Converting off the 87 MAF
It is time for me to upgrade from the 87 MAF to the LT1 and the translator. The cost is the driving force. The rebuilt 87 MAF are too expensive and may have reliability issues. Tranlator is $200 plus shipping and a used LT1 is $50. Rebuilt 87 MAF is $190. Todays electronics are so much better. I will post on my results. Take-care- Brad
85GN, TA33C Turbo, ported and matched intake and heads, 42.5 lbs blue stripe injectors, Poston exhaust headers, Hooker high flow 2 1/2 exhaust, Walbro 340 fuel pump hot wired, test pipe, 2 1/2 inch integrated downpipe(no turbo elbow), F-Body rad. dual ramchargers, 87 ECM-Wide Band Turbo tweak chip, Razor Alky kit. Scanmater, LS1 MAF with Translator, BLM of 128 at idle. Trans oil cooler with a 2800 stall conv with lockup, oil cooler. Mickey Thompson drag radials. Ported throttle body. HRPARTSNSTUFF motor mounts. Powerlogger with wide band o2 sensor. |
I will let you know how it works once I get the translator. It should be plug and play. Brad
Brad............what would it take for you to ditch the MAF alltogether.......I'm not familiar with the translator options, but is that one of them ?......with your list of mods and a wideband, it looks like you could benefit from not running a maf at all...no flame intended, just curious.
Ugly travels in pairs....don't believe me?.....look at the sumbitch next to you...... |
Dwayne- I have heard a rumor that TT is working on a MAFless chip. I need to suck it up now and get rid of 20 year old stock MAF's and the horribly over priced remanufactured ones. The translator is a proven product and there are literally millions of LT1 MAF's which I believe are still being made. You can buy the translator from TT as well as Fullthrottle. I will post results once I get the translator. Take-care. Brad
I typed too slow.....I know that TT and Yaklin worked together..........and as sharp as Eric is, I can see a mafless version in the horizon.......lets us know how it works for you.
Been trying to call you for 3 days! LOL Not a rumor anymore ..... Look at the last chip listed hereTurboTweak - Turbo Buick Custom Chips and Parts Contact Eric. Edit: As in any SD chip, it will require a IAT in the intake, after the turbo. ![]() Quote:
Chip has some AWESOME features!! All I can say is "WOW!!" ![]()
Chips By Turbo Tweak -"Simple And VERY Effective" Sometimes what counts is "That which you DON'T do" Nobody likes the "Smell of @$$", so don't show yours here. KNOCK Check list! - Chasing KR - By Razor! X-Mas Every Day!- Click here 84 Pics here; It's only slow because it's stock and missing 2 cylinders! In GOD we trust, all others must provide data.YES, Already replaced that too, TWICE! . Read on the future of "World Peace" Last edited by Jerryl : August 3rd, 2008 at 10:36 AM. |
Brad -let me know also how you like it I've got a LT1 maf and Translator 2 sitting on the shelf as well--haven't installed it either...
Mark http://community.webshots.com/user/M...host=community 1984 GN--stock turbo w/adj. wastegate actuator, 42.5 blue stripe injectors, Poston headers, Walboro 340 fuel pump--hotwired, adj. fuel press. reg., 87 ECM -Turbo Tweak chip, 87 MAF, MAT, 87 Coil/Ign. module, K&N cone filter, Scanmaster, Boost, Water Temp., Oil Press., Casper's Knock guage, 160 T, Boxed Rear Control Arms, 15 X 7 Weld Draglite (4.5" BS) w/ 225/60 T/A's & 15 X 8 Weld Draglite (4.5" BS) w/ 275/50 T/A's |
I installed my LT1 MAF and translator YEARS ago...Back when the translator first came out. I don't even think my translator is upgradeable like the newer ones are, mine is so old...
Worked great, last time I drove it(4-5 yrs ago) Wiped the cam, parked it and walked away(3 cams in under 2 yrs)...Finally got my motor fixed up(thrust surface on face of block worn, now fixed(pics in another thread)...Also did the factory style roller lifter conversion featured in the other massive thread, got some pics of my conversion in there...Made some solid rocker arm shafts, got pics in another thread if you haven't seen those yet) Motor just needs to get all assembled. For those who don't know my setup, I just haven't been active here in a while. My setup is as follows... 109 block, .030 over Stage Jr heads(no EGR or heat crossover provisions, CNC bowl work done, short side radius worked) flows real good... stock 86/87 lower, custom upper plenum to keep turbo in stock 85 location TA 51 turbo with PTE exhaust housing MSD 50# injs. DeQuick V-2 front mount IC 212/212 roller cam Neil Chance 2800 stall l/u converter 3" Terry Houston DP prototype made by a longtime current vendor Joe Lubrant low timing street chip All of the above, except for the roller cam went 13.5 @ 108 on street tires with 92 oct pump gas, open dump, 16# boost with a 2.4 60' time(cam was a Comp Cam 206/206) chassis dyno'd the week before at 330 HP/440 torque on 92 oct pump gas at 16# boost, closed dump... Sorry to hijack the thread, got a little carried away... ![]()
Jim F fjm568@swbell.net 85 GN 87 T 66 Skylark Last edited by FJM568 : August 6th, 2008 at 12:54 AM. |
| converting to AWD | usetaboost | Syclone & Typhoon Tech Forum | 8 | April 24th, 2007 11:27 AM |
| Converting | ejkh87 | General Turbo Buick Tech | 3 | December 21st, 2006 05:34 PM |
| converting a 84 to a 87 | YBLEGL | General Turbo Buick Tech | 5 | November 22nd, 2004 12:28 PM |
| Converting to an '87 ECM | TurboTer | Hot Air (non-intercooled) Tech | 10 | June 1st, 2003 04:41 PM |
| Converting a Hot air car. | SSPARKY | General Turbo Buick Tech | 1 | July 26th, 2002 07:31 PM |
