| Time Slip and Combo Database Post your time slips and list your combo's here! |
| Sponsored Links |
That car is not only beautiful but dam fast.
1987 Turbo T Dark Blue Blackout Astroroof, Don Cruz Built 109, PTE Billet 71 DBB HPS T4, Forged Bottom End, 2xx/2xx Cam, RJC Girdle, TA Headers, DLS Ext. Oiling Sys., Champion GN1R, Champion Rails, PTE 95 Lb. Inj., RJC I-475 FMIC, JW Racing 3.5 DP, XFI, AMS 1000, Co2, Meriere Water Pump, RJC Pulleys, PTE Plenum, Accufab 70 TB, Tial 44 WG, Tial 50 BOV, JW Racing Cold Air, Razor's Dual Alky, Alum. Rad. Dual Spal Fans, 140 Billet Alt., PTC 9.5, Extreme All Billet Rollerized 2004R, JW Racing Mini-Tub, Custom DS, H&R Sway Bar, H&R Upper/Lower, HR MM, SC&C Upper/Lower, TA Girdle, Eaton Posi, Moser Axles, Adj. Varishocks, Aerospace, AC/Heat, NO CAGE..... Street Car. XFI Tuned By Otto. www.ottosperformance.com ![]() |
The Cheney Brothers 1988 Iroc-Z28 Camaro Hybrid.109, CHAMPION Iron's & intake, FMIC,74 GTQ, comp224, FAST XFI, RAZORS ALKY,TH400,3500 conv, 9" 10.40's@134 1987 Buick Turbo Regal T Limited. Stock 109, SMC Alky, TE.66, TT Chip, wideband 02, Leeo Tranny, FMIC 11.14@120 www.aaperformance.org for pics ![]() ![]()
Don't you guy's know you can't go that fast with a chip....
![]() That is awsome.....
Ronnie Martin 87 GN, 25K, 10 sec. (Will work for Parts) No seriously I will Powder Coating and Performance Coating WWW.MyPowderCoating.Com WWW.TurboTweak.Com It's always the Tuna (Grumpy) This forum requires that you wait 45 seconds between searches. Please try again in 18 seconds.
Job well done!
Any motor pics?
Chris McDade 87 GN Motor is out. Heads are being ported along with intake. New combo will be .030 Weisco stock crank, rods, RJC girdle. PTE stock location. 87 GN (Dad's Car) Build 109 with all the goodies New times 10.64@126 New mods RJC Front Mount, Ported intake, Rear anti roll bar. New times soon. 87 T 10.44@129.85 1.47 60ft (Sold) |
Good Job!I did get to see this pass,it was awesome.Another Buick event would be great especially if it was in the fall.
WWW.HRpartsNstuff.Com HRpartsNstuff Phone Sales Mike Ruminski 1986 Grand National TA49,Precision intercooler,55lbs,Weber heads,stock TC,ATR SS Exhaust,Hot Wired XP Fuel Pump,Volt Booster,HRpartsNstuff U/L Control Arms Best Time 11.52@118 w/1.65 60ft/New Combo Limited GT70 p-trim Turbo,Janis Trans with Pro-Torque,Weber Racing motor 212/206 Billet Roller,Tomka 4in Cold Air,HRpartsNstuff Swaybar |
Congratulations on that great pass!
![]() Count me in for next year- I'll be breaking in my new motor! ![]() Joe
87 GN- Astroroof, GNX Style Dash, Razor's Alky , 60# Mototron's, Mease 24 Row SLIC, 3"THDP, TurboTweak Chip, Janis built Stage II 2004R, PTS Xtreme Billet 9x11 3200 lockup. 144K stock longblock ![]() New Motor Coming- Finally! |
Bad A$$... Good job Brian!!
K.
NCTURBOS If You See One of These... Turbocharged Drivability & Performance!! Quad Air Inc. Janis Transmissions DLS Engine Development Hartline Performance HRPartsNStuff Razor's Alky Control TurboTweak Products Pete Tomka Cold Air Kits Twisted-6 PTC Converters Merritt Performance TRE Diesel Performance JD's Cycle Works |
Excellent job Brian, congrats.
Mike Ricketts ![]() DLS ENGINE DEVELOPMENT 886 E 900N, Wheatfeild, IN, 46392 219-956-3653 HARTLINE PERFORMANCE 321-722-1563 My Track passes http://www.youtube.com/watch?v=mKEIyppgOr0 http://www.youtube.com/watch?v=6SqbYtfQn8c |
Holy Moly, that's flying. No cage either?
87 TurboT--Stock longblock, GT6131, rebuilt trans, Pat's 12" 2800 stall converter, 60lb injectors, Precision sl intercooler, Hooker cat back exhaust, THDP, pp, 62mm tb,AlkyControl kit, Turbo Tweak 6.0 alky chip, HR lower control arms, air bags, ATR bar, Powerlogger/Powerdex A/FX wideband best 60' 1.509 best et 11.384 best mph 117.23 http://s64.photobucket.com/albums/h1...secondpass.flv |
Thanks Mike, you of all guys knows what it takes to run these numbers.Quote:
QUOTE=turbo6mike;2326546]Good Job!I did get to see this pass,it was awesome.Another Buick event would be great especially if it was in the fall.[/QUOTE] Thanks Mike! Next year is your turn to run well! ![]() Quote:
Timing/cam sensor issue that turned out to be minor. Thanks alot Keith! Still prob gonna bite the bullet and try that PTC! ![]() Thanks bud! It would be great to get alot of us 9 sec stock block guys together in good weather on a hookin track! Com on out! Id like to meet you in person. Indeed..no cage. Cant bring myself to cut on a 17k org mile car.
Ya!I should be out next year
.Hopefully it will be another day like that.Weather was perfect.
Makes me laugh when I hear that Red is too old to make Chip...
![]() Way to go man..Stock ECM and MAF.. ![]() A proven package that works.
============== 1987 Hard Top 231 C.I. |
Damn that amazing on the stock ECM and MAF!
Congrats!
V8KillR4U 109 block bored .030, main caps, girdle, T&D roller, roller cam (secret grind), ported champion intake, GN1's, 70 mmTB, Plenum, 75 lb inj, 70-ptrim, atr headers, 3" TH DP, CAS v-1 FM, NickMchale Radiator, Tranny cooler, 400 trans with brake, rev manuel VB, Precision Converter 3400, Max effort, have a FAST ready to install, REds XP pump, voltbooster (probably some more stuff im forgetting) |
That's great!
87 GN, BB6776,3000 stall,hotwire,Denso pump,Ebay FMIC,210/215 roller,stock crank,65lb injt,SMC alky,Scan2.1.JDM Headers. TT Chip.ect |
![]() Thanks fellas! |
That's awesome Brian!!
Let me know when you have the next event and I'll get some of us from down here with buicks to come up We have been talking about having a get together at a track for awhile. I can probably get a few fellow tsm and ths cars to join.
![]() Quote:
This would be great! We need to get together in late winter and figure out a date that would work best for you guys and make it happen. Were real flexable up here. The more guys I can get here the better. Try and make it more of a "mini event" or something if possible except it will be VERY cheap to run in comparison to all the others. No payout for anything obviously just alot of fun and alot of cars laying down some great numbers. Maybe this is something that could get big if all goes well.The track prep/upkeep is way more critical to our cars than most cars as everyone knows. No monster wide tire, back halfs, exc. The owner understands this and gives us free rain with the VHT/gold dust to keep us glued. So the starting line wont be going away after 10 cars making a pass. You cant hardly put a price on an outstanding 60 ft! ![]() Anyone who would be interested in something like this or knows people who would be, chime in. I can make a post in the lounge section later to get an idea of who all would game for something like this. Brian |
Congrats, beautiful car and great numbers too. I am partial to the color as well.
1987 GRAND NAT'L - 12.0 @ 112 MPH 1986 GOLD T-TYPE - 11.6 @ 116 MPH AMATUERS BUILT THE ARK / PROFESSIONALS BUILT THE TITANIC. |
That car has hurt some feelings on the street I bet.
09 G8 GT 13.9x's stock with 2800 D/A 87 GN 10.26@134 1.49 60ft. Stock block. Bunch of S2 parts waiting on a GTO to go away 05 GTO 11.43@120.4 1.55 60ft. cam only all motor. GONE. 86-T-Type 13.84@103.5 /2.45 60ft, straight 93. Dutt neck,340,hooker cb,afpr,3"maf pipe. Serious KR issues and tons of wheel spin USN Retired |
B- nice to see you took the car to the track, sounds like its running its ass off.
We met a few years back in BG right after you purchased the almost same colored limited in CA. 9.7 on a stock maf with such a small cam and ****ty chip, thats amazing how well the car performs with the DLS components. Very nice! Take it easy BW
BRYAN Eric Marshalls Turbo Tweak Chips Timeslips for white car TA61/009 Inj Under hood shot of white limited ![]() Proud TTA owner ![]() ![]() Sage Green 87 T |
Thanks alot Otto!
Yeah it has suprised a few big blocks..lol ![]() Quote:
Brian Quote:
![]() The car has exceeded expectations and the DLS built mill is everything its cracked up to be. I will prob be going to a FAST with it later but wanted to see the car run a impressive numbers with the stock stuff. Take care and hopefully you make it back to BG in '10 Brian |
| Bookmarks |
| 27k mile Stock Rear End cover w/bolts, stock axles, stock starter | V6UnderPressure | Parts for sale | 0 | February 18th, 2008 06:00 PM |
| Used Stock Turbo Crank, Stock Rods, TRW Forged Pistons, Billet Comp Cam | 87TurboGN | Parts for sale | 11 | December 13th, 2007 08:18 PM |
| Nice turbo shield, stock downpipe w/ dump welded in, stock a arms | mjdwyer23 | Parts for sale | 12 | April 13th, 2007 06:57 PM |
| Block, heads, A/C condensor, stock injectors, stock headers FOR SALE HOTAIR | Matto | Parts for sale | 1 | November 12th, 2005 08:19 PM |
| 2.5" exhaust, Stock Maf and 9" K&N cone, Stock IC fan , Stock speakers and more | GNVYUS 1 | Parts for sale | 10 | September 9th, 2005 10:36 PM |
