hydro boost to vacum brakes????
can a regular vacum brake set up be put on a 85 gn?????
85 gn gone ,85 regal broken 84 z28 camaro 400 horse 350........"haulin ass on pump gas"
Why would you rid your car of the Hydroboost system?
It is a strong system, and offers alot of holding power out of a Stock Brake setup. I can hold an easy 8+ PSI on the brake. IMO...Don't swap the system...Enjoy the system that the 85/86/87 TurboRegals wished they had! I see you have an 85GN....The 85's came with the PowerMaster....correct?!
Herb Fishman TurboRegal84@Hotmail.com 1987 Buick GN X - One of the Fortunate 547 1987 Buick Grand National 840 Miles-SOLD 2003 Ford SVT Lightning #4261-SOLD 1999 Ford SVT Lightning #2212-SOLD 1984 Grand National TOTALLED By a Church Van Special Thanks to: Kevin "BFH" Williams, Chuck P, and Jason Cramer. "Was one of the few stock appearing 12 sec Hot-Air GN's" TurboBuick.com Member Since 5/99 |
brakes
the brakes on my car run off of the power steering pump.the seals are blown out money is tight for about a month.wanted to convert till i could afford the new unit
Late 85 cars came with powermaters
Early with Hydroboost ![]()
86 T-Type 106K BB66, BGC 23 row, 9x11(2800), 60lb Injectors, Translator Plus, Extender, SMC alky - blah,blah, blah |
Where are the seals blown out at???
Find a salvage yard with some GM cars or even trucks(early 80s) with diesel engines in them...They will have the HydroBoost setup on them... Or, I'm not sure because I've never checked, but they should offer a rebuild kit with the seals, etc., either at the dealer, or even aftermarket parts stores...Figure out which seals are blown, and replace them...Can't be any more than $5 or so per seal... Herb is right, though, the HydroBoost setup is tough to beat for holding power... edit Just got off the phone with AutoZone, they had the HydroBoost booster w/o master cyl for about $121 + about $45 for a core charge...You would end up with that much in a vacuum setup swapping it over...They didn't have it in stock here, but could get it in about a day...Would have to pre-pay...
Jim F fjm568@swbell.net 85 GN 87 T 66 Skylark Last edited by FJM568 : August 26th, 2002 at 07:44 PM. |
what id the difference between hydro boost and powermaters????
Re: brakes
Powermaster is the later model system, but is very trouble prone and expensive. Found on the late 85 models, along with the 86 and 87 models. Most often replaced with vacuum bosted brakes. As far as I'm concerned, Hydroboost is the ONLY power assist brake system for a supercharged car.
Alan K. Roehrich Grant's Custom and Racing Automotive 615-893-1665 |
I think GM STILL puts them on trucks, a few months ago I saw one on a '99 GMC my cousin was working on, looked exactly like the one in my '84!
Custom Dress-up stuff for your TURBO REGAL, Console Overlays, Aluminum Shifter Handles, Wheelcap Overlays, Door and Underhood Dress-up, and More! contact Mark Hueffman at www.buickgn.com |
PowerMaster has an electric motor underneath the master cylinder, the HydroBoost don't...
Hydroboost has hydraulic lines running between the power steering pump, the power steering gearbox, and the Hydroboost unit(which is mounted between the firewall and the master cylinder)...
Jim F fjm568@swbell.net 85 GN 87 T 66 Skylark |
I believe that the Powermaster is the biggest shortcoming on the Buick. I had it replaced under warranty twice and once out of pocket.
After the fourth failure I switched to vacuum boost, which has never failed me. But my brothers '84, which he's had since new, I think has better feel. Either one is an improvement over the Powermaster ![]() |
Been using vac brakes for 3 years and they work just as good as the hydryboost did,weigh a hell of alot less and free up space,and are more simple and dependable.Wet,slipping or broken power steering belts don't stop them from working,and will never ever ruin your pretty carpet. And yes I can hold over 5psi with regular street radials.I have not experienced any disadvantages yet,if you know of any please tell me about them.Seems with the hydro you have alot more possible scenarios for failure.Have you ever seen a post"my vaccum brake setup failed and I'm going back to XX"? No flame intended,I just don't understand why some insist on directing people from going with what seems a no brainer setup? ![]() |
