Old October 18th, 2003, 09:46 PM
Trader Rating: (-1)
1-2 Shift Point
HOW DO I LOWER MY 1-2 SHIFT POINT ONLY, WITHOUT ADJUSTING TV OR MODIFYING GOVERNOR. BY ABOUT 200 RPM.
Old October 19th, 2003, 06:37 AM
Lee Thompson's Avatar
shift points
I know how I did it, cut 1/2 ring off the the 1-2 shift spring. I also would like to know what the REAL trans builders think.
leeo
Old October 19th, 2003, 09:07 AM
chris718's Avatar
Supporting Vendor
it depends on at what throttle angle you / position you want it lowered at.
www.ckperformance.com
Old October 19th, 2003, 10:13 AM
Trader Rating: (-1)
I WOULD LIKE IT LOWERED AT WOT.
Old October 19th, 2003, 10:31 AM
chris718's Avatar
Supporting Vendor
change 1/2 shift valve spring tension by installing a spring with the same working height and less tension.it could be that there is a leak at the shift tv valve sleeve due to wear and this is causing a slight increase in wot 1/2 shift rpm.you can change the sleeve.
Old October 19th, 2003, 10:49 AM
Trader Rating: (-1)
OH I ALMOST FORGOT, I INSTALLED THE TRANSGO REPROGRAMING KIT WHICH SAYS FOR ME TO PLUG THE F HOLE IN SEPARATOR PLATE, I DON'T KNOW WHICH WHOLE THIS IS OR IT'S PURPOSE. DON'T REALLY HAVE ANY PROBLEMS BUT WOULD LIKE TO FIRM UP MY 2-3 SHIFT A LITTLE MORE IS THE ANYTHING ELSE I CAN DO FOR THAT?
Old October 19th, 2003, 10:55 AM
chris718's Avatar
Supporting Vendor
now i cant help you.that transgo kit is not right for turbo regals.sorry
Old October 19th, 2003, 11:03 AM
Trader Rating: (-1)
IT'S NOT A BR OR BQ TRANS IT'S A CTF OUT OF A CHEVY CAPRICE WITH POLICE PACKAGE.
