Old November 11th, 2007, 04:29 PM
Hot Air
109 vs Stage II Parts Interchange
I'm a newbie to Stage II parts. Will anything from a 109 block fit a 4.1 Stage II block?
Conrad
Turbonetic 66-S-BB-.63exh w/EVO WG (35mm) #10780, KB 70mm TB/Plenum, Champion port Intake/CI head/Fuel Rail/EGR B/O, Comp Hyd Roller #212/212 w/beehive, Scorpion 1.5 RR, ATR 3-bolt header/dual 3" Cat-Bk/DP301, 72# inj, RJC Pl, PTE TurboSaver, 12" B-Car frt/11" Baer rr disk, Hotchkis tubular up frt ctrl arms/frt sway bar, Metco rear ctrl arms & HNR sway bar, Eaton posi w/Moser 30 axle, GTA wheels, CAS V-1/St. Al. radiator/Valve Covers , 4" cold air, XFI, GNX Dash, Autometer Dual Channel In. Air Temp, Billet Optima Battery Mnt, 9.5" ArtCarr LU 3k stall, DRW C. Al Tran. Pan w/700R filter. 11.6 @ 118 mph.
Jack & Brian Cotton (www.cottonsperformance.com) (413-789-0531) The Greatest!
Old November 11th, 2007, 04:49 PM
Yes but why?????
The:
-Crank
-Front cover
-Heads
-Flywheel
-Cam
will swap over
The basically everything will swap over except for the pistons and rods.
Another thing that you have to take into consideration if the Stage block is on-center or off-center. This basically means that Buick shifted the one bank (cylinders) .120-.125 to put the rod in the center of the piston pin hence "on-center". I believe the driver's side bank got moved forward, I think.
With the on-center block, the oil pan, exhaust manifolds/headers and intake must be on-center specific. Yes, stock production parts can be modified to fit. Also the production brackets can be made to work on the on-center block.
You must make a decision on which oiling system you are going to use.
I might have forgot some stuff, probably others will chime in.
Billy T.
gnxtc2@aol.com
1987 GN "under major transformation"
Pictures
Old November 11th, 2007, 09:42 PM
Everything will interchange, assuming it's off-center. Including rods and pistons.
On-center needs a specific intake, or some grinding on the ports and bolt holes, as well as on-center rods. Plus the front conver needs to be milled
.120. Oil pan works on either, as will headers.
86 Gray T-Type, Bench Seat, Column Shift....
274 Stage II with Stage II Heads
Old November 11th, 2007, 10:26 PM
Hot Air
Guys,
Thanks for the info. I have purchased a on-center block. Trying to determine what I can remove from my 109 engine. Sounds like the Comp 212/212 hydraulic roller cam is about it. Guess I can sell my Champion iron heads and purchase a set of 14 bolt aluminum Champion heads. Then I will need a new forged crank, good rods and new forged pistons.
Conrad
Parts interchange questions... Need help! Squid4life General Turbo Buick Tech 0 November 18th, 2005 02:18 PM
84/85 to 86/87 parts interchange sailor77 Hot Air (non-intercooled) Tech 1 August 13th, 2004 08:17 AM
Any parts I could interchange from an 81 to an 85? PNYKLR Junkyard Dogs 1 January 3rd, 2004 11:14 PM
parts interchange info please!! wlaukaitis Junkyard Dogs 1 September 18th, 2003 12:27 PM
91 Z28 for parts anyone? Interchange?? PNYKLR Turbo Lounge 3 May 29th, 2003 09:00 AM
