Go Back   TurboBuick.Com > Marketplace > Internet Auction Finds & Possible Frauds
Old January 27th, 2008, 07:22 PM
Left coast Buick lover.
87 ebay car...are these good upgrades?
eBay Motors: Buick : Grand National (item 160202881920 end time Feb-05-08 13:15:05 PST)
I new to GN's but not to Buicks. I have two GS's now but I'm seriously considering a GN. This car on ebay is only 15 minutes from me. I'm looking for some feedback on the upgrades done to this car. Are they good? Any opinions on the value of the car are also most welcome! Thanks in advance for you help.
Harvey
Vehicle is not stock and has had the following modifications made by Aggressive Performance in Michigan. GNX style rims(16 in. GTA) w/ Michelin Pilots(front 245/50/16-rear 255/50/16),has newer paint,TE 62 turbo,Houston downpipe,ATR stainless 21/2 in. exhaust,Red Armstrong XP fuel pump, 009(blue top) injectors,62 mm throttle body, ported upper plenum,ported stock intake,,Champion iron ported heads W/ M/A casting "Buick" logo aluminum valve covers,Roller cam w/ kit, all ARP hardware, MSD plug wires,Aluminum radiator w/ integrated cooler,turbo saver lubrication system, 2800 stall converter, shift kit, chrome alternator,inlet pipe,turbo shield and cross over pipe, Kenne Bell adjustable fuel pressure regulator,GNX dash(VDO guages), all weather stripping replaced with new OEM parts, rear seat braces in trunk, BG customs floor mats and headrests w/ embroidered "Grand National" logo, cold air kit(Tinman) w/drivers side inlet air dam, Eastern Performance front mount intercooler, bilstein shocks.
Old January 27th, 2008, 08:07 PM
jcj1407's Avatar
I don't know anything about the performance shop he is talking about, but the list of the mods seem pretty good. I can't remember for sure but I think the 009 injectors are 42.5 lbs, if I'm correct they may be a little small if you turn the boost up very much with no alchy (relatively cheap fix). Other than it seems like a great package that should be nice and fast when tuned properly.
87 GN: GT66 DBB turbo, SMC alky kit, rebuilt/girdled bottom end, RJC power plate, FMIC, RJC 3" downpipe, 60lb injectors, 204/214 cam, RJC rocker shaft braces, Russ Merritt heads and ported intake, Big Mouth air intake w/K&N, poly motor mounts, Walbro pump/Hot wire kit, TT alky chip, West Coast 3200 stall converter, Hooker exhaust w/dump, Metco Lower Control Arms, ATR Style rear sway bar, Air Bags, Nitto drag radials......
Old January 27th, 2008, 08:38 PM
Brer Rabbit's Avatar
Pursuit Specialist
Yep blue tops are 36lb. injectors.
I would make sure the Champion / M&A issue is clarified. Champions are fine but I believe the M&As are known to crack. It does sound like its just M&A valve covers but I would certainly make sure first. Sounds like the guy has dumped a lot of money on the car especially if he had the work done at a shop. Take the VIN and call the shop and ask them if they worked on the car. Who knows they might tell U.
The Widely Accepted and Riegning "Peoples Champ" in the state of Illinois, as stated by Dr. Boosts Girlfriend! Man was he mad when he heard that!
Old January 28th, 2008, 12:39 AM
Anyone care to make a guess as to what this car is worth today on the assumption that everything he says is accurate?
Thanks for the input so far!!
Harvey
These good upgrades? JB151 General Turbo Buick Tech 10 March 19th, 2006 11:35 AM
this TTA looks good...Ebay rex362 Turbo Trans Am Tech 19 September 21st, 2005 03:47 PM
An actual GOOD alternative to eBay!! If you ebay YOU have to see this AZ Vic Turbo Lounge 12 January 27th, 2005 09:29 PM
Good deal on Ebay Otto J Parts for sale 1 December 26th, 2004 08:44 PM
Some good upgrades for a 1985 Grand National TurboTer Hot Air (non-intercooled) Tech 5 March 12th, 2003 06:24 AM
