Bogart Force 5's on the TTA
Discussion in 'Turbo Trans Am Tech' started by ttafan, Dec 26, 2011.
  1. ttafan Member
    Message Count:
    164
    Offline
    Just got my Bogarts mounted up. I'm very pleased with the way these look, so I thought I would share some pics. Enjoy! :smile:
  2. Haterade Adsense
  3. its2qik Member
    Message Count:
    288
    Offline
    What size are the back rims? Backspacing? Also, what size tire is that on back? Looks like a 28x10 slick, but not sure...
  4. ttafan Member
    Message Count:
    164
    Offline
    The rears are 28x10.5-15" M/T drag slick on a 9"x15" rim with a 5.5" backspace.
  5. YamikidR1 Member
    Message Count:
    63
    Offline
    Looks BAD A$$ nice work!!!
  6. JP112_89 Member
    Message Count:
    787
    Offline
    Nice job Trent. You keep raising the bar every year. Joe
  7. ttafan Member
    Message Count:
    164
    Offline
    Thanks guys! Its hard to find rims that looks as good and are as timeless as the originals that come on the car. This is the third set of aftermarket wheels i've tried on this car and I think i'm finally 100% satisfied with the way it looks. Now i'm just afraid to bend it up at the track. :biggrin: Think i'll take it to some shows this summer...
  8. Razor Forum tech Advisor
    Message Count:
    12,257
    Offline
    Trent,
    That is all that matters. Looks great.
    Its hard to get over that 16x8 factory mesh wheel.. as nothing else seems to get that "look". My hurdle was the larger rear tires raising the back end.. I personally could never get use to having the car sit higher in the back than the front. The larger tires "worked better".. just driving down the street.. vs the 26 inch tall stocker size.. made it feel different to me.
  9. Scott89TTA Member
    Message Count:
    883
    Offline
    Looks Good Trent! WOW another set...can you still see those pretty brakes? ;-)
  10. ttafan Member
    Message Count:
    164
    Offline
    Thanks Scott! You can't see them as well as with the Magnums but that's OK with me. These match the car so much better IMO.
  11. 2QUICK2B6 Black Car Fever
    Message Count:
    1,376
    Online
    looks good to me I went with a taller tire on the front its like a 27 inch radial to raise the front when i put 28's on the back .... Im thinkin on magnum 2.0's with the gold bead locks on the rear
Share This Page
^ Top
