Go Back   TurboBuick.Com > Marketplace > Parts wanted
Old January 21st, 2007, 08:54 PM
Life is GREAT!!
VDO oil Gauge (electrical)
looking for a "WORKING" 2 1/16 black face VDO oil gauge complete with sender
THANKS
AgTeacher
87 GN-Shop Class Students MODS.: ScanMaster and PowerLogger,Extender chip,LM-1-WB,EGT,fuel press.,3bar MAP,340 fuel pump/ hot wire,adj.fuel reg.,Fbody radiator, Fbody duel Fans,160deg.Tstat,SMC alcohol “progress” injection kit,ATR headers,SE 3" downpipe & dump with elec.cut-out,HD adj.actuator,4" built-in MAF pipe-Cold air"big-mouth" 4in intake WITH translator +,gauges(knock--audio and visual-,boost,water,oil and tach),New body bushings,ALL-BRACES,Century STAGE 2 trans.& 9.5" 2800 billit l/u conv.,TE-60,60's lbs.injectors,CAS-v4,RJC power plate,62mm throttle and 62mm dh,Boxed upper/lower trailing arms,S10 frt.disc,Line-lock, E-vac pump and 2400 watts Rockford Fosgate sound system and NOW...NITROUS & CO2
Life is like a WHEEL....what goes Around....comes AROUND !!!
Phantom fp gauge, gauge pods, test pipe, powermaster, lakewood shocks Dan K Parts for sale 22 September 18th, 2005 10:43 PM
Electrical Fuel Pressure Gauge Recommendations? Raven General Turbo Buick Tech 6 June 21st, 2005 12:36 PM
Electrical Coolant Temp Gauge quazzy81 General Turbo Buick Tech 1 June 17th, 2005 10:14 AM
Electrical Coolant Gauge Accuracy trbodon21 General Turbo Buick Tech 5 July 2nd, 2004 02:38 AM
Dumb gauge/electrical question 1bad85gn General Turbo Buick Tech 3 November 20th, 2002 07:18 PM
