Old May 12th, 2002, 10:30 PM
XLR8N6
Posts: n/a
Stage-2 Front Cam Bearing Hole(s)
I have a new 4.1L off-center block and noticed
that the front cam journal has a hole drilled at
the 6 o'clock position and another semi-drilled
hole at the 1 o'clock position (leads towards
the driver's side oil gallery). Setting it up for
hydraulic roller and wet sump.
QUESTION:
- Should the semi-drilled hole be drilled all
the way through to the oil gallery?? TIA.
Old May 13th, 2002, 02:13 AM
EightSecV6's Avatar
MDBL
Oil comes into the cam from the 6 o'clock hole, goes around the groove in the cam and exits at 1 o'clock into the lifter oil galley, so YES this hole should be drilled all the way through, it will supply oil to the lifters on the drivers side
Bill Anderson
Anderson Performance Automotive
8209D Rosebank Ave.
Baltimore, MD 21222
410-282-9335
gettin tired of it...quick!
Old May 13th, 2002, 11:45 AM
JayC's Avatar
T6P.Com/TB.com Administrator/Webmaster
Also, let me stress this for you.
Make sure your machinist lines the cam bearing hole up with the groove in the cam
If not, bad things will happen.
Jay
Jay Carter
Site Administrator
TurboBuick.Com
Turbo 6 Power
