Old June 27th, 2006, 09:25 PM
S10xGN's Avatar
Finally Roadworthy!
What hard parts to order...
Hi All,
I'm getting ready to go through my "CQ" tranny (from an '85 MCSS) that will reside in front of a 2004 LS-1 motor in my old street rod. I *was* going to turbo the motor (and still might), but for now just a big cam and heads will do. I already have my 3600 VIG converter and the flywheel and spacer needed to mate this up, all checks out perfect with 0.080" clearance between the flywheel and converter.
I need opinions on what hard parts to go with either way and what special tools I *really* need (I'm pretty handy at building stuff). I already have Chris's manual plus the ATSG book.
Thanks!
* Russ Selkirk; Port Neches, TX -> GN powered S-10 <- 12.17 @ 115.6 on pump gas!
* * * * * * * * * * * * * Click HERE to check out my thermal-printed stickers page! * * * * * * * * * * * * *
* GN powered '96 S-10 fleetside * +.030 TRW's * steel caps * ARP studs * Comp billet 215°/210° roller * full-port iron heads
* JetHotted "Hayden" ported headers * 50# MSD's * "TurboTweak" chip * PTE 52 turbo * "Jay Jackson" 62mm throttle body
* CAS front-mount IC * "TurboMike" ported elbow: 3" downpipe: 3" DynoMax Raceflow * Walbro 340 * Vigilante 3400 converter
* B&M megastick * Ford 8.8" 3.73 trac-lok * Hoosier QT's * CalTrac bars * Razor ALKY * BsTC controller w/dual solenoids
* and a whole lot of custom-made pieces!
Old June 27th, 2006, 09:38 PM
turbocody's Avatar
GOT BOOST!
forward drum! input shaft also....but if ya go turbo later i would do both!
Cody C.
87 T 58k miles
ported gn1's,70gtq,fast xfi,83's, fully forged/girdled 109, pte fmic, 3.5 DP, ported intake, ta ss headers,3800 stall, built 200r4 w/brake, etc,etc
Old June 27th, 2006, 10:33 PM
bison's Avatar
Long Duc Dong
Trader Rating: (23)
Front carrier and ring gear will need to be replaced for the turbo app. as well as the parts listed above. Call Chris for info about trans brakes.
Old June 28th, 2006, 08:31 PM
S10xGN's Avatar
Finally Roadworthy!
Thanks much! Hope others will respond too...
Old June 30th, 2006, 07:02 AM
chris718's Avatar
Supporting Vendor
e4340 shaft forward drum should be mandatory,as well as a quality recalibration kit.
www.ckperformance.com
