| Time Slip and Combo Database Post your time slips and list your combo's here! |
10.41 @ 126.99 pump gas and alky
86 gn , last pass made in 2006
93 pump gas and alky ,stock shortblock , 200-4r, no slicks or skinnies drove to track and back 140mile weight ~3450-3475 launch 10psi , 1.43 60 ' run 24psi for 4 seconds then 23psi the rest slips are here http://www.turbobuick.com/forums/att...imeslips86.jpg video (1st and last pass on vid were 4th and 5th run of the day) Video - A little fun with the Gn's at Atco. 109 stock shortblock , stock pistons rods crank, no caps ,studs ,bolts or girdle 212-208 hydraulic flat tappet studded ported stock irons , stock rockers and covers, RJC headgaskets mease plenum , 70mm accufab, stock intake 75# injectors ,stock fuel rail, RTX hotwired injector harness, accufab fuel pressure reg., ATR twin in tank 340s hotwired, stock fuel lines 160 therm , RMI 25-water , fbody rad, valeo dual fans hotwired champ alt ps bracket , deletes a/c compressor and tensioner , stock pulleys CAS V2 front mount , 2 1/2 in 3 out 71 GTQ , 70 A/R S cover , precision .85 exh 3 bolt 4" chrome steel inlet pipe (mafless type) with 6x9KN filter 4" inlet stock exhaust manifolds, poston crossover ATR SS 3" external gate , test , 2.75 SS TH full length duals ,3" magnaflows HKS 40mm gate , 5 psi spring , innovative MSBC-1 boost controller 200-4R (good stuff), PTS deep pan , stageright brake, art carr 9" 3600 N/L converter, B&M trans cooler (only) PTE turbo saver , no oil cooler AC delco 75 series battery (stock location), stock cs 144 alternator ,reds VB stock ac delco ign module and coil , MSD DIS-4, MSD 8.5 supercondutor wires hd chromoly driveshaft , spicer yokes 8.5 rear 3.42, moser spool ,33's ,elims, studs, alum drums, stock upper arms , boxed stock lowers (all stock bushings), HR parts rear sway bar (no front) stock rr springs (no bags), eibach front (-1"), nothing fancy about the shocks 276/60-15 MT radial ET streets (drag radials) inflated 22psi (no slicks) 235/50-15 fronts on 15x7 western mesh aum rims (no skinnies) 6 point roll bar (no swingouts), SFI trans blanket, 5 point 3" belts , metco driveshaft loop, steel valve stems other stuff vacuum brakes , stock interior pw/dl/tilt /pseat/deck rel/ p-ant/delco cassette , CF hood , token frt and rear bumpers, rr alum support fuel . 93 wawa gas and alkycontroll PAC dual nozzle (methanol) engine management stock ecm (modified drivers for injectors) , turbotweak 5.4 chip , translator+ LT1 3" blow through mass air flow sensor , denso O2 engine monitor /logger gnx 8 gauge dash ( boost /knock/tach/speedo/volt/water/oil/fuel level scanmaster 2.1 directscan 1.52 Innovate LM1 wideband
paul -NJ rep MAGNAbuick.com NJ,PA,MD DE -GN/TTA club 86 & 87 GN's A little fun with the GNs at Atco video my 86 10.4 on 93 with a 2004r on radials through the mufflers Last edited by pacecarta; February 12th, 2007 at 09:24 PM. |
| Sponsored Links |
nice times
great times how does that turbo spool on the street
thanks jay 87 gn - stock 109 block with just springs and chain done pt-51 turbo, rjc boost controller an EGT gauge, 60lb injectors, cold air intake, 340 fuel pump an hotwire kit, 2 3/4 dual exhaust, 3" terry houston down pipe, joe lubrant chip and cas-v2 front mount intercooler,precision vigilante 3200 stall converter, level 1 trans done by jimmy's, ET 11.60 @116.mph 60ft 1.60, 1/8 7.36 @94.20mph on stock rims best sixty so far in the 1.5's |
hardly ever get into the throttle on the street , spoolup isnt too bad but there is a delay , gets too hairy too fast at anything above 15psi
oh thanks nordy , i love the vid , the other Gns are hooper and artie on some of thier best passes of the year
paul -NJ rep MAGNAbuick.com NJ,PA,MD DE -GN/TTA club 86 & 87 GN's A little fun with the GNs at Atco video my 86 10.4 on 93 with a 2004r on radials through the mufflers Last edited by pacecarta; February 12th, 2007 at 09:47 PM. |
you coming down to the MAGNA meeting on Saturday.. i'm flying in to hang out with you guys..
![]() SOLD87 GN Anderson Powered.. 9.65 at 140mph in 100* weather... 6.04 at 114 1/8 65* temps, (thats a 9.43 ET in the 1/4 )
Great runs Paul. I see you've got that boost controller dialed in. NICE!!!
Alan Ferrer 87 GN:Ttops 109 Girdled/CAT forged crank,Scat rods,Fully ported TA Street Intimidator heads,214/214 roller,Precision 70HPQ,Innovative MSBC,Cotton DP,Turbonetics RG-45 gate,84#'s,Me-R w/ WB correction,Aeromotive Eliminator pump,PTC 9.5 NL converter,TH400w/ brake, Metco lower CA's and Metco adjustable upper CA's, ATR bar... 10.88@126 (old combo) 1.62 60 ft. |
heres the bay , now with a heater only box
paul -NJ rep MAGNAbuick.com NJ,PA,MD DE -GN/TTA club 86 & 87 GN's A little fun with the GNs at Atco video my 86 10.4 on 93 with a 2004r on radials through the mufflers Last edited by pacecarta; December 25th, 2007 at 08:57 PM. |
outside looks like all the other black cars
![]() older pic is with no hood emblems and an 87 grill gtas , looks tame enough but it had run 10.5 1.50 60' as pictured on that tire/wheel combo the hood and bumpers arent stock , carbon fibre hood and stock apearing bupmers with the strips molded in are from Token now has the emblems and the 86 grill , i have run slicks and telstars at the track but dont run them on the street , it usually rolls on on mesh rims , either 16" gtas or rikens , or western 15" gta style rims
heres pics of the bottom end
i knew you would call me on this
, i said the same thing when i went to replace the oil pan gasket ,i remeber thinking "funny those billet mains i was told i had look just like stockers , and those studs look just like GM bolts ? " here the real pic of what im really running all those 100s of 10 sec passes with
Kinda reminds me of 9 years ago when I was told how F.O.S. I was on the gnttype BB when I ran an 11.16 on a BF Goodrich 275/60-15 (Touring Radial). Even after scanning the timeslip and having multiple witnesses I was still smoking the cheeba. Again congrats, glad to hear you are posting up your results instead of keeping them to yourself. As for the critics, pizz on em, they probably think the lunar landing is all a hoax too.................Jim C.
Whoever said progress was a slow process wasn’t talkin about me I’m a p-i-m-p plus, I got the “Magic Stick”!!! ![]() 1987 Buick GN - Best of 10.52@133 1.55 60-ft. 2000 LS1 T/A Best of 10.79@125.39 2005 5.7 Hemi 1500 truck. - 12.663.02@106 mph 1970 Cutlass 455 - Best of 12.15@116 1970 Datsun 240-Z GN Powered - Not yet. 9.52@152 with the old 355 & N2O setup hitting the gas at the 60-ft mark. Little car lotsa motor and gas. Other Toys too. Hehe |
Bumping this one back to the top for a great running car.
Congrats Paulie!
Banning Cohen 1986 T-Type WH1 Mid-Atlantic Grand National Association (MAGNA) Club Director & Delaware State Rep. New combo in the works: Girdled 109 stroker, 76GTQ 4-bolt turbo, Bronsonian Stage IV heads, 83's and Razor's dual nozzle, Turbotweak Speed Density w/WBo2 control, Powerstroke IC, Michael's TH400 w/transbrake, 33 spline Mosers & full spool, 325/50/15 drag radials. |
thanks B
heres an update added the ssautochrome headers ( atr copy) , heater box and fresh 275/60s on 15 western mesh (heavy tire wheel combo compared to slicks) put the car at just under #3500 with nothing really changed from atco my bogging at spoolup once i reach about 8psi is back and now im building boost much faster than rpm compared to the stock headers , 10psi is coming up as low as 3300 rpm where it took 4200 . moved the O2 out of the pressure area before the turbo and moved it to the downpipe (whre i had the WB before), the o2 sensor now reads consistant through the entire run without diving off due to the pressure and temps pre turbo. i was reading 680s through third and now 890 -870 through a run (same sensor) with all the fuel i could take out of my old 5.4 TT chip (3-5% less than my fastes runs) now only at 60% injector at 5850, alky only at 11:00 (thats almost at 3 with razors new contoller label) or just less than mid way . added LC-1 xd-1 gauge and moved that sensor further down by test pipe but didnt log AF , 60ft was terrible due to low launch rpm and were in the 1.7s on the first 2 passes . last pass wasnt much better and the top end picking up under 25 so theres more to be had there , last run i took the VB off which didnt seem to lean it down any with 02s in the 870s 1.59 4.411 6.801 102.89 8.874 10.642 127.19
paul -NJ rep MAGNAbuick.com NJ,PA,MD DE -GN/TTA club 86 & 87 GN's A little fun with the GNs at Atco video my 86 10.4 on 93 with a 2004r on radials through the mufflers Last edited by pacecarta; April 22nd, 2007 at 08:27 AM. |
