Here is some info, hope this helps
Block Photo Guide |
I have one but mine is actually a stage2-the oil filter pick up tube hole is in the first section of the motor and has the six headbolt holes and other identifiable things.so it could be a stage 1 or 2 with the same number.if the oil filter pick up hole is between the 2 and 3 cap its a stage1 ,if between the 1 and 2 cap its a stage2. HTH.
87 Stage2 in the works! |
Stage 1, 0016 will have 2 bolt mains, a converted stage 1 will have the remains of a oil pickup boss directly next to #2 main cap. It has to be machined away to clear a 4 bolt main cap.
Early casting stage 1 blocks had 1 water passage cast in the deck next to the middle 2 head bolt holes on the upper row. 9 times out of 10 a stage 2 will have 2 water passages next to each other. The only exception i have seen is a 0016 block and they came either way (one or two water holes). I have a few blocks here, i can take pics if it will help you out.
I own 3 cars, one has a BIG turbo, one has a BIG Blower, and one has a BIG N2O kit, but all 3 need tires
| TA aluminum block info | larry33kc | General Turbo Buick Tech | 8 | September 30th, 2006 01:06 AM |
| Where is info on block,head,crank,rod, ID number reference? | V SICKS | Hot Air (non-intercooled) Tech | 1 | September 6th, 2006 09:32 AM |
| head swap info 84 heads on odd fire block | alec296 | General Turbo Buick Tech | 2 | September 5th, 2005 09:08 AM |
| any info on this block? | racemybuick | Hot Air (non-intercooled) Tech | 3 | October 6th, 2003 08:06 AM |
| need info on a block | Badd Azz TTA | Junkyard Dogs | 2 | August 27th, 2003 01:03 PM |
