Transmission Talk Tech support for transmissions and torque converters from the experts
LinkBack (47) Thread Tools Display Modes
  47 links from elsewhere to this Post. Click to view. #1 (permalink)
Old August 10th, 2006, 09:28 PM
jpwalt1987's Avatar
OMNI PAINT SUCKS
th-400 and thrust bearing?
what exactly is the cure for a th-400 taking out the thrust bearing on the turbo6? thanks, jeremy
Jeremy
DSR Member #82
http://community.webshots.com/user/jpwalt1987
http://evadaleraceway.com/index.html
”The Constitution shall never be construed to prevent the people of the United States, who are peaceable citizens from keeping their own arms…”~Samuel Adams
If you're gonna be stupid....you better be tough!!
Sponsored Links
Old August 10th, 2006, 10:39 PM
Always Look Forward
Restrict the converter feed passage in the pump.
Donnie
1984 BUICK Grand National 224 cid Stage I BUICK V6 burning CH3OH w/N2O, 91mm turbo. Engine/trans by me.
Latest 1/8 mi. perf. (5/2010) w/FI91X (B/W Airwerks S510-91mm): 5.80@126.21mph, 1.35 60', 290 kPa MAP (27-28 psi boost).
5.27 hp/cid. Equivalent to a 500cid V8 producing 2,635 hp.
My pass @ Pinks All Out qualifying, http://www.youtube.com/watch?v=9AZumqEdMUE "What the h#ll is it?"
Old August 11th, 2006, 01:46 PM
how would a thrust bearing get takin out on a th400 car ?
87 WE4 stock block,stock crank, stock rods, 224-224 cam,70mm plenum, stock turbo, stock stretched intercooler, stock throttle body, Kenny bell headers, THDP, 009s, adjustable fuel pressure reg, adjustable waste gate, translator plus, 3'' LT-1 MAF, turbo tweek chip, SMC alky, turbo 400, 3000 stall, strength and honor
Old August 11th, 2006, 09:49 PM
Always Look Forward
Every so often you come across a 400 that does not control converter pressure well. I believe it's caused by casting variations of the pump assembly. I haven't been able to prove it though. A good way of spotting one is to monitor cooler line pressure. Assuming that there is not any abnormal restrictions in the transmission cooling system, cooler line pressure should read 40 psi. No higher! Lower is OK. If yours has a pressure higher than 40 psi, congratulations, you have a potential crank killer.
Pressure in the torque converter causes it to try to spit out the front of the transmission. Some forward pressure on the crank caused by the T/C trying to spit out is normal with automatic transmissions. It's when that pressure is excessive that the crank thrust bearing has a hard time dealing with the high pressure and it wears out. This is a very common occurence with the THM400 in motorhome and HD truck applications where heavy load is constantly on the powertrain during normal use. Heavy throttle positions translate to higher line pressures in the transmission which means higher converter pressures in those units that don't control T/C pressure well. If your using a manual VB, you have high line pressure at all throttle positions. Even at idle. I realize that there are other theories floating around that try to explain this problem. I've heard them all. This is the 'true' reason for this problem and for about 20 years, since I started modifying torque converter feed, I have not had one single problem and have in fact helped some well known people on this board solve repeated crank thrust problems. I feel for those people that ruin 3 or more cranks before they learn the truth behind the problem. This is a mod that should be done on every single 400 built.
Donnie
Old August 11th, 2006, 10:44 PM
jpwalt1987's Avatar
OMNI PAINT SUCKS
Thumbs up awesome
Don, that is some very good info there. i am gonna print this all out and bring it to my tranny builder. he is the best in town when it comes to stock applications and diagnostics. but hasnt done a th400 with a brake for a turbo6. any other special info that would be useful in putting the trans together? you know... tricks of the trade. thanks for all the help. jeremy
Jeremy
DSR Member #82
Old August 12th, 2006, 08:56 AM
man that sucks don now you've got me scared, i just put a 400 in that i got from a member here on the board.
Old August 12th, 2006, 11:04 AM
Always Look Forward
It's not hard to check if the mod was done. Pull just the pump and unbolt the halves to check. Have someone familiar with trans work help you so you get the pump aligned properly when you put it back together and you don't drop any clutch plates. Tranny guys know what I'm talking about.
I cannot urge this modification enough. Do it regardless of whether you think you have a crank killer or not. It is not worth the chance of damaging a very valuable engine.
Donnie
Old August 12th, 2006, 11:21 AM
jpwalt1987's Avatar
OMNI PAINT SUCKS
Post
don, what do you mean "drop any clutch paltes?" i found the passage that you are talking abotu in the ATSG manual i have. what do you use to restrict it? thanks, jeremy
Jeremy
DSR Member #82
Old August 12th, 2006, 10:45 PM
Wink
Don,
I was one of the people you helped with problem along with Jeff Harrington. I bought a 400 from a well know tranny guy on the board who said the trans was modified to eliminate the thrust
failure. Well it failed shortly after. I checked the converter feed pressure and sure enough it was too high about 100 psi. I did the mod and had 40 psi. Hence to say so far so good. Thanks again.
87 GN
8.81@158
Getting there.
Old August 14th, 2006, 10:35 AM
Quick Turbo V6's Avatar
Define stock!
What is need to do this mod? Where can I find a picture of the passage and where it is located?
Thanks,
Scott
Something should go here. I just don't know what.
Old August 14th, 2006, 09:47 PM
chris718's Avatar
Supporting Vendor
the converter charge hole exits the pr valve and pees oil out of the pump and into the converter in the vicinity of the front seal area thru an angled passage .recent testing has shown that installing an allen head set screw and drilling it out to .175" is enough to reduce converter charge psi to 55 psi.we used to crossdrill the hole .100'" to exhaust oil at the back of the pump but this generates increased stall speed from the torque converter due to restricted charge and will increase operating temperature of the transmission and some pumps didnt reduce pressure if the casting port of decrease oil was machined too wide,very common on most 6 bolt 895 /896 combinations with induction heat treated stator tubes.if the car is to use a fixed line pressure the line should be kept to below 170 psi by using an unshimmed stock pr spring (worn out is even better) .we have went even further with this concept by making the only externally adjustable th400 transbrake valve body that uses the modulator valve and a drilled and tapped modulator plug that exerts a force on the modulator valve to raise or lower operating pressure.the clutch apply area in a th400 is capable of running reliably at 160 psi hot with up to 1000 horsepower.keeping crankshaft endplay to the low side of factory specs and doing the mods will ensure trouble free operation with the th400 / 3.8 combination.the thrust area of the crankshaft in inches squared wasnt designed to work with the normal thrust of the th400 converter.then theres this stuff thats needed:http://www.ckperformance.com/resourc...OMPONENTS.html
Old August 15th, 2006, 09:04 AM
Don, I was talking about this with someone at Indy and he told me that you can get cavitation in the converter if the cooler line pressure falls below about 60 psi (I think). Have you ever run into this?
Regards,
Carl Ijames carl.ijames@verizon.net
Old August 15th, 2006, 09:22 AM
Always Look Forward
It is very important to realize that your standard cooler line pressure found with most automatics is 40 psi. Even the vast majority of 400s run 40 psi. A few will test at over 40 psi. Those units are the ones to watch out for. Just a little of my background. I worked at the only shop in San Diego that had a transmission dyno for 13 years. I studied a lot of cooler line pressure readings on 400s on the dyno because of the stories and problems people were experiencing with crank thrust wear. Mainly in motorhomes with 454 BBCs. Another important spec to remember. Cooler line flow should not fall below 1 quart in 20 seconds measured after the cooler. Pressure is not the important factor. Flow volume is. That doesn't mean restrict to 0 psi. Just enough to give you 40 psi at all loads. You'd be surprised how small you can go with the orifice and still maintain 40 psi and 1 quart in 20 seconds. To get an idea of converter feed restriction sizes, just study some of the late model transmission hydraulic circuits. They will give you an excellent idea of what size is needed.
Donnie
Old August 15th, 2006, 09:36 AM
Always Look Forward
I have heard the cavitation scare before. Even from a very well known transmssion man in the Buick community. All I will say is this. I have been doing the same mod, same size orifice for almost 20 years on stock, motorhomes, heavy commercial trucks, diesels, light racing and max effort racing and have yet to see an overheating problem or cavitation problem or crank thrust problem yet. Some of those customers run temp gauges too and monitor it. You can talk theory all day. In my mind it is proven.
I would imagine that if you go too small on the orifice size, then yes, cavitation is a possibility. Just stick to the specs I outlined and you'll be OK. Don't worry, be happy. No more crank repairs.
Donnie
Old August 15th, 2006, 09:44 AM
Always Look Forward
Some are asking what size orifice to use. I prefer not to freely give that info out. I have outlined the results to shoot for, some transmissions to study that will give you important clues. Now it's just a matter of doing some good old fashion experimenting and figuring it out for yourself. Not trying to be a hard bottom ender. I just like to see people figure things out for themselves. It's like dealing with my children and my employees. I prefer to see them learn on their own with a little guidance. It teaches good problem solving skills.
Donnie
Old August 15th, 2006, 10:04 PM
chris718's Avatar
Supporting Vendor
heres the deal.the hole is usually around .300 ",tap it to 3/8 coarse and install a 3/8 by 1/4 " allen head set screw and drill a hole through it to .155" to .175".with a stock unshimmed pr spring this will give 50 to 55 psi cooler pressure hot .period.
Old August 17th, 2006, 03:18 PM
Converter stall
Could restricting converter feed pressure change the stall speed of the converter?
Old August 20th, 2006, 09:04 AM
Yes. If the charge psi is too low it will increase the stall of the converter. I am not sure at what psi that is a problem. I can tell you the converter will work fine at 30 psi.
Lonnie Diers
Cincinnati, OH
513-898-0553
Extreme Automatics
  #19 (permalink)
Old November 14th, 2006, 10:22 AM
Lonnie, Don,
Could you have lets say 40 psi with a certain size orifice say 3/32" and 40 psi at 1/8" ? But now the difference is the volume the converter sees with the 2 different sized orifices? I'm thinking larger the size with same psi would supply more volume as to not raise the stall speed? Does this sound correct?
87 GN
8.81@158
Getting there.
  #20 (permalink)
Old November 14th, 2006, 11:03 AM
Always Look Forward
Originally Posted by lazaris View Post
Lonnie, Don,
If you have one quart in 20 seconds, you're fine. That's all you need.
When I was playing with different orifice sizes there was a case where a small block Ford that someone was building kept eating the crank thrust. It is very uncommon to hear of a Ford having this problem. I helped him out with it by restricting the converter feed. I think it was a C4. On the dyno we got it to 20 psi. Still ate a crank. I restricted it further to 0 psi. Still ate a crank. The interesting thing was, even at 0 psi cooler line pressure, it still had at least one quart in 20 seconds flow. In the end it turned out he started having crank thrust problems with other SB Fords he was building and found the true cause to be bad cranks. Can't remember what the exact problem was with them. I believe they were aftermarket cranks.
Donnie
BB code is On
LinkBacks (?)
LinkBack to this Thread: http://www.turbobuick.com/forums/transmission-talk/193584-th-400-thrust-bearing.html
Posted By For Type Date
LS2/TH400 7hrs and I destroyed the motor!! - Page 4 - Pirate4x4.Com Bulletin Board This thread Refback May 9th, 2010 12:51 PM
Question about repeated bearing failure • Speed Talk This thread Refback May 6th, 2010 11:09 PM
LS2/TH400 7hrs and I destroyed the motor!! - Page 4 - Pirate4x4.Com Bulletin Board This thread Refback March 4th, 2010 08:46 AM
LS2/TH400 7hrs and I destroyed the motor!! - Page 4 - Pirate4x4.Com Bulletin Board This thread Refback March 4th, 2010 05:08 AM
LS2/TH400 7hrs and I destroyed the motor!! - Page 4 - Pirate4x4.Com Bulletin Board This thread Refback March 4th, 2010 01:40 AM
LS2/TH400 7hrs and I destroyed the motor!! - Page 4 - Pirate4x4.Com Bulletin Board This thread Refback March 3rd, 2010 11:59 PM
LS2/TH400 7hrs and I destroyed the motor!! - Page 4 - Pirate4x4.Com Bulletin Board This thread Refback March 3rd, 2010 09:04 PM
LS2/TH400 7hrs and I destroyed the motor!! - Page 4 - Pirate4x4.Com Bulletin Board This thread Refback March 3rd, 2010 08:52 PM
Thrust bearing worn? what causes it. - Page 2 - LS1TECH This thread Refback March 13th, 2009 11:42 PM
Thrust bearing worn? what causes it. - LS1TECH This thread Refback March 12th, 2009 09:34 AM
THRUST BEARING WIPE OUT???? - Yellow Bullet Forums This thread Refback March 9th, 2009 06:54 PM
THRUST BEARING WIPE OUT???? - Yellow Bullet Forums This thread Refback March 9th, 2009 09:32 AM
BBC Rear Main Bearing Thrust Issues - Page 8 - Yellow Bullet Forums This thread Refback February 24th, 2008 05:04 PM
BBC Rear Main Bearing Thrust Issues - Page 8 - Yellow Bullet Forums This thread Refback February 24th, 2008 04:58 PM
BBC Rear Main Bearing Thrust Issues - Page 8 - Yellow Bullet Forums This thread Refback February 24th, 2008 04:56 PM
Question about repeated bearing failure - Speed Talk This thread Refback October 15th, 2007 11:52 PM
Question about repeated bearing failure - Speed Talk This thread Refback October 9th, 2007 11:53 PM
Question about repeated bearing failure - Speed Talk This thread Refback October 9th, 2007 08:18 AM
Question about repeated bearing failure - Speed Talk This thread Refback October 7th, 2007 11:27 AM
Question about repeated bearing failure - Speed Talk This thread Refback October 7th, 2007 07:04 AM
Question about repeated bearing failure - Speed Talk This thread Refback October 6th, 2007 12:29 PM
Question about repeated bearing failure - Speed Talk This thread Refback October 4th, 2007 09:58 PM
Question about repeated bearing failure - Speed Talk This thread Refback October 3rd, 2007 11:00 PM
Question about repeated bearing failure - Speed Talk This thread Refback October 2nd, 2007 08:46 PM
Question about repeated bearing failure - Speed Talk This thread Refback September 28th, 2007 06:19 PM
Question about repeated bearing failure - Speed Talk This thread Refback September 27th, 2007 09:09 PM
Question about repeated bearing failure - Speed Talk This thread Refback September 27th, 2007 06:38 AM
Question about repeated bearing failure - Speed Talk This thread Refback September 26th, 2007 06:49 PM
Question about repeated bearing failure - Speed Talk This thread Refback September 26th, 2007 05:42 PM
Question about repeated bearing failure - Speed Talk This thread Refback September 26th, 2007 05:30 PM
Question about repeated bearing failure - Speed Talk This thread Refback September 26th, 2007 04:49 PM
Question about repeated bearing failure - Speed Talk This thread Refback September 26th, 2007 12:17 PM
Question about repeated bearing failure - Speed Talk This thread Refback September 26th, 2007 08:52 AM
Question about repeated bearing failure - Speed Talk This thread Refback September 26th, 2007 08:40 AM
Question about repeated bearing failure - Speed Talk This thread Refback September 26th, 2007 07:00 AM
Question about repeated bearing failure - Speed Talk This thread Refback September 26th, 2007 06:53 AM
Question about repeated bearing failure - Speed Talk This thread Refback September 26th, 2007 05:56 AM
copper/brass in the engine oil filter :: Speed Talk - Auto Racing Forum This thread Refback May 6th, 2007 08:31 PM
copper/brass in the engine oil filter :: Speed Talk - Auto Racing Forum This thread Refback April 28th, 2007 02:07 AM
copper/brass in the engine oil filter :: Speed Talk - Auto Racing Forum This thread Refback April 27th, 2007 09:06 PM
copper/brass in the engine oil filter :: Speed Talk - Auto Racing Forum This thread Refback April 27th, 2007 03:20 PM
copper/brass in the engine oil filter :: Speed Talk - Auto Racing Forum This thread Refback April 27th, 2007 01:57 PM
copper/brass in the engine oil filter :: Speed Talk - Auto Racing Forum This thread Refback April 27th, 2007 09:58 AM
copper/brass in the engine oil filter :: Speed Talk - Auto Racing Forum This thread Refback April 27th, 2007 09:26 AM
Crankshaft endplay - Chevelle Tech This thread Refback November 7th, 2006 12:58 AM
Crankshaft endplay - Chevelle Tech This thread Refback November 5th, 2006 09:20 PM
