6 Point Cage in 87 GN
I just got my car back from having a cage installed. It turned out pretty good. I was worried about the door bars but it is really easy to get in and out of. The bends to get around the door panels and concert speaker perch are as tight as they can be. I don't really have much road noise as some mentioned the cage would cause. I do have a noisy 10-bolt so it probably covers up most of the sound I would hear.
87 GN, TE67, Champion irons, T&D 1.65, SCE Titan ICS head gaskets, Champion intake, Kenne Bell 208 cam, TRW pistons, billet caps, Eastern FMI, 62mm TB, IAC Angle Boss, custom plenum, 60lb Mototrons, RJC Boost Controller, 3500 Pat's Converter, Art Carr 2004R, Setrab trans cooler, Hooker Exhaust, Performance Instruments Dash, 6-point cage, 2" drop springs, tubular A arms, ZQ8 Blazer front disc's, HR bar, HR adj uppers & lowers, Gen2, LS1 Maf, Ext G chip, Wideband LC-1, Big Mouth Cold kit, 3.5 MAF pipe, 255/50/16 MT drag radials. More to come... 1/8th mile at 7.15, 97mph, 1.62 60', 23lbs, 110 octane, 24' timing - and it will get faster! Prostreet Nova SS, 355 w/671 BDS, tubbed, 9", 5-spd 80 Golden Eagle CJ-7 V8, 4-spd - restored |
yeah the leather looks sharp, nice cage too. Nice taste. The ladies will like leather
Ill give you half track and the leave! http://gabesprojects.myphotoalbum.com/albums.php |
Thanks for the compliments.
Looks good! Are they the JAX leather seats? How much did the rollbar cost installed if i may ask? Im thinking of doing the same thing. Would you know what track times the bar qualifies for?
87 Stage2 in the works! |
Seats are actually "pleather" which is vinyl that looks like leather. The silver has a carbon fiber pattern. I had the headset covers made at a local sewing company. The 6-point role bar cost $650.00 installed which I think was a great price. I only have plans for the car to run in the 10's and it was built to pass tech for that. I think you have to have 8-point in the 9's. I chose not to have the two little bars that run from the center hoop to the floor behind the front seats; hence 7th and 8th points. You can still get in the back seat but I am not sure anyone has ever ridden back there. I added the role cage because the local 3 or 4 IHRA tracks I play at required it when faster than 7.50 in 1/8th or under 12 in 1/4. thanks
The builder said it will pass all the IHRA track specs. The closest NHRA track is Commerce, GA and when I take it there I expect it to pass but they may say something. We'll see. Hopefully because it is a driver and should only go mid 10's I can get by with it. I can add the rest of the cage if needed but I don't have any plans to do so.
| 10 Point S&W roll cage/ rear runners | 1of1547 | Parts for sale | 2 | August 2nd, 2007 02:03 PM |
| Who makes a good easy (or some what easy) 8 point roll cage for our cars?? | thunderace31 | General Turbo Buick Tech | 11 | August 1st, 2006 04:12 AM |
| What's max e.t. for 8 point cage? | jjvites | Bracket Racing Across America | 12 | April 22nd, 2006 11:45 PM |
| 10 Point Cage | Brian Schauder | Turbo Lounge | 3 | May 10th, 2005 10:11 PM |
| Need cage put in | Fatsix | North Eastern Area | 10 | April 6th, 2003 02:38 AM |
