Old May 22nd, 2002, 01:52 PM
turbodave231's Avatar
MI Buick Performance Club
3.590 stroke in 4.1 Stage 1 block
I would like to know (from someone who has built one) if a 3.590 stroke crank in a 4.1 Stage One block will create interferance problems with a connecting rod and the stock oil pickup passage.
I am using 6.5" offcenter Carrilo rods.
I don't mind relieving the area a bit, but I don't want to break into the oil passage.
Dave
1985 GN 9.68@139.....1.30 60'
270 Stage 2
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Old May 22nd, 2002, 04:06 PM
EightSecV6's Avatar
MDBL
You will on MOST break into the oil passage
Bill Anderson
Anderson Performance Automotive
8209D Rosebank Ave.
Baltimore, MD 21222
410-282-9335
gettin tired of it...quick!
Old May 22nd, 2002, 04:48 PM
JayC's Avatar
T6P.Com/TB.com Administrator/Webmaster
Probably have to notch the bottom of the cylinders also. I have the same stroke in a stage 2 block and the cylinders had to be notched at the bottom for clearance. As Billy said you will probably have some oiling fun also but it would be better to use an external pickup anyway.
Jay
Jay Carter
Site Administrator
TurboBuick.Com
Turbo 6 Power
Old May 22nd, 2002, 07:53 PM
Bill is correct. My off-center stage II had the oil passage broke into slightley by whoever clearanced it., so Rich is going to sleeve the passage and it will be as good as new. The cylinders are clearanced, and it also uses 6.5" Carrillos like your setup.
If it ever gets done.
84 T-Type, TSO car
Powered by DLS Engine Development
219-956-3653
Big Stuff 3
Twisted 6-PTC converters
Old June 4th, 2002, 12:38 AM
geno's Avatar
9sec 17MPG Street Car
I just got through with putting a 3.590 crank in a S1 with 6.5 Carillo rods. I had to sleeve the pickup passage and clear the cylinder bases My block had a area that could have been used for a front mounted pickup if i was to machine it and delete the rear pickup There is 2 pictures in this alblum that shows the area i had to clear..
http://www.netSnapShot.com/b?ACCOUNT=2412&KEY=12
http://www.turbobuick.com/forums/pac...-update-6.html
Gene Fleury
86 Green GN Off Center Stage 2 (9 sec 140MPH street car 17 MPG)
POS Buick With Stage 2 on center(Looking for high 7,s) In work
67 Chevelle Convert 283 PG
Old June 4th, 2002, 07:29 AM
Thanks Geno. One picture=1000 words!
Go Fast!
Dave
270 Stage 2
YouTube Video
