Fuel Pump Question & Fuel Rail Part
I changed the fuel filter on my car- apparently the one on the car was installed backwards (flow arrow pointing to the pump). Before the change, the fuel pump was extremely, loud, now I cannot even hear it. I checked F.P. after the change and it was 35 PSI at idle, line on. Is this normal - I'm sure most TR owners don't let their fuel filter get this clogged, but has anyone else experienced this?
Also, does anyone know a part number / supplier for the schrader valve core in the fuel rail? A/C size ones do not fit - mine looks pretty crusty and it makes me nervous.
86 T-type Astroroof, Dark Red Metallic, FMIC, TE-44 Ported (Champion) Irons, 3000 stall, double pumper |
shrader valve is the same size as the valve stem in your tires.
Mid Atlantic Grand National Association MagnaBuick.Com 87 GRAND NATIONAL: 86 T-TYPE: Light Chestnut Met. Sold ![]()
FP should be ~42 line off. I wouldn't measure it line-on since vacuum drops the reading, and the engine will get different vacuum on different days and whatnot based on weather and being finicky and such.
87 GN with dual catback from monte, big mouth CAI, walbro 340, kirban adj fpr/guage, world record slowest car yet with maxeffort mafless, BstC boost controller, DS, msd 50lb/hr squirters, rjc power plate, airbags. best/only run so far: 14.6 @ 87mph @ 25+ psi of (accidental) boost on 93 octane. Just needs paint!!! newest mods: nos fuel sol type 7th squirter, te45a (67mm gt wheel), precision fmic, atr rear sway, lt1 starter, .030" over with forged pistons, billet steel caps (#2/3), 224/224 flat tappet, double roller chain, .010/.010 crank, etc. |
