 months and 85 passes out of our stage 1 2004r running 10.20 to 9.90s depending on weather and the track. i finally twisted the output shaft.pulled it apart and put a new shaft in and sold the car.its still going but has since broke the output shaft twice.finally the guy who bought the car bought and installed a billet input shaft ,ring gear and carrier.this was with a 3850 lb hurst olds with a mild 18 degree 406 small block and small supercharger.the car still wont run better than a 10.0 now.
CRISTOFOROS KOKKONIS GM AUTOMATIC TRANSMISSION SPECIALIST www.ckperformance.com STREET,STRIP AND DRAG RACE TRANSMISSIONS,CONVERTERS,DRUMS ,SHAFTS ETC. |
I have seen the output shaft/ yoke twist from transbrake launches, this is why i decided not to put a bunch a money in the 200 as there is no easy fix for that problem.
OLD fast efi help still located at http://www3.sympatico.ca/norbz/felpro.html or email norbz@sympatico.ca |
Please also post how much $$ you got in the tranny to run that time.
I am on the fence here between the 200 or just going with the 400.
Mike 87GN T-Top down 423lbs. Rebuild #2, BLK/BL Paint w/Custom Metal Flares, VPE Stg 3 Heads, 210/215 Roller Cam, TA49, V2 w/Blitz Blow Off, Billet Drum/Input, PI 3400 5disc, T Brake, Inland 3.5" DS, KB Plenum/70mm TB, Razor's Post Turbo Alky Kit, Devils Preturbo Alky Kit, TT Chip, 60lb Inj, Denso 280 Pump,-8/-6 SS Fuel Lines, MBC, Pwr Plt, PTE Oil Relocator, Preluber, Z06 Maf, Translator, Volt Master, Poston Headers, THSS 3.5" DP/Test Pipe, ATR SS 2.5" Y Pipe w/No Muffs, PST 2" Drop, Poly Bushings, Boxed Upper/Lower Arms, QA1 Shocks, Vacuum Converted, Aerospace 11" Brakes w/SS lines, Alum Drums, Polished Autodrags 15x8/15x10, 275/60 Nitto 555Rs |
Brett 87 GN stock (sold) 87 GN a few mods (sold) 87 GN Stage II (sold) 87 Turbo T Stage II (sold) |
This trans was our basic Hi-pro unit 1595 plus core, off the foot brake.
Jack Cotton check out our Bulletin Board today,www.cottonsperformance.com/forums 413-789-0531 Da Pumpkin - 8.90@154
Don't know who built it but I know of a stage II car that ran high 9's with one! I have a 109 car that runs nines and has had MANY 1/8th mile transbrake launches at 6.42! I think it was built by Mike Kurtz with all of PTS parts, at least that is what I was told!
I would make my decision based on the application for the car. Full race go with the 400; more street than race go with the 200! Just my .02's
1987 GN 47K 1987 GN 26K 1987 T 18K A few more TR's! T6P.COM Big Wood Racing Where Fast is never Fast enough! BoostedWhips.com Super-Motocross.com TheBassForums.com NCSHANE.COM |
My car only runs 10.40's at 128-129, but I have right around 300 passes on it. 90% of those were transbrake launches. Also mostly 1/8th mile passes. Car weighs 3500 w/driver, trans is by Brian Hofer. I know I'm not the fastest but I figured I'd throw it in there for reliability.
87 gnX clone, girdled 109, j & e's, ported stock heads, atr headers, THDP, te67, 60lb mototrons, precision FMIC and a 2004r trans by Brian. ET 10.16 at 132.21 mph 1.45 60ft. |
I've gone mid 6s in the 1/8 with a 200C. Now lets get down to life expectancy. I had to replace the direct clutch pack every 3 to 4 runs. Very easy to do with a 200C, but it gets old quick.
Donnie |
The quickest/fastest 2004r that I know of is 9.4's @ 147+ mph. Built by Vince Janis with all the billet internals.
K.
NCTURBOS If You See One of These... Turbocharged Drivability & Performance!! In-House Cylinder Head Porting & Computerized Flow-Bench Testing!! '87 Turbo-T Sage Green "1 RARE T" '00 H-D Heritage Softail S&S 106cui., etc. '02 2500 24v CTD Patriot Pearl Blue, 2wd, A/T, QC, BHAF, MIA silencer ring, J-Hook, 5" MBRP, DSS, MITUSA, Smarty, Redline box... **FOR SALE!!** |
Seems everyone is getting a few hundred passes out of there tranny's and your getting 3-4? WHat are you doing wrong? ![]()
OLD fast efi help still located at http://www3.sympatico.ca/norbz/felpro.html or email norbz@sympatico.ca Last edited by norbs : November 13th, 2006 at 09:40 PM. |
You do realize that I'm not talking about the 200-4R, right? You know the difference between the 200C and the 200-4R?
Donnie Last edited by DonWG : November 13th, 2006 at 09:51 PM. |
Yes, i do but i thought the tranny;s used the same componets inside except the OD section, my mistake, sorry
I couldn't tell you. I never did a direct comparison between the two. I know that when I went to the 400 I lost one tenth. Some people are saying they went faster after going to the 400 from the 200-4R. You can draw your own conclusions from that.
Donnie |
I had my 200-4R built without any billet parts and a Art Carr shift kit and my own special tweaking that I won't mention.
But it lasted from 1997 to Feb 2006 when I had it refreshed. It was still working fine but I figured with my recent upgrades I'd go ahead and redo it while the engine was out. The trans went from high 7's to mid 6's in the 8th at 107mph during those years. I guess I'm one of the lucky ones not to have it break all the time. |
