Radiator hold down.
I need a radiator hold for my 85 GN. Using a f-body radiator. Just looking for the piece that runs across the top of the radiator and holds it in place. Nothing fancy needed. Junk yards in my area have nothing. No internet at home, please call and leave message........920-296-3017. Thanks, Nick.
~'85 GN~!!SOLD Fall of '06!!~ ![]() V2 intake, Spearco FM, TA-49, 40#inj., ATR pipes, & even more crap that I can't remember!! ~'01 CVPI~ 4000lb. Daily Driver thats run a best of 14.924 @ 93mph. Slower then your average Hot Air! Pictures: http://community.webshots.com/user/1quick6 |
The direct bolt on plate is from an 87 V8 Cutlass. Other years may work as well. You can have your local junk yard locate one. These guys are very computerized and share parts. Brad
85GN, TA33C Turbo, ported and matched intake and heads, 42.5 lbs blue stripe injectors, Poston exhaust headers, Hooker high flow 2 1/2 exhaust, Walbro 340 fuel pump hot wired, test pipe, 2 1/2 inch integrated downpipe(no turbo elbow), F-Body rad. dual ramchargers, 87 ECM-Wide Band Turbo tweak chip, Razor Alky kit. Scanmater, LS1 MAF with Translator, BLM of 128 at idle. Trans oil cooler with a 2800 stall conv with lockup, oil cooler. Mickey Thompson drag radials. Ported throttle body. HRPARTSNSTUFF motor mounts. Powerlogger with wide band o2 sensor. |
I found one at a local pick 'n' pull. $5.....direct bolt on from a early 80's cutlass v8. Thanks, Nick.
