Car backfired and died...
Discussion in 'General Turbo Buick Tech' started by Adam Connell, Aug 8, 2012.
  1. Adam Connell Monster Truckin since 87'
    Message Count:
    909
    Offline
    Well yesterday was just one of those days... was driving back from the gym, driving normally, when all of the sudden the car backfired and died. It still cranks, but doesn't even try to fire.
    So what do yall think? Spark or Fuel??
    I've never dealt with coil packs or the ignition module, but I've got the casper's ignition hot wire.
  2. TurboBob Tater Salad
    Message Count:
    3,941
    Online
    blown fuse?
    bad crank sensor?
    bad cam sensor (sheared pin at the bottom?)
    bad ignition module?
    Bob
  3. TurboDave Navy/civilian Retired
    Message Count:
    10,412
    Offline
    I was going to suggest cam sensor issue. Try removing the cam sensor cap and rotate the cup inside by hand. If you can rotate it, your cam sensor is bupkis.
  4. jpratt Active Member
    Message Count:
    2,270
    Offline
    Cam gear, stock they are plastic.
  5. bayssngnrida New Member
    Message Count:
    10
    Offline
    I just had the same exact issue happen last week, only mine made a loud metal clang underneath the car. It cranks and sounds fine but won't fire, so I'm interested myself to your answer to your problem.
  6. TurboTnZ06 Living the dream
    Message Count:
    2,427
    Offline
    One time I pulled the front cover off instead of trying that first- doh! I broke a cam gear roll pin and the same thing happened, was cruising along, and then it just popped and backfired. I made it a few more miles home by going WOT (no backfire at WOT lol) then let off.
  7. pacecarta ----------------
    Message Count:
    5,235
    Offline
    check cam sensor
  8. bose Member
    Message Count:
    199
    Offline
    Do the basics, don't just throw parts on it. A simple spark test is to get a spare spark plug unplug one of your plug wires plug wire onto spare make sure it is grounded on the engine (spare plug) and have someone crank it over and see if you have spark. Do you have a fuel pressure gauge under the hood? Is there pressure at the gauge? Do you hear the fuel pump run a short time when you first turn the key on? If there is spark are you mechanically inclined enough to take the up pipe off and spray a small amount of fuel into the throttle body to see if it will fire? If it does your problem is fuel. An engine needs spark at the correct time, fuel, and air to run. Bruce
  9. Adam Connell Monster Truckin since 87'
    Message Count:
    909
    Offline
    OK guys sorry to bring this back from the dead, but it's taken me almost 9 months to find the time to figure out what's up with the car... I was so mad at it that I literally left it just as the wrecker dropped it off.
    First off, I'm about to go get a new battery (not sure how long it's been dead, but it's VERY dead). My fuel pressure gauge is junk, so if they have one I'll buy a rail mounted gauge while I'm there. I am planning on checking for fuel/spark first and reporting back. Would I still have spark if the cam sensor is junk?
  10. 87-WE2 Back in business!!
    Message Count:
    756
    Online
    You will still have spark if the cam sensor is dead. It has nothing to do with spark.
  11. TurboBob Tater Salad
    Message Count:
    3,941
    Online
    well...
    if the cam sensor is dead, the ignition module will not sync, and you will get neither spark nor fuel. If the cam sensor jumped time, then you will get spark, but not at the right time.
    B
  12. 87-WE2 Back in business!!
    Message Count:
    756
    Online
    Aahhh. Thanks for correcting me Bob.
    My apologies on the bad information
  13. earlbrown runs with scissors
    Message Count:
    860
    Offline
    Quick and east test here...... Take off the oil filler and spin the engine over. If the rockers don't move, you lost a timing set. If the rockers move pop off the cam sensor cap..... if it's not spinning it's in the cam sensor.
Share This Page
^ Top
