Old December 12th, 2006, 10:51 AM
Hot Air
3-Bar Map Sensor - Old P/N vs New?
I have heard that the new P/N requires a wiring adaptor. Anyone else?
Conrad
Turbonetic 66-S-BB-.63exh w/EVO WG (35mm) #10780, KB 70mm TB/Plenum, Champion port Intake/CI head/Fuel Rail/EGR B/O, Comp Hyd Roller #212/212 w/beehive, Scorpion 1.5 RR, ATR 3-bolt header/dual 3" Cat-Bk/DP301, 72# inj, RJC Pl, PTE TurboSaver, 12" B-Car frt/11" Baer rr disk, Hotchkis tubular up frt ctrl arms/frt sway bar, Metco rear ctrl arms & HNR sway bar, Eaton posi w/Moser 30 axle, GTA wheels, CAS V-1/St. Al. radiator/Valve Covers , 4" cold air, XFI, GNX Dash, Autometer Dual Channel In. Air Temp, Billet Optima Battery Mnt, 9.5" ArtCarr LU 3k stall, DRW C. Al Tran. Pan w/700R filter. 11.6 @ 118 mph.
Jack & Brian Cotton (www.cottonsperformance.com) (413-789-0531) The Greatest!
Old December 19th, 2006, 09:38 PM
Razor's Avatar
Forum tech Advisor
12223861 doesnt need anything. Direct plug in with GN harness.
The original TTA sensor was wired backwards. Hence the plug needed if you owned a TTA and wanted to use the new sensor on it.
HTH
89 TTA Stock appearing
Always on 93 octane
www.alkycontrol.com
727-570-9999
http://stores.ebay.com/ALKYCONTROL_W...eNameZl2QQtZkm
Old December 19th, 2006, 10:30 PM
Hot Air
HTH,
Thanks so much for the details. Makes sense.
Conrad
Replaced crank sensor and still no start (cam sensor?).. Sinical General Turbo Buick Tech 15 November 26th, 2006 10:51 PM
Hood shocks, PLX R-500, Cam Sensor, Crank Sensor, ATS Intercooler Parts for sale 0 July 10th, 2005 09:04 PM
Cam Position Sensor, Crank Sensor, Balancer DAVID C Junkyard Dogs 6 February 3rd, 2004 06:35 PM
Any reason why MAT sensor cannot be located immediately after MAF Sensor?? 87LtdT General Turbo Buick Tech 2 May 31st, 2003 07:47 PM
New crank sensor doesn't fit into old sensor bracket??? 87LtdT General Turbo Buick Tech 7 November 12th, 2002 05:46 PM
