Go Back   TurboBuick.Com > Miscellaneous > Time Slip and Combo Database
Old August 6th, 2008, 09:19 PM
buickrob's Avatar
12.85 @ 114
Man my converter killed me. Nice to see the MPH is there though. Should have raced with my TE-44 before buying the 6152, probably would have been a lower ET.
I sat with the green light staring me in the face for a while trying to build boost, thus the terrible reaction time. Might have hit a pound or two of boost, not much at all. Really dogged until the boost hit around 40' out, then it took off like a shot.
I'm thinking about going back to a smaller turbo because I really don't feel like pulling the trans again. I could spool about 7-9 psi on my 44 on the footbrake.
1987 GN hardtop, 6131e, ESP front mount, SMC progressive alky, Pat's Converter 2800 Stall 12", 50# Injectors, hotwired 307, THDP, 2 1/2" exhaust w/ ultra flow muffs, Turbo Tweak alky chip, adj fuel regulator, RJC boost controller HD wastegate, 9" K&N w/ 3" maf pipe, 160* stat, R42TS plugs & 8.5mm MSD's, Tubular Lowers, 15x8.5 GN wheels w/ 275/60/15 MT drag radials
Old August 6th, 2008, 09:26 PM
Little6pack's Avatar
at 114mph should be way faster then 12.85. I get 12.80 at 108 mph
87 Turbo T Limited: TA-49, 009's, TT chip, 70mm accufab, Single shot exhuast.
Old August 6th, 2008, 09:34 PM
Boost231's Avatar
What's An Intercooler
Trader Rating: (13)
keep the turbo. just save up and get a real converter.
Just Another Slow HotAir
www.arizonagn.com
www.gbodyparts.com
www.rjcracing.com
Old August 6th, 2008, 09:45 PM
buickrob's Avatar
Oh I'm more than aware it should be way faster ET with the 114 mph, definite 11's potential. The bright side is the power is there.
Boost231 you are absolutely right, I just have a hell of a time saving up
Old August 6th, 2008, 10:02 PM
Boost231's Avatar
Trader Rating: (13)
you know what i do when i need money. look around the house and list up all the crap lying around that i never use on ebay.
www.arizonagn.com
www.gbodyparts.com
www.rjcracing.com
Old August 8th, 2008, 08:43 PM
t-typex1's Avatar
I got 12.50's at 105. I was running 12.02 @ 113 with a D5 restalled to 3K and a TE60
Stock long block, PT6776S with AlkyControl and pump gas
