Old February 18th, 2005, 11:43 AM
gn4u2c's Avatar
"I will become powerfull"
Trader Rating: (9)
Trans cooler/ custom lines
I have a biggie front mount trans cooler. my aftermarket al. rad has no cooler built in. so the lines were cut and rubber hose connected to the cooler.
What i want to know is does anyone make a cooler that will accept a -an fitting of some sort vs a side on hose.
A tech at my job suggested running new lines and getting a cooler with fittings as my current ones have been rubbing against the frame and are showing some wear. He also says the rubber hose has a much higher chance of blowing off with hot fluid going through it.
I would like to do something to prevent future problems.
Don't ask how much money I have spent on it .I may go insane.
Old February 18th, 2005, 01:09 PM
HAPPY WHEN IM BOOSTING!
YES, I JUST BOUGHT ONE BECAUSE THE GUY BEFORE ME HAD THE SLIDE ON RUBBER HOSE DEAL AND THEY WERE SWEATING FLUID.
ITS A B&M COOLER PART# 70266. IT COMES WITH 1/2 NPT FEMALE THREADS AND YOU CAN EITHER PUT A RUSSEL FITTING NPT TO AN IN AND RUN A BRAIDED LINE TO IT OR A BRASS FITTING THAT ACCEPTS A METAL LINE LIKE THE FACTORY ONE.
I HAVE THIS UNIT ON 3 DIFFERENT CARS, IT WORKS GREAT.
HOPE THIS HELPS,GOOD LUCK
Old February 18th, 2005, 01:49 PM
This company makes the best oil coolers in the world.
If you purchase one with a built-in fan you will have the freedom to locate it away from the intercooler, radiator, a/c condenser stack, which will improve their performances. Plus, it could make the plumbing substantially easier.
www.setrab.se
strike
Old February 18th, 2005, 02:12 PM
gn4u2c's Avatar
Trader Rating: (9)
sweet. looks like the anwser.
Old February 18th, 2005, 03:10 PM
I just did this yesterday. I used the B&M 70266, which is actually made by LONG out of Canada. It has 1/2"NPT inlets, I used a 1/2"npt - 3/8"npt reducer bushing then a 3/8"npt to 6an fitting. Also 1/4"npt - 6an fitting will screw directly into the transmission case. Good Luck. I can snap pics if you want.
Scott Atkinson / White 87T 109: Performance Transmissions LV; ALKYCONTROL.com; MAXEFFORT "R"; Full Throttle Speed
Old February 18th, 2005, 03:19 PM
Intercooler's Avatar
Are you doing stainless braid? Can you send me a picture? I want to see how your routed them near the frame.
Old February 18th, 2005, 03:56 PM
Ditto. Can I also get a pic?
Bill
1987 Buick Grand National
CPT62, 212/206 billet roller,
ported irons, Seimans 72#, RA Double Pumper, 65MM TB,
RJC power plate and pulleys, ATR headers, ATR single shot,
ATR DP, Pats 3200 L/U, and more...
Old February 18th, 2005, 04:25 PM
gn4u2c's Avatar
Trader Rating: (9)
Same here sounds like a good idea
Old February 18th, 2005, 09:49 PM
pics sent.
Old February 18th, 2005, 10:19 PM
Hey there..If I could get some pics that would be sweet!
Brgds,
Bill Crawford
1987 Ltd "T", ATR (Double Pumber, EMC-10, F/P Reg., Pitbull Chip), K&N 9", Test Pipe, Dynomax OEM repl muff, ADJ Wastgate, A/C Trans w/9"N/Lu Conv,Tran Clr, Airbag, Burgundy with Weld wheels.
Old February 19th, 2005, 04:21 AM
Lunkan's Avatar
Crazy? Me? :-P
Please, do send me some pictures too. If I understand it correctly, the 200 and 400 use the same cooler fittings.
Thanks
/Andreas
On the internet we inform us with words. If you write like an idiot, expect to be treated like one.
Old February 19th, 2005, 01:59 PM
86gn's Avatar
Glenn is slow!!!!!!!!!!!!
Pics too please..
Built shortblock : 214-210 roller :GN1's : BGC intake : THDP : TE45A : Hooker Cat back : Trans + & Extender Extreme 72's :PTE Front mount : Extreme Tranmission & 3400 9/11 :Best run so far a 10.79 @ 126 MPH @ 21psi.Full weight car 3850 with FAT driver.
Old February 19th, 2005, 03:37 PM
Just realized they went to my work e-mail. Can you send them to my home e-mail: intercooler2@comcast.net
Thanks!
Old February 19th, 2005, 09:40 PM
I actually re-routed them last night. Now they go from the trans. to underneath the starter heat shield (LT1 starter, not sure if possible on stock starter) and along frame. I'm still not real happy with how close they come to the ATR headers. I'll probably run about 18" of "fire sleeve" where they pass under the headers.
Old February 19th, 2005, 09:49 PM
pics sent
Old November 19th, 2005, 09:06 PM
oldtimer's Avatar
Scott,
Can I get pics of your install. I'm just in the process of trying how I'm going to do mine.
Thanks a lot !!
George
Oldtimer
'87 GN ( original owner )
Cal Hartline prepared Stage 2
9.76 et @ 148.07 @ 25# with awful 1.80+ 60 fts. (some more work to do)
G S C A 2865
Old December 3rd, 2005, 03:21 PM
GO FAST's Avatar
I have the TCI cooler with built in -6 female ends , works very well. Sorry no pics got it from Summitt Racing.
87 GN ,T-tops, stock block, stock heads/intake ported by Champion Racing. Precision GTQ 70 turbo & front mount intercooler. Siemens 72 lb/hr injectors, Red's double in tank pumps and 106 chip. Art Carr 9" converter & valve body, transmission built by Tranny Tech. Plus other cool stuff.
Old December 3rd, 2005, 03:46 PM
mybuick's Avatar
intercooled engines rule!
i have the b&m cooler also and i routed the aeroquip hoses in the frame... much cleaner look too ... there hosed clamped for now but i will put the threaded ends on it after the frame off resto..
trans end
cooler end
84 gn/ 87 engine
.030 109 ballanced, msd 50# inj, all billet mains, bms rods, 8445 champion ported heads, comp cams .459 lift, champion intake, precision fm, accufb 70mm tb, 340 fp hotwired, tt 93 chip, 3 in mcale dp, hooker cat back, northern alum rad, b&m tranny cooler. all on 93 octane...
  #19 (permalink)
Old December 3rd, 2005, 08:05 PM
A. G. Olphart's Avatar
In my not too humble opinion, mybuick could use some protection on its' new hoses where they pass through the frame. (See gn4u2c's original post).
I had a copper cooler line break from work hardening (guess there's a reason they are steel from the factory), and believe me, leaky cooler lines aren't fun.
_______________
A. G.
  #20 (permalink)
Old December 3rd, 2005, 08:24 PM
mybuick's Avatar
been on 3 years 20,000 miles now and no leak as you can see.
84 gn/ 87 engine
  #21 (permalink)
Old December 3rd, 2005, 11:09 PM
Free advice, worth what you paid... conformance is optional, no kneecappers will be sent.
Told you I wasn't too humble .
Glad it is working for you.
_______________
A. G.
