  #36 (permalink)
Old March 18th, 2008, 08:49 PM
John Wilde's Avatar
Pray for Kasci Weaver
Billy,
That looks really nice, what is the rear cross over for?
John Wilde
86 T Type Blue - Driver
86 T Type Black - Resting
87 GN Back Halved - Sold
  #37 (permalink)
Old March 18th, 2008, 09:07 PM
Originally Posted by 1BADTT View Post
Billy, that looks like a burns stainless muffler ??? what size exhaust is that ? It's coming along nicely !
Nope, Burns stuff is way over rated and $$$$. That's a cheap mild steel Dynomax bullet muffler that I bought from Summit. Exhaust size is 4". I didn't opted for stainless because my car is parked in a heated garage and doesn't see inclement weather use. I'm thinking of sending the exhaust off the Jet Hot to be coated.
Billy T.
gnxtc2@aol.com
1987 GN "under major transformation"
Pictures
  #38 (permalink)
Old March 18th, 2008, 09:18 PM
Originally Posted by John Wilde View Post
Billy,
Thanks.
I have a fobia that I might buckle the quaterpanels since the frame rails are notched. By notching the frame, the lower control arm frame mounts want to twist up into the floorboard. I re-plated the frame with 1/8-3/16 steel plate. I also have the HR lower control arm boxing brackets. I'm thinking about tying the lower mounts into the crossmember. And I got tired of it laying around in my garage. So I braced the sh!t out of the car.
Billy T.
gnxtc2@aol.com
Pictures
  #39 (permalink)
Old March 18th, 2008, 10:02 PM
Im sure it will run as good as it looks - lots of work. Let us know how she goes..good luck..Larry
Working with and on my T/A motor - learned alot the hard way. However-with help from many of you - its getting there ---- Thanks
  #40 (permalink)
Old March 18th, 2008, 11:21 PM
1BADTT's Avatar
XFI rookie
Trader Rating: (12)
Billy T.
gnxtc2@aol.com
Cool ! What's the orange wrap around the trans lines in the last pic ? Thermal proteccion ? Billy do u have a pic of ur cowl dip tray available ? I'm about to install mine & any pics of it installed would be useful along with any advice or pointers. Thanx.
'87 Turbo-T
With the works in the works...
  #41 (permalink)
Old March 19th, 2008, 04:42 AM
Very Affected method for killing the competition very well done.
87White turbo T,Stage II,GN1's,Champion Ported stock lower,Hyd Roller,Atr Headers & Down pipe,Delta Race gate, 70 p trim, 72 lbs injectors,Percision upper & 65mm TB,old school KB front mount for now,areomotive fule pump,ADJ Fuel pressure reg,big mouth cold air kit/with KN FILTER,volt booster,progressive alcohol injection, scanmaster, heated o2,GNX dash,Maft Pro,ECM done for the 72lbs injectors,Type II coils&module,accel300+wires,centerline telstars,nitto drag radials/hooker 2 1/2 cat-back W/ aero chambers,metco uppers&lowers,hotchiks trailing arm braces,auto meter EGT gauge,griffin aluminum radiator,3400 9x11, converter Hope it go's 13's now.87 GN 109 block built to run 10.0's.72 Big Block Nova,83 Firebird 468 BBC.
  #42 (permalink)
Old March 19th, 2008, 10:45 AM
turbot990's Avatar
new best et. 9.65@138.52
looks great very nice great things take time and that is a very nice set up good luck
  #43 (permalink)
Old March 19th, 2008, 03:09 PM
Yep, Earl's Flame Guard (I don't agree with the color )
This is an old pic. The install is straight forward. My drip tray is made by G-Force out of Long Island, NY. I put some dum-dum under the lip that attaches to the firewall to insure no water leaks. The AC delete plate is from Mark Hueffman.
This is what I got:
Need Heat
Billy T.
gnxtc2@aol.com
Pictures
  #44 (permalink)
Old March 21st, 2008, 11:41 AM
oldtimer's Avatar
Billy,
The fitment of your intake pipe to throttlebody pipe looks a little tight. Do you see any problems here.
Do you have it fabricated yet ... any pics ?
I'm asking because I see clearance problems when I put my 4276 on.
George
Oldtimer
'87 GN ( original owner )
Cal Hartline prepared Stage 2
9.76 et @ 148.07 @ 25# with awful 1.80+ 60 fts. (some more work to do)
G S C A 2865
  #45 (permalink)
Old March 21st, 2008, 03:03 PM
42-76 install
George,
I had to reposition the header flange to get the turbo to fit. lowered a bit and rolled it forward sum. Make sure you have all the plenum spacers you can get for the intake and still close the hood this makes the up pipe easier.
Great to have you in the TSL class.
Final Answer---Gary Harmon TSL---RRA
813-355-6993
  #46 (permalink)
Old March 21st, 2008, 05:01 PM
I did not do anything to the headers. I am using TA 4 bolt headers. I don't know if TA does anything with the flange.
I am using a Champion on-center intake with a plenum spacer. I can still close the stock steel hood (have fiberglass hood in my living room resting against the couch for the past year )
I am picking up the car tomorrow. I post some pics when I have it in my possession. The pics were taken by the chassis guy.
George,
I don't exactly understand when you state "The fitment of your intake pipe to throttlebody pipe looks a little tight". Post some pics of your set up. Don't look at the pic posted on this page, that's a pic of my TSM motor.
Billy T.
gnxtc2@aol.com
Pictures
  #47 (permalink)
Old March 21st, 2008, 06:18 PM
1BADTT's Avatar
XFI rookie
Trader Rating: (12)
This is what I got:
Need Heat
Billy T.
gnxtc2@aol.com
Mine is from G-Force also, did u drill a hole for the tray ? Thanx.
'87 Turbo-T
  #48 (permalink)
Old March 22nd, 2008, 11:39 AM
Just bolted it in.
Billy T.
gnxtc2@aol.com
Pictures
  #49 (permalink)
Old March 24th, 2008, 11:10 AM
Robert Wilson's Avatar
Plenum spacer?
Billy T.
gnxtc2@aol.com
Billy,
What thickness plenum spacer are you using?
thanks,
Robert
'87 Turbo T 10.48 @ 129.3
10.48 pass
stuff
running hot humberto General Turbo Buick Tech 0 August 27th, 2007 09:08 PM
It is running the D*m thing is running!!! SGRIM General Turbo Buick Tech 1 June 3rd, 2005 07:44 PM
So what should i be running? V8killR4U General Turbo Buick Tech 2 April 13th, 2003 07:04 PM
HEY LEO, What new after running 10.77 cwmccray Hot Air (non-intercooled) Tech 6 July 20th, 2002 02:16 PM
Running GEN 7's PCS74 Performance ECM Upgrades 4 July 11th, 2002 05:56 PM
