Go Back   TurboBuick.Com > Tech Arena > Smog tech and emissions tech
Old May 7th, 2008, 06:21 PM
No helmet required!
Reds 93 or Conley Mini-Mag
Going on the rollers tommorow. Have changed the oil and filter and plugs. Will add a couple of bottles of Heet. Running 93 unleaded with cat and functioning egr. Swapping in a 195 stat and fresh PCV valve tonight. I have two chips to choose from, a Reds 93 and the Conley Mini-mag. It's passed with the Conley every year before but I was just wondering if anyone knows if the Reds might be any better on emissions. Running out of time before the Nats and don't want to have to deal with an inspection failure now. Thanks.
Lance Marlette GSCA #24
87 GN - XP, green stripes, Houston DP w/dump, 3" cat (sometimes), KN, adj fpr, RJC power plate, LT1 maf, translator +, extender chip, stock turbo, stock intercooler w/dutt neck 13.12, 103.20
Old May 7th, 2008, 08:52 PM
JST A 6's Avatar
Stay with your tried and true emissions setup for now; TurboTweak and 160 stat after the inspection! JMHO
Mike
1987 GRAND NATIONAL
  • TE-44 turbo
  • MSD 50 lb. injectors
  • Turbo Tweak 93 octane street chip
  • RJC Power Plate
  • VDO boost gauge in pillar
  • adjustable FP regulator
  • Hotwired fuel pump
  • Fuel pressure gauge
  • 8" K&N cone filter
  • ESP coil pack
  • 160° thermostat
  • GN1 Performance 3" T304 downpipe w/ external wastegate
  • GN1 Performance 3" T304 dump pipe & exhaust
  • Scanmaster 2.1
Old May 7th, 2008, 09:16 PM
No helmet required!
Thanks. I think that's what I'll do. I put the stat in it and it ran great after it warmed up. The Conley runs like crap until the engine gets hot. I normally run the translater and extender but it has no egr so it's out.
Old May 8th, 2008, 04:33 PM
No helmet required!
Passed without any problems. Numbers were a little higher than last time but that was probably because the car hadn't run in 2 years.
Looking For Chris Conley countrybumpkin Stage II Tech 0 January 1st, 2008 09:52 PM
Looking For Chris Conley countrybumpkin Stage II Tech 7 November 12th, 2007 03:56 PM
East Coast Auto Electric Mini 2020 12 Volt Series MINI-ALTERNATOR kwcook Hot Air (non-intercooled) Tech 1 June 2nd, 2005 12:09 AM
Conley Mini MAg GNASH Computer Chips 101 1 August 5th, 2002 06:12 PM
How much timing is in a Conley Mini-Mag chip? WSLN 6 Computer Chips 101 1 May 2nd, 2002 03:05 AM
