Old April 13th, 2005, 01:15 PM
Chrisk's Avatar
TurboTransAm.com
Question Single Disc or Multi Disc Converter????
Im about to purchase a Precision Industries 9.5" converter.
What would be best a Single Disc or Multi Disc?
I know about the Lockup issue. Would it be better to lock it up with a switch?? what is the advantage of using a switch??
Thanks for the Help
Old April 13th, 2005, 03:10 PM
you can safely lock a multi disk at WOT.....not so on a single disk
you need a switch if your chip/ecm doesn't provide wot lockup
Woody
Basic TSM recipe 24 lbs boost
Old April 13th, 2005, 08:17 PM
chris718's Avatar
Supporting Vendor
the switch will allow you to acgtivate the lock up before the computer does.it is best to use a well plotted lock up strategy incorporated into the chip,as well as a switch to also ground the solenoid and command lock up at will .this will allow you to do some experimentation at the track to find additional tenths in your e.t..if you dont get the precision unit we can set you up with a very reliable single woven fibre disc lock up clutch that will be capable of holding all you throw at it.how much power are you making?
www.ckperformance.com
Old April 13th, 2005, 09:03 PM
Intercooler's Avatar
Glad our cars come with multi-disk D-5's. Oh, they didn't.... Hmmmm people lock them up I think You can lock a single. Just don't get rammy and try to do it on the tree. Third gear is no problem.
Old April 14th, 2005, 08:35 PM
think he was asking about Precision converters? They advise against locking their single disk
anyone still using D5 isn't making enough power to matter, but you will still tear them up locking under wot
Woody
Old April 14th, 2005, 09:42 PM
S10xGN's Avatar
Finally Roadworthy!
You're talking about locking a 12" converter vs. a 9.5" converter with MUCH less surface area. Those locking their 12 inchers are playing with fire. Those who try and lock a 9.5 incher may do it once (or maybe not...).
* Russ Selkirk; Port Neches, TX -> GN powered S-10 <- 12.17 @ 115.6 on pump gas!
* * * * * * * * * * * * * Click HERE to check out my thermal-printed stickers page! * * * * * * * * * * * * *
* GN powered '96 S-10 fleetside * +.030 TRW's * steel caps * ARP studs * Comp billet 215°/210° roller * full-port iron heads
* JetHotted "Hayden" ported headers * 50# MSD's * "TurboTweak" chip * PTE 52 turbo * "Jay Jackson" 62mm throttle body
* CAS front-mount IC * "TurboMike" ported elbow: 3" downpipe: 3" DynoMax Raceflow * Walbro 340 * Vigilante 3400 converter
* B&M megastick * Ford 8.8" 3.73 trac-lok * Hoosier QT's * CalTrac bars * Razor ALKY * BsTC controller w/dual solenoids
* and a whole lot of custom-made pieces!
Old April 15th, 2005, 03:37 AM
REDS HOT AIR's Avatar
Buick Tweaker
Im testing a 9.5" single disc converter now(different manufacture)
so far its been 134 mph thru the traps in a full weight GN locking the converter at all different gears and rpms and so far not a bit of trouble (watching rpm drop on f.a.s.t. datalogs)
after a few combo changes ..I'll be beating on it even more
full weight 109 block ....140 mph ?? who knows
85ttype 87 powered (resting) , 78 elcamino turblo bruick powered
Eastern Virginia Turbo Buicks
From Stock To Stage All Types of Buick Repairs Or Mods
business is closed ... relocating to jax. florida soon
Old April 15th, 2005, 05:34 AM
Is this a special Pat's unit Steve was whipping up for you?
