4.1vs 3.8, power gains with using the same heads.
Since my project is getting closer to completion, I was wondering just how much more power a 4.1 is worth with the same stuff bolted up top. I had to get rid of my GN1s due to lack of funds so I have ported irons, the same as with my 3.8.
I figure I'm going to have faster turbo spool, more low end torque, more midrange, but I've been wondering, is the 4.1 worth much power in the upper rpm range considering the limited airflow of the heads and intake?
84 GN. 4.1L girdled with 8.5:1 JEs, 212-212 Comp Cam, GN1s, Ported stock intake, Ford FM IC, 6765DBB, KB headers, Cotton's 3" DP, Innovative Turbo Systems external gate, 60lb injectors, Turbo tweak chip, and a few misc things. No times with new combo yet. 06 Acura TL daily driver. |
thanks for any info BW
BRYAN Eric Marshalls Turbo Tweak Chips Timeslips for white car TA61/009 Inj Under hood shot of white limited ![]() ![]() Proud TTA owner |
I didn't want to turn this into a 4.1 strength debate but I'm a little worried too. I want to know if anyone has ever actually blown a hole in a cylinder or if it's just hearsay like a lot of things on the internet. I've always heard the hotair block is weaker than the IC block but I had a pretty potent combo and not a bit of problem. Duttweiler himself told me the hotair block is no weaker it just doesn't look as pretty in the valley area and it's possible for cracks to develop from the rough casting.
I talked to my engine builder (who is an engineer and had a part in the Buick Indy program) and he flat out wouldn't do hardblock on my street driven car even a small amount. He said it would hold up as long as it's in a good state of tune. Mine's .035 over so we'll see.
i didnt come anywhere close to breaking a block-
but i did purchase a car in the past that it turned out to have a 4.1 litre engine in it, .040 over,stock cam, stock nylon timing chain gears , mild ported heads and intake-went 11.80s no problem on nittos at 118+ with a looooooose 9 inch non lockup convertor so my answer to your first post is, yes its like having more power all the time, but i felt it was limited on the upper range- i think i was just afraid to rev it up past 5200ish?? its the only turbo regal that i was able to blow the tires away thru 3rd gear on real radials with 3 guys and a full tank of fuel- it had a te45a with .85 housing spooled SUPER FAST- MSD 50'S, ATR 301 DOWN PIPE, dual 3 inch exhaust
I have block hard 1.75" from deck in my 4.1 and plan on driving it sometimes here and there. Also the lifter valley has been Ti-putty to strengthen that area. I have a 4.1 reciepe from the man Lonnie diers. He has giving me great knowledge on the 4.1 and a also have Nick Micale helping out with the dirty work on this motor. I plan to see what a 4.1 can do and I know they have potential if built right.
86 White Ttype Rolling chassis w/6point rollbar FOR SALE 86 Grand National Stock W/ Baer 12in front,11.5 rears brakes,3in Atr crossflow exhaust, Pitbull mufflers,3in Atr DP301,Atr Duel fuel pumps, AtrSS/Headers. http://community.webshots.com/user/whitettype |
That's what I like to hear!
