209 AF Reading!!!
Before replacing my maf sensor today, with a re-manufactured one, my AF readings would reach around 240. Now the highest that I've seen is 209!!! What's up with that? What do I need to do to get the AF numbers higher? Will this hurt the car's performance any? It also seems like I'm getting more knock now. Would this have something to do with that? Sorry about so many questions. Thanks, R.B
1987 GN with t-tops Ta49, 60# injectors, 340 Walbro, Lt-1 maf, Hooker cat back, THDP, Dutweiller neck, afpr, translator, Scanmaster & Directscan. Turbotweak chips. 212/212 roller rocker cam. 7.61 @ 90.53 mph 1.79 60 ft. 392 h.p. 517 ft. lbs. torque Decal on back window that reads "Hell No! It's not a Monte Carlo" 1986 T-Type. All original. |
Yes, you're getting more knock now simply because the MAF isn't able to read high enough. Those low number equate to less fuel, leaning the car out and cause premature detonation.
Dontcha just love those crappy rebuilt MAFs?? Too bad all those junk MAFs are out there. You might want to investigate the MAF Translator, and chevy MAFs All problems solved.
TurboDave EWCS(SW) USN (Ret.) My Photo Gallery Email Us Sevierville, TN TranslatorPro MAFless fuel, spark and boost management 86 GN(TranslatorPro/ExtenderPro on speed density w/boost & fuel pump control,PLX-WB) (original owner) 87 GN (second owner) 84 L69 Z28 (original owner) 01 Excursion LTD 7.3L PSD(Power Stroke Diesel), Turbo, 4X2 08 Honda Accord EX-L, 3.5V6, AT |
The Translator, LS1/LT1 MAF, and Extender chip gives the ability to read higher than 255 gps limit the stock unit has (up to 512 gps), idle fueling adjustment, and WOT fueling adjustement. Translator Plus also adds timing adjustments with the fueling adjustments. Currently my car is flowing 380 gps and has great fueling control.
Chad Schwartz (Mr. URL Sir-Links-A-Lot) rad87gn@yahoo.com "The Need For Speed" Website Cars, pictures, movies, screen savers, tech info, links, and more! '04 Dodge SRT-4 '87 Grand National (7.42@92 1.70 60ft 8th mile) w/91 octane pump gas, 22 degree Extender, 24 psi boost, TE-51, CAS V4, MSD-50, SMC Alchy, Translator w/LS1 MAF, 62mm Throttle Body, MaxEffort-16, 3" TH DP, ATR 2.5 Dual '86 T-Type WH1 (7.13@96 1.58 60ft 8th mile) w/91 octane pump gas, 25/23 degree Extender 24 psi boost, TE-63E, CAS V4R, MSD-50, PT&E Ported/Polished Iron Heads, 206/206, 62mm Throttle Body, 9/11 3,700 stall, SMC Alchy, XP+ Double Pumper, Translator w/LS1 MAF, 3" TH DP, 3" ATR Single shot '79 Hurst/Olds (12.72@106.91 1.84 60ft) ZZ4 350 Chevy w/125hp nitrous |
